Old 15-10-2013, 12:39 PM   #1
twr7cx
Member
twr7cx's Avatar
Arrow AU2/BA/BF Brembo Compatible Front Brake Line Brackets
Matt,
As you are aware I recently purchased the 6 piston Brembo front brakes from you. Being an AU Series 3 Pursuit 250 ute with the OEM Tickford/PBR twin piston units, they also have factory standard braided brake lines (front only). The OEM braided brake lines have a bracket to hold the hose with a rubber grommet. This bracket is not removable from the brake line due to the bracket not having an opening slit.
The Tickford lines can't be used on the Brembo calipers as the caliper end connection is rectangular in shape and the Brembo's seem to require a circular mount (such as that on the brake line which you supplied in the kit) due to it being indented into the caliper body.
The brake lines that you supplied already have a rubber grommet fitted to them and the solution was to purchase the BA brake line brackets at $4.15 each side. The part number is F*BA2L456A. These have an opening allowing the new brake lines to easily be fitted into them.
Note: that the Ford Spare parts dealer informs me that there is a separate listing at $120.00 per side for Brembo compatible brackets, however, I found the standard brackets to be compatible with the Brembo 6 piston setup.
Thought I would post this up here for anyone else's future reference if they run into this problem.
Now that I have the brackets sorted hopefully the rotors will be here in the next few days to finish the job!
Current vehicles: MY12 Land Rover Discovery 4 TDV6, MY03 Land Rover Discovery 2 HSE Td5 off road modified and 1989 Mazda NA MX-5 toy car.
Previously: 1992 Ford EBII Fairmont, 1994 Ford EF Falcon XR6 supercharged, 2003 Ford BA Falcon XR6 Turbo 325rwkw, and 2002 Ford AU3 Falcon XR8 Pursuit 250 270rwkw.
twr7cx is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2013, 02:30 PM   #2
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Default Re: AU2/BA/BF Brembo Compatible Front Brake Line Brackets
Thanks for that and the recent Brembo AU 111 job we did had coilovers and no hose locators on them and this presented a challenge as well.
MATTHEW PEARCE
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
