Old 27-12-2005, 11:51 PM   #1
kcaillin666
New Ford Owner
Default 1978 esky
hey guys just lookin for some help on finding some flat top pistons for a 1.6 litre escort
i dont wanna do a 2.0 litre conversion because everything that is in my block is good, just going to but a new camshaft and springs/rockers/rods
and just looking for a couple of suppliers for a standard 1.6 escort
Reason for not wanting to do a conversion is that i would like to keep the car origonal with everything that it came out with
thanks
caillin
kcaillin666 is offline   Reply With Quote Multi-Quote with this Post
Old 28-12-2005, 12:27 AM   #2
INJECTED_250
Custom user title
INJECTED_250's Avatar
mate .. if u pull the head of the escort u wil se that its surface is flat, the pistons have a massive dish in them , i flat top piston wont work.. I mean it would run on diesel ok....
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
Old 28-12-2005, 04:47 PM   #3
kcaillin666
New Ford Owner
i want higher compression though and im gonna be running a lumpy cam
Old 29-12-2005, 01:10 PM   #4
filoil
filoil's Avatar
Hi M8
as injected 250 said the compression bowl is in the piston on Xflows fitting flat tops will smash the valves to bits with std cam never mind a Big cam.JP engineering in south aus (0882617222) do a piston @ 83.5mm (part no Q202087) which will give 10.5cr & 1700cc the valve cutouts are something like 50thou deeper & wider, for Big cams and overlaps,this is used with std head gasket.I have used this piston for quite some time now with no worries about water jacket leaks etc.
filoil is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2005, 02:54 PM   #5
356mal
put 1300 pistons in it they are the same diameter just have a smaller bowl and therefore raise the compression to approx 10:1
356mal is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2006, 10:25 AM   #6
whooligan
whooligan's Avatar
As 356mal suggests the common mod is to put in 1300 pistons but economically you are better off just putting in a 2lt from a later model escort or cortina. There are a few local x-flow specialists who are capable of wringing every last horse out of the old kent lump but my $600 pinto would wipe the floor with most of them. If you are determined to keep it "looking" original but want a "bit" of extra performance give Twin Cam Services a call (03) 9786 4711 in Seaford.
