ASL
Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Race Brakes Sydney
Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link
Old 06-02-2013, 07:38 PM   #1
FAT245
Lacking Imagination
FAT245's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Nath deserve's a Technical Contributor award for his willingness to share everything in his vast knowledge of tuning EEC-IV and -V Falcons, not to mention engines!
Default Help with finding Discs..
hey Guys,
I got given a front end upgrade for my AU Fairlane.
It came off a BA yet i cannot find any information regarding the discs?
Disc Rotors have K388-004C Cast into the front and measure 355mm,
Yet they have PBR 2 Piston Calipers.
Can you help me out?
My 11 Second AU Fairlane
364w | 225cc CNC | ---/---@0.050 | Morrison Motorsport ITB Manifold | MoTeC M150 (Engine Control) | PCS TCM-2800 (Trans Control) | 6800rpm Stall | 4R75W
FAT245 is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2013, 09:38 AM   #2
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Default Re: Help with finding Discs..
Originally Posted by FAT245 View Post
hey Guys,
The casting doesn't help me but we do a twin piston kit with 355mm rotors and the rotors are FPV discs but there may also be other kits available as well i would have to get the specs off the disc and see the caliper first.
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop
Street to track is what we expertise in
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
FLOORED is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2013, 10:16 AM   #3
FAT245
Lacking Imagination
FAT245's Avatar
The only Label i can find on the Caliper is a Barcode Sticker that says 'EF8'
Old 07-02-2013, 10:19 AM   #4
FAT245
Lacking Imagination
FAT245's Avatar
Are any of those Pictures Helpful?
Old 07-02-2013, 11:33 AM   #5
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Are you sure there 355mm they do not look like it?
MATTHEW PEARCE
Phone 02 9609 1101
Old 07-02-2013, 11:44 AM   #6
FAT245
Lacking Imagination
FAT245's Avatar
90% Sure they are...
Old 07-02-2013, 12:13 PM   #7
05_ENFORCER
05_ENFORCER's Avatar
298 or 325 mm maybe by the looks of them def not 355 mm
This is the difference when compared from a top view, as you can see, not a lot of physical difference between 325 and 355 mm.
2015 FGX XR8 5.0 S/C 645 RWKW
05_ENFORCER is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2013, 12:19 PM   #8
FAT245
Lacking Imagination
FAT245's Avatar
Thanks, Ill check them out tonight and get back to you.
FLOORED, If i wanted a decent set of 325mm Discs to suit, what would they run me?
Old 07-02-2013, 12:57 PM   #9
FLOORED
Race Brakes Sydney
FLOORED's Avatar
They look like 322mm discs but also check the thickness as these are 28mm and the 325mm thick disc is 32mm thick but that 325mm disc used either a red PBR caliper or a Black BA GT caliper generally.
MATTHEW PEARCE
Phone 02 9609 1101
Old 07-02-2013, 12:58 PM   #10
FAT245
Lacking Imagination
FAT245's Avatar
Minimum Thickness on these says 26mm
Old 07-02-2013, 01:04 PM   #11
05_ENFORCER
298 mm then?
Old 07-02-2013, 01:17 PM   #12
FAT245
Lacking Imagination
FAT245's Avatar
The ones on the Fairlane are 287mm and these things are larger than that. As well as the calipers are larger than AUII/AUIII Items.
I am thinking they are off a Typhoon? cause the guy I got them off has wrecked out a couple of FPV Cars as well as some XR6T's
Old 07-02-2013, 01:35 PM   #13
05_ENFORCER
From what I have found on late model front brakes:
I haven't researched pre BA models
BA, BF, FG 298 mm front std
BA FPV 325 mm front
BF, FG, XR6T, XR8, G6ET, Territory 322 mm front
FPV premo 355 mm front
Old 07-02-2013, 01:52 PM   #14
FLOORED
Race Brakes Sydney
FLOORED's Avatar
The 28mm disc will be either 298mm or 322mm in diamter so just double check tonight to see what you have and let me know in the morning
MATTHEW PEARCE
Phone 02 9609 1101
Old 07-02-2013, 01:54 PM   #15
FAT245
Lacking Imagination
FAT245's Avatar
No Worries.
Thanks Matt!
I will also need Braided Lines to suit the calipers, I am sure you can help me with those as well?
Nathan
Old 07-02-2013, 02:09 PM   #16
FLOORED
Race Brakes Sydney
FLOORED's Avatar
No Worries.
Thanks Matt!
Nathan
Sure can mate
MATTHEW PEARCE
Phone 02 9609 1101
Old 07-02-2013, 02:59 PM   #17
FAT245
Lacking Imagination
FAT245's Avatar
PM Sent
Old 07-02-2013, 08:15 PM   #18
FAT245
Lacking Imagination
FAT245's Avatar
322x28
Discs have plenty of life in them (measure 27.6mm thick) Will throw on a Good set of Pads and Braided Lines ..
