Old 14-12-2011, 01:15 PM   #1
ya.rahman
Default EF Fairmont Ghia 1995 - Speaker size
Hi,
I have Ford Fairmont Ghia EF 1995 and I would like to know the size of the front door speakers.
I am planning to buy new front door speakers, hence please let me know the size of the same and also the procedure on how to replace the speakers.
Thanks
Ray
ya.rahman is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2011, 03:14 PM   #2
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
Default Re: EF Fairmont Ghia 1995 - Speaker size
6" stock but 6.5" can fit as long as they dont have a massive magnet on them - as do the more high end spekers do
EF/EL Door Measurements
Hole size: 126mm
Width around hole: 160mm ( recessed section around hole)
Allowing 2-3mm gap to clear the window the following is a guide to the max mounting depth allowable
Depth @ top of hole 60mm
Depth @ centre of hole 70mm
Depth @ bottom of hole 72mm
If you use a 12mm MDF spacer ring then the maximum depth in hole centre is 92mm.
Max depth speaker you could fit into the door and still have the window wind up and the door skin fit on would be 92mm deep in the middle.
An additional spacer ring can be made up to 12mm thick and this gives an additional 12mm mounting depth without fouling on the standard door skin and allow the mounting of 6.5” speakers. Alternatively you can use 9mm MDF and use some rubber under the front edge to give it some backwards angle (which is desirable) Even a few degrees can make a big difference
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Originally Posted by rednose View Post
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
