One of the headlamp bulbs has blown and the manual says, "Have Xenon bulbs changed by trained technician. There is risk of electric shock."
How do I know if I have Xenon bulbs? 2008 Zetec.
~ Zetec Hatch in Thunder owned since bought new in 2008 ~ |
Giddy up!
In Europe they have to have washers installed in the front bumper. they pop up and clean them or something.
I think they only came with the Titanium MB. i reckon an auto-elec could tell you, so could a mechanic. Or Supercheap to get the bulb and do it yourself.
Current: June 11 built Titanium TDCi Territory, Edge, side steps, mud spats, bonnet protector, tow pack, full tint. Nov 10 built XR6 Sensation. Previous: Oct 07 built Mondeo TDCi hatch, Stardust Silver, bluetooth, leather, tow pack, sunroof. |
#3 | |||
apstar |
If You Seek AU
I have a feeling that only the XR5 had Xenons. Your Zetec should be safe.
Cheers.
************************ 2013 Kuga Trend TDCi, Burnished Glow My dashcam/travel YouTube channel: https://www.youtube.com/channel/UC5x..._OYiDekVUlmEhg |
Thanks, folks.
Cheers, Ron.
Tippy-tronic Free Zone
Yep only MB XR5 had Xenons....a plus in my car buying decision (XR5 Vs Mazda6 Lux Sports). Really nice being *behind* those lights.
It's really hard to follow the directions on the manual to replace the bulb. It's got be one of the cheapest and shoddiest car manuals I've ever seen. The pages look photocopied and the pics are dark and blurry.
I hope they've improved this in the later models.
Finally replaced the low beam bulb (yes, I know I'm slack but it's that time of the year).
It's a job I wouldn't want to do too often as it was the most complicated bulb replacement I've ever seen. First you have to remove a screw holding the grill onto the body frame. This is a cheap plastic screw and just would not unscrew: I had to force it out it by levering it. I checked the other side and it was the same. Then you have to remove two screws holding the complete headlamp assembly. By gently bending the grille you have to remove that whole assembly from the side body panel. Then remove the backing plate from the assembly, and pull out the bulb holder. Putting that bulb holder back in took over 30": it just wouldn't clip in. ![]() Trying to get the whole light assembly back in while twisting the grille wasn't fun either. It took over two hours to do the job. ![]() Whatever happened the simple bulb replacement of earlier days?
Giddy up!
Sealed beams are long gone, unfortunately.
When I last had a headlight blow on me (BA Futura), I looked and said 'too hard' and took it to an auto elec. About half an hour later all done, and I was about $50 worse off. For me, it was money well spent.
I have two +50 bulbs that I bought from the UK over a year ago. Haven't had the courage to install them yet...
The opposite side low beam blew on Friday. A bit quicker this time after the first experience: only took an hour.
![]() Once again I had to cut off that plastic screw holding the grill onto the main assembly. There just doesn't seem to be any other way to get it out. They don't make bulbs like they used to. My 2000 Laser has only ever had one bulb replaced: left front parking light. (Now that I've written they'll all blow at once this week. ;) ).
#12 | ||
I have managed to replace both sides of mine without touching the grill, its a bit tight and a bit fiddly but its doable and only takes about 15 minutes. Your right about modern globes, just don't make em like they used to.
