Adams Polishes
Old 18-10-2009, 04:50 PM   #1
Jack91
Jack91's Avatar
Default DAVO_XR6's AIRBOX MOD
Well, I was pretty bored today so thought Id get around to modifying the original airbox in the car. When I had the car dyno'd I was told that just by adding another inlet pipe people are getting a 5kw gain, so thought stuff it why not. So, headed down to the local hardware store, they didnt have what i wanted (wanted one of those bits that goes on the end of a downpipe) so settled for this instead:
Its just a square to circle thingo, I presume for some sort of guttering application. That and the piece of pipe that fits snug inside cost me a whopping $3.50, as I got the offcut for free.
Airbox out:
Hole cut:
Why dont I ever bloody measure stuff?:
No match for black silicone, and some black paint:
Some of you will see a big boo boo here:
I put it to far up, and the air filter wouldnt fit in, though, with just a bit of force I got joy and the top went back on perfectly;
Im a bit peeved that I couldnt get to the bottom bolt to do it up but it is bloody sturdy so I suppose its ok. Also very annoyed that once the bottom bit was back in one of the clips came out, Ill take the box out next weekend and clip that one back on, pain in the ***.
Result:
Oh yeah and I got a bit wild with the stanley knife so did my own version of the widemouth ticky snorkel:
Needs paint, Ill do that another time, as it was starting to rain.
All up, for $3.50, im stoked with the gains, fuel consumption is definately better and theres an awesome noise at WOT, along with a lot more action down low. Very worthwhile mod for an hours work.
--Dave
Jack91 is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2009, 05:18 PM   #2
Beer Baron
Not a bad idea mate. What about a pod filter inside the air box instead of your panel filter ?
AU XLS.
Beer Baron is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2009, 05:30 PM   #3
Jack91
Jack91's Avatar
As far as I know they dont fit at all insiude the AU boxes, I remember putting one in the box of my EF, but there was a lot of bending, force and swearing. The K&N panel filter in there now does a good enough job anyway I think.
Old 18-10-2009, 05:32 PM   #4
Jack91
Jack91's Avatar
And I guess that if I was going to buy a $120 K&N pod filter I would've got the fiberglass out and done it properly. This is a cheap fix I suppose for bored people who want a bit more action.
Old 18-10-2009, 06:14 PM   #5
Erich
Davo
Done the same with my I6 S3 AU - I recon for the price its great
Erich is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2009, 06:23 PM   #6
Jack91
Jack91's Avatar
Yeah im very impressed too. Recommend anyone to do it
Old 18-10-2009, 06:29 PM   #7
GS608
the lower typhoon style intake would really only benefit the XR's i assume?
not much cold air getting in behind the triangle lights
GS608 is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2009, 06:31 PM   #8
frd906
im mounting mine in my box with the pod, not hard to do bends pretty easy
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2009, 06:35 PM   #9
xrford
WAGONE
xrford's Avatar
did you notice if it went better at all? might try knock up something similar.
xrford is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2009, 07:03 PM   #10
Jack91
Jack91's Avatar
Definately did go better, I think you're right xr-chief the xr's have more air flow but I think it would benefit a non-xr front aswell.
Old 18-10-2009, 08:26 PM   #11
Mont5.0
Mont5.0's Avatar
The "widemouth" snorkels tube Body is wider not just the opening.
FGII XR6 IN LIGHTNING STRIKE
R52 SIII IN GUN METALLIC
Mont5.0 is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2009, 09:09 PM   #12
Jack91
Jack91's Avatar
Yeah I know but I thought id give it as much help as I could.
Old 18-10-2009, 10:40 PM   #13
White_sr_taxi
lol love the mod to the snorkle lol but the air box is nice and neat ill do the piping on mine one day too lol
White_sr_taxi is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2009, 11:21 PM   #14
Peuty
Afterburner + skids =
Peuty's Avatar
Mine fits in no dramas.
Oo\===/oO
Old 18-10-2009, 11:32 PM   #15
ronwest
All Bran = Regular Member
You can do it this way without the silicone - except for the mismeasure
....and you can get at the bottom bolt...
http://www.fordforums.com.au/showthread.php?t=11262681
ronwest is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2009, 11:44 PM   #16
Jack91
Jack91's Avatar
Wasnt really a mis measure, more as if I had a 15mm drill bit in the drill going at full speed with the button holding the trigger on trying to use it to cut in a circle, which Im sure we've all done, and the outcome was pretty dodgy. I dont mind that one there but I prefer mine to come out closer to the headlight. You cant tell its a bit messy underneath anyway. And Im not too concerned about that bolt, the snorkel adds the extra support for it.
Old 19-10-2009, 12:00 AM   #17
ronwest
Sure, nothing wrong with yours. At least you're not sitting on your hands wondering
For others considering it, you wanted it closer to the headlight (on mine that is) it's only a matter of making the cut a bit longer on the 90mm front pipe.
Old 19-10-2009, 02:45 AM   #18
ronwest
Actually, that won't work on mine.
It's the mesh cap that holds it in place so if the pipe was longer it would just flop about (said the actress to the Bishop).
I guess the way to overcome that would be to cut a piece of 90mm poly pipe joiner and slide it over the existing pipe to hold it in place against the airbox.
(Not meaning to hijack your thread Davo but I think that the info should be as accurate as poss for those reading and maybe contemplating using it)
