Shockworks
Old 04-02-2009, 03:23 PM   #1
TTXF
TTXF's Avatar
Default error code 32?
After starting the car (AU1) the airbag light flashes 3 times then 2 times, does this several times and then just stays on. I've tried searching and from what I found this would mean error code 32? Driver airbag circuit open? Is this right?
I've checked the fuses and they are fine, Is there anything else I can check?
Cheers....
TTXF is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2009, 09:06 PM   #2
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
If everything else looks ok my guess would be the clock spring in the steering column. It happened to my wagon so I just went to a wrecker and picked up a replacement and fitted it myself. Hardest part about the job was finding someone with the correct 5 sided torx bit to get the airbag off. Once that was done it was a breeze.
Bushbasher
MINE- AUII Forte
Old 04-02-2009, 09:09 PM   #3
NC1183
NC1183's Avatar
Check, pull apart and clean all connections under the seats.
Nathan
2005 FPV BF Super Pursuit
The new toy (now sold)
The SP
The old ute (sold)
www.aufalcon.com/nc1183
Build Thread
Originally Posted by F6T
If you look closely you can see the remains of a Hyundai excel that’s been sucked into the intake.
about the pic of 'CHOP YA' F6
NC1183 is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2009, 09:19 PM   #4
TTXF
TTXF's Avatar
Bushbasher
That might explain why the horn doesn't work as well. I've changed one in a XH ute before but it didn't have an airbag.
I will check the connections tomorrow...
