Hey guys, I'm lowering my Series II Fairmont with Kings Superlows and Shortend shocks, I'll Have 18's on it when i get it done but is there anything else i will need to do?? eg. Camber kit?
Thanks for the help John |
![]() Join Date: Nov 2007
i went superlows with 18" on my mont. No castor kit required here.
FGII XR6 IN LIGHTNING STRIKE R52 SIII IN GUN METALLIC |
#3 | |||
#4 | |||
Back to Le Frenchy
Mines on Sl's all round and I didn't need a camber kit, however there is only one bloke I know that can actually get the alignment right without one. Most places say I need one.
I also have caught a guard with 245/40/18's on the front and I have to be careful with the 245/35/19's I have now, getting the front guards rolled might be an idea.
Critical Thinker
NYTEYZ - I am assuming you dont have IRS rear end. Do you have any pics of your car?
I am also interested in have a similar setup like yours with same diameter wheel.
"Everybody was KungFu fighting..." 2022 Mazda CX5 GTSP Turbo 2024 Ford Everest Trend 1967 Ford XR FALCON 500 Cars previously owned: 2018 Hyundai Santa Fe Highlander 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
#6 | |||
Audi S3
Critical Thinker
thanks henry
Same story here, I've got King Superlow with shortened shocks and haven't needed any camber kits. I've had 17, 18 and 19" wheels on there without a drama. If you want to see how it sits check out my build thread, there's plenty of photos in there. I haven't had any problems with scraping at all either, except when there's a couple of big blokes in the back (and even then it's just mudguards). Cheers.
Critical Thinker
thats good to know matt. thanks.
Sorry to steal ya thread John
not here much anymore
I on the other hand will put my hand up and say that I would not lower a car without putting a camber kit on. I have one on the XR8 and it is the best thing about the entire suspension setup.
2024 F150 XLT
#11 | |||
To all he others thanks for the help, I'll have some picks up in a few days after i get the wheels and then after the suspension is done. |
Critical Thinker
look forward to seeing the pics. ;)
#13 | |||
Isn't the main purpose of a camber kit to allow for more adjustment if the 'stock' set-up doesn't go far enough to align the wheels satisfactorily? Therefore if it can be adjusted enough, you don't need one, so what would you gain by putting one on? My understanding is that the main benefit of adding a camber kit is preventing the tyres from scrubbing out on the inside edge, but handling would actually be better in this set-up, with better turn-in. So it's a balance between tyre wear and handling. So in my case, adjustment was adequate and tyre wear is satisfactory, so would I benefit from adding a camber kit? Is this a fair assessment? Please correct me if I'm wrong. |
#14 | ||
MADED.6
usualy with a bit of camber u get alot of tram lining as in the car follows lines in the road and will pull a bit but if u dont have that and ur not chewing tyres the it will be fine.
mine with my special springs in it has 2 degree negative camber at all 4 corners and with anything other than stockies tram lines all over the place. but i will be getting springs shocks and camber kits soon. cheers josh.
TUFAU-8 Get Stroked. AU Stroked 5.6L GHIA |
#15 | ||||
Back to Le Frenchy
#16 | ||
Critical Thinker
I was in 2 minds as to whether I need this or not. But I reckon I'll get the camber kit only if the car needs it.
#17 | |||
On another note i finally found someone to fit the suspension this week. ![]() I rang TTF in sunshine and they could do it until i told them the springs were off another car. TTF: Do we need to order the springs and shocks for you or have already got them? ME: I already have them, Springs have about 1000km on them, shocks are new. TTF: sorry we don't install secondhand parts. ME: What?? TTF: we don't install second hand parts. ME: *hangs up phone* |
#18 | ||
clean the springs up (1000k old shouldn't be that dirty) wrap em in pairs in glad wrap, take em there say thats how you bought them.
#19 | |||
#20 | ||
Critical Thinker
I think the reason why they dont like second hands parts is:
a) they dont make any money on them b) they dont warranty the 2nd hand parts c) they may have had issues in the past with fitting second hand materials. Wouldnt let that worry you. Try somewhere else. Any mechanic can do it, it doesnt have to be a wheel mob.
#21 | ||
I've a suspension mob in brooklyn doing it tomorrow for $140 all up.
#22 | |||
Back to Le Frenchy
The problem is you called TTF Sunshine. They are absolute morons there, I nearly got into a fist fight with the manager there because he tried to tell me it was my fault they put the wrong tyres on my car. All I did was go there to swap the Bridgestone GridII's that I had put on at Cheltenham TTF (I had asked for and paid for GIII's) and the bloke at Sunshine said he had a set (Cheltenham organized it). Got there and he tried to put Grid II's on it, then said he was doing me a favour and that I should take them and shut my mouth before he shut it for me.
Sunshine TTF is bad.
#23 | |||
Critical Thinker
thats is shocking beahviour. Terrible business practice. Thats sad to see. John - thats god to see you have found another place. $140 fitted isnt bad. Does that include a wheel align after?
#24 | ||
No wheel align with the price, extra $20 which i'll get done
#25 | ||
Critical Thinker
thats cheap for a wheel align. Is that with the same place?
#26 | |||
2024 F150 XLT
