Old 29-09-2008, 03:01 PM   #1
wezza1
Default Central Locking
Hi,
My battery died on my remote for my 2004 Fiesta Zetec. I got the battery replaced, but now the buttons arent working. Is there some way i can fix this from home? As i called my ford dealers and they said it will cost $150 'to hook up to the laptop' and a big 2 hour job. I'm sure they are full of it.
wezza1 is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2008, 11:32 AM   #2
Kariharnett
Lil Henry
Kariharnett's Avatar
dont know if this will work but give it a whirl.
1. Obtain all keys 2. Turn Ignition switch to position 1 3. Wait 10 seconds 4. Ensure clock LED illuminates (for approx 5 seconds) 5. Remove igniton key whilst LED illuminated. 6. Programming mode now enabled for approx 20 seconds proceed as below
a,Point key at receiver, (located near interior lamp) b, press and hold UNLOCK button, after 1 second key LED will flash once c, press LOCK button 3-5 times d, release UNLOCK button e, keep key pointed at receiver until LEDs in clock and key have flashed 5 times
Repeat above within 20 secs to program remaining keys
To exit programming mode, switch ignition ON and OFF and wait approx 20 secs.
Kariharnett is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2008, 01:10 PM   #3
Twinpiston
Finally rollin on 20's
Twinpiston's Avatar
wow, that sounds insane!!! Where did you find that?
Fiesta ST..... Colorado Red...... SOLD
Territory Turbo Ghia ..... Winter White
SOLD - Good bye my little buddy!!!!
K&N, F6 Snorkel, Debung, 20" Enix Turbine in Gunmetal, 7 seat rear springs.
Twinpiston is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2008, 01:26 PM   #4
Kariharnett
Lil Henry
google of course. i dont know if it will work i think it comes off a older model fiesta as aussie ones dont have a led in the key. but it is worth a go
Old 30-09-2008, 01:56 PM   #5
wezza1
Thanks guys, i'll give it a whirl tonight
Old 30-09-2008, 08:33 PM   #6
Kariharnett
Lil Henry
Ok it has come to my attn that that was for an ifrared 2 button remote.
my bad, This is for a Fiesta 3 botton W1 key apperently
(Radio 3 Button) - Key Remote Programming
1. Insert Key and turn to II, then Turn Key from II to I and back to II four times within 3 seconds
2. The PATS LED should light. Turn Key to Position 0.
3. Press the Unlock button and keep it pressed until the PATS LED flashes 4 times.
4. Add additional fobs the same way. Turn to II and back to 0 to end
Old 30-09-2008, 08:48 PM   #7
Kariharnett
Lil Henry
I have also looked it up in thee owners manual but that only explains how to code the Keys. not the Keypad.
Old 06-10-2008, 11:31 AM   #8
wezza1
Thanks guys, i finally got it working.
I tried the ignition trick and it didn't seem to work for me, but then i pointed the fob at the rear vision mirror and held lock/unlock and it seemed to work. Doing that also switched inbetween different lock cycles (one press driver door, 2 press all doors).
Thanks for the help, so much for $200 , a big job and hooking it up to a laptop! (thanks ford dealers lol).
