Shockworks
Old 24-03-2008, 02:18 PM   #1
Rangas GTP
Default First run at WSID
Had my first run ever at WSID on the 12/3/08. Total of 3 runs and the 1st run being my best time of 13.931 @ 100.55 MPH. 2nd run 14.8 and 3rd run 14.5. Car is BFII GT auto with Herrod headers, Hitech exhaust, Bluepower CAI and Bluepower tune. All runs in manual mode. 1st run i just planted the gas and shifted, the other runs i stalled it up but it just seemed to bog down. Car in full street trim.
What is the best way to launch these things?
Im also looking at purchasing MT ETs, but i am not quite sure what size rims. Whats the ideal setup seeing that BFs have 19in? Last question I promise. Best place in Sydney to have 3.9 gears fitted?
Sorry for all the questions but I gave up the smokes and it seems true that when you loose an addiction you pick up a new one.
Time Slip
Air Temp C. 27
Rel Humidity 0
Abs. Barometer 30.00
Track Temp C. 42
R/T......146
60'.......2.204
330'......6.019
660.......9.069
mph.......80.58
1000......11.696
ET.........13.931
MPH.......100.55
K/mh......161.83
Cheers for any feedback
Rangas GTP is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2008, 11:17 PM   #2
DBL15
love being blown
DBL15's Avatar
all the BA and BF that i know that use M/T's run standard 17inch rim with 275 wide mt's on it
they will fit over most rear brakes that i have seen
good luck and its quite fun going down the 1/4 isn't it
6 speed auto? i would have thought you would get a bit better 60 foot time but as you say launch is the problem
stall it up to 2200rpm then stand on it of the line make sure your right in the sticky tyre marks the other cars have left as well that might help
GT-P 2003 + XR8 Supercharged Ute 260+ BOSS : : :sm_headba :
New PB 12.4 @ 108mph : :
www.xrclub.com.au
DBL15 is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2008, 01:52 AM   #3
Falc'man
You dig, we stick!
Falc'man's Avatar
Hmmm pretty good for a first run. When you say "it bogged down" do you mean it felt like it was restricted in power, or did it spin the rears?
Also, you currently have 2.73 diff gears so changing to 3.9's is over the top (too short).
By the look of it the WSID haven't been giving any readings for the humidity lately. I was there a few weeks ago and the reading was zero for all the runs.
"....You don't put the car through engineering" - Rod Barrett.
Falc'man is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2008, 04:48 AM   #4
XR8-260
A 2.2 sec 60ft is an okay launch. With those mods you should really be trapping higher speeds than that though. How many km has your car done?
XR8-260 is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2008, 02:48 PM   #5
Stav
Smile
Stav's Avatar
Is 100mph the best mph of the night? I think its is similar to stock gtp's. . In winter it should do better though with a few improvements.
100mph indicates around 200rwkws for that run.
Smithfield diff and gears did my diff.It works really well and I do reccomend them.
Stingray Car Security ph 0414445444
Single din radio fascias for fg to fgx fords Australia wide .
FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/
Site Sponsor See Sponsor Stingray Car Security 😍👌✌
AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again
Old 25-03-2008, 04:21 PM   #6
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
By "bog down" I think he means it sorta hangs in the revs for the first 60 odd feet, it just doesn't feel like it's going anywhere then it comes on.
My XR6 does this, I managed to overcome it for two runs but have never got it to do it again.
Carless
TheSneakiness is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2008, 06:37 PM   #7
Quadcams
Quadcams's Avatar
Location: Working, chasing after my daughter and working
Time Slip
Air Temp C. 27
Rel Humidity 0
Track Temp C. 42
R/T......146
60'.......2.204
330'......6.019
660.......9.069
mph.......80.58
1000......11.696
ET.........13.931
MPH.......100.55
K/mh......161.83
Mate for the mods your mph is down a fair bit should be around 106-109mph something not right there.
With diff gears your best bet would be to go 3.23's as with the 6sp auto they are 2.73 from factory, a friend with a BF XR8 went to 3.23 and went really well with the ZF 6ps box, did a 12.85@109 with hedders/tune/cai and on street tyres (dunlop sp3000). If you go MT street you will go slower with out a bigger stall convertor but you cant do as they havnt released the software for the ZF box and tuners arnt able adjust the box to suite the stall, if you still want to get some Rocket Indristries is your best bet, you can run the 275/50/17 and get yourself some 17" alloy rims to put them on.
Another thing is your 60ft, you should be able to get it down around the 2.0 mark which will improve your time by about 4 tenths at least, but carfull not to stall the ZF box up to much as they dont like it and can go into limphome mode.
A good place I know of to install the diff gears is KCDR drivetrain 02 96797747 speak to glen or another is Craft diffs they also are very good too.
And if you have a Bluepower tune your best bet is to have a chat to Chris, the best guy around to help you out with tips at the strip.
I'll be heading out tomorrow night if the weathers good, should come out for a run and say hellow.
Quadcams is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2008, 10:04 PM   #8
Bossxr8
Peter Car
Bossxr8's Avatar
I ran 100mph is an auto BA XR8 with just a CAI, you should be going a fair bit quicker than that being a 290 with those mods.
Old 26-03-2008, 12:29 AM   #9
Rangas GTP
Thanks for the feedback guys. I also expected a much better time with the current mods. Maybe to early as its only got 6000 klm on the clock. Also first time ever for me on a strip so the adrenalin was peaking. A few more visits will hopefully sort that out.
By Bogging down I was referring to stalling it up on take off, it just seemed to loose power, but after reading Wades post I think he was spot on with limp home mode. Thats a new one for me, should of been looking at the tacho. At what revs on stalling it up would you expect it to go into limp mode?
Wade I cant get out their tomorrow but possibly the following week. Im keen on throwing you the keys, GRIN GRIN (again). It would be great to have someone with experience give it a go.
Hopefully by the end of this week I will have the car dynoed for the first time. Very curiuos to see results. Anyone willing to have a stab with current mods of rwk? I will post results. Its a BF II 290kw.
Old 26-03-2008, 12:36 AM   #10
XR8-260
Don't worry about stalling it up or self shifting. Just step off the brake pedal and mash the accelerator and let the auto do the work. My best time was achieved without stalling it up and using D-perf mode.
Old 26-03-2008, 12:47 AM   #11
Rangas GTP
Thanks 3. Only had 3 runs on the night and as yet have not tried in D-perf mode, next visit will definately give it a go. Hopefully get more runs in as well.
Old 26-03-2008, 03:44 PM   #12
Quadcams
Quadcams's Avatar
Thanks for the offer mate but Im a manual man lol, the best auto driver in sydney is Rich (Hot460), he's the one I mentioned that had the BF XR8 6sp auto, he can really drive those ZF box's well, havent heared of many that have done better 60ft with that box,only big powered F6's have done better. definately the one to speak to.
Old 28-03-2008, 01:31 PM   #13
CV PERFORMANCE
We have our customers Boss powered cars running consistant 1.8/1.9 60ft and best of a 1.68 60ft,last week a customer in his BF GT on street Dunlop's run a 13.3 with a 2.0 60ft with just exhaust and tune,once he get's the hang of it he should see his times and 60ft fall
CV PERFORMANCE
Performance and Drag racing specialist and only shop in AUST to have 8 10 sec BA/BF's
Home of Australia's quickest turbo powered car 6.7@210, fastest LS1 auto in the world 7.0@207
CV PERFORMANCE is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2008, 07:24 PM   #14
Quadcams
Quadcams's Avatar
CV PERFORMANCE
Yeh thats about ball park and of corse depending on what setup there running, seeing you cant run any stalls yet.
Seen a BF XR8 ZF6sp do a 13.0@109 2.0 60ft with only hedders and tune, becoming pretty common with the BF range.
Old 28-03-2008, 10:05 PM   #15
hot460
From what I have found its best to stall the zf between 1200 and 1400rpm. Also in both my utes with zf's only went into limp mode during the burnout when mashing the peddle to fast.
XA Coupe 545cub N/A 10.17@136.70 BP ultimate.
hot460 is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2008, 10:13 PM   #16
hot460
The times will come, just takes some practice. Just curious if you have had Chris(Bluepower) do a custom tune on your car or is it a generic tune?
Old 28-03-2008, 10:21 PM   #17
Rangas GTP
Had the Gt on the dyno today, ran 249.5 rwkw on Bluepower tune. Car then retuned on dyno and now producing 257.7 rwkw. On driving home noticed car not to be as responsive as original tune but does seem to have more down low. I will leave this tune in for a few days and see how it goes, but for the 8kw gain in tune I prefer the Bluepower tune, its just so more aggresive and responsive. Looks like a trip to Victoria on the cards soon.
Old 28-03-2008, 10:51 PM   #18
hot460
Trust me, The trip to vic is well worth the drive. Chris(Bluepower) has done my last 3 Ba-Bf's XR8 utes! And dont get caught up on DYNO figures, 230rwkws got my ute doin 12.8 and 266rwkws with the little pd 12.1.
I have also done over 200,000klms in 2 Bluepower tuned BF XR8's one of which has done 100'000klms with a blower on the car with NO dramas at all!!!! : well apart from the tailshafts from me always getting a little heavy footed when the car has 3-500kgs of pool stuff in it. LOL
Old 28-03-2008, 11:16 PM   #19
Rangas GTP
Thanks hot460. Currently running Bluepower generic tune and honestly cant wait for custome tune. Have a job to do shortly in Portland VIC, I usually fly down but will definately drive down this time. Need to get more Ks up so this will do nicely.
Hey Rich what diff ratio would you reccomend. I had sort of settled for 3.7 or 3.9s but everyones opinions seem to differ. Im not fussed on economy.
Quadcams, I wonder if this thing was in the 11s would you knock it back even for an auto?
Old 28-03-2008, 11:21 PM   #20
hot460
3.23's or 3.4's. makes a big difference! Depends on how much you drive. I went 3.2's because of the klm's I do.
Old 28-03-2008, 11:38 PM   #21
Rangas GTP
Ok 3.4's then it is. Hopefully have them installed next week and out to WSID the following week. If your our there on the day Rich maybe you can show me how its done.
Cheers.
Old 29-03-2008, 11:04 AM   #22
hot460
Cheers.
I'll be out there running my coupe if the trans sorted in time. :
And if you change your diff gears you will need some sticky rubber for sure.
Old 29-03-2008, 12:58 PM   #23
Quadcams
Quadcams's Avatar
Baaah..... Auto's are boring as bat s#*t. Luv me manual. :eclipsee_
Old 29-03-2008, 02:28 PM   #24
PhantomXR8
Now a FG XR8 in Nitro
PhantomXR8's Avatar
Talking
Mate, I'm thinking of going there this Wednesday. My BF XR8 auto with only an airbox got a 13.7@104 with a 2.0 60', there has to more in your boy! Try the stock tune, just tramp the accelerator in sports auto, forget stalling for now, then work forward.......
Nitro XR8 6 Speed Manual - SS Inductions Growler, Herrod Headers John Bowe exhaust 0-60kph 2.46 secs
PhantomXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2008, 05:03 PM   #25
PhantomXR8
PhantomXR8's Avatar
Time Slip
Air Temp C. 27
Rel Humidity 0
Track Temp C. 42
R/T......146
60'.......2.204
330'......6.019
660.......9.069
mph.......80.58
1000......11.696
ET.........13.931
MPH.......100.55
K/mh......161.83
As Wade said, 3.23 gears are the best. I've got a set of these lying around the garage somewhere, they come off my old BA with about 50,000km on them.
