01-12-2007, 11:28 AM | #1 | ||
just found another problem to go with the others, water dripping on my foot during heavy rain. anyone else have this problem? im just curious where it comes from....is it from a leaking front windscree or does it some how come down through the fire wall where the wiper arms attach..
01-12-2007, 11:31 AM | #2 | ||
Leave blocking the cowl channels; open bonnet and remove leaves from corner of the opening nera the doors.
regards Blue |
01-12-2007, 11:41 AM | #3 | ||
i cleaned it out and still dripping
01-12-2007, 11:42 AM | #4 | ||
could possibly be the rubber grommets where the engine bay wiring comes through the firewall into the cabin? maybe one came out
Everything always works out when you just do whatever you want and don't worry about the consequences. see my ute here AU parts for sale |
01-12-2007, 06:28 PM | #5 | |||
I got the same problem. Its not my windscreen, found that out the expensive way, but a mechanic mate a ford, told me run water down the windscreen while looking in the car and u might find it, thinks it could be the gromemt that goes around the brake shaft.
Nathan 2005 FPV BF Super Pursuit The new toy (now sold) The SP The old ute (sold) www.aufalcon.com/nc1183 Build Thread Quote:
01-12-2007, 06:32 PM | #6 | ||
Its Resonating!
Isnt it something do with the clutch pedal (cracked firewall)??
01-12-2007, 06:46 PM | #7 | |||
Yeah, thats another possiblity, but i couldn't see or feel any cracks in my firewall
01-12-2007, 07:30 PM | #8 | ||
Formerly MR BAXR6t
i also got the same problem. seems to be coming from somewhere near the steering column, and it leaking on wires!!
Im not sure what i can do bout it either
Current car 94 ED Fairmont 5L in Burgundy Fords ive owned- 2010 FG XR6 5 speed auto in Mystic 81 XD S-Pac 302c 4sp manual 78 Yellow TE Cortina Wagon 4.1L 92 Green EB Fairmont GT replica 01 Black AU XR8 II Manual 04 Rapid BAII XR6T 220rwkw 04 Mandarin BA XR6T 247rwkw 07 BF II XR6T 385rwkw 1980 ZJ Fairlane 302c |
01-12-2007, 11:42 PM | #9 | ||
Get the hose into those cowl corners and you may flush out some leaves and fix the leak or at worse find another source.
regards Blue |
02-12-2007, 02:04 AM | #10 | ||
funny you should mention that mine started doing the same thing a couple of weeks ago .....drips on my right foot but i think it is a windscreen weather strip problem on mine i notice the seal has a crack in it and some of the other seals are starting to show some sun damage :(
04-12-2007, 07:55 PM | #11 | ||
Mine has been doing it for ages, happens more so when turning during the wet, or straight after giving it a wash... Im kinda used to it, and have gotten used to remembering to move my feet in time!!!
04-12-2007, 08:05 PM | #12 | ||
mine too, alway drip on my clutch P!ss me off so much!!
Many Thanks 2001 AUII Factory LPG Manual XL Styleside Box High series bonnet Clear Side Indicator K&N Air Filter BAXR6T Snorkle Low Fronts, Super Low Leafs |
04-12-2007, 08:25 PM | #13 | ||
I'm assuming everyone who has this issue drives a manual? Thus the water dripping issue has something to do with the shithouse strength of the EA-AU firewall?
Anyway, i've recently had my pedal box replaced and firewall repaired (today actually, like driving a new car now ), i'll let you know if I still get a wet foot when (if?) it next rains. Or i might go wash my car later in the week and test it out. ;)
Me fail English? That's unpossible.
10-12-2007, 09:55 PM | #14 | ||
did repairing the firewall happen to fix the leaks?
where would the best place to go get it repaired (panel beater)...i suppose |
10-12-2007, 11:16 PM | #15 | ||
Right out sideways
my sedan (auto) no problem, my ute (manual) drippin like a mofo
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302 |
10-12-2007, 11:38 PM | #16 | ||
GT-P #0336
2003 FULLY OPTIONED MERCURY SILVER BA GT-P BUILD #336
REVERSE CAMERA - SAT NAV - PIONEER SUB & AMP - SUNROOF - DVD PLAYER - CUSTOM DUAL EXHAUST ~Tuned By Bluepower Racing~ |
11-12-2007, 10:52 AM | #17 | ||
Cracked peddalbox/firewall.. common problem, EVERY manual will do it at some point or another.
of a job, but yes it does fix the leak. |
14-12-2007, 11:25 AM | #18 | ||
Power & Torque
Refer to my post (& threads) AU falcon - "GXR: Water leaking drivers side front"
This reply I made today: Hi Guys Well I picked up my car from my panel beater yesterday. (NOTE: He said to find the source of the water leak, DO NOT USE A HOSE. To isloate the location of a water leak he said use a watering can. Have a person looking under the dash while you pour water. Start low, ie. plenum chamber, then work up the side of the windscreen very, very slowly. When it starts to leak, this is the level (area) where water enters your car). Anyway: My windscreen & seal were OK. A grommet in the firewall was not fitted properly due to someone previously stuffing around. He siliconed this. This was not the cause of my leak. The cause of my leak was the plenum chamber. He explained to me the plenum chamber sits under the wiper assembly catching all the water from the windscreen (like a gutter on a roof). The brake & clutch bracket are spot welded to the underside of the plenum chamber. 3 out of the 4 spot welds are broken. He has siliconed this to stop the leak. As it is a structural problem it needs to be welded. Fortunately my car is just in warranty and the dealer I purchased my car from has OK they will fix (?MIG weld) this under warranty. They have acknowledged this is a know problem with AU Falcons. This should then be a long term fix. Again thanks for your input, you guys were right. |
15-12-2007, 12:03 AM | #19 | ||
it appears mine was the windscreen no more leaks so far.............cross the fingers
