Shockworks
Old 08-12-2007, 04:47 AM   #1
Falcon87
Falcon Unbelievable
Falcon87's Avatar
Default Doe's my 99 AUI Forte have an imboliser?
Im not sure if it doe's or doesn't as there is no flashing light on my dash...
Falcon87 is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2007, 09:40 AM   #2
sly
Sly like a G6
sly's Avatar
Maybe the light's blown, I thought the flashing light when locked went back to when Smartlock was first fitted.... EA or EB????
Does your car have front power windows? These were made standard when the security system was changed from Smartlock to Smartshield. If you have 'em, check the build date on the compliance plate. Smartshield after May.
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring.
Sleeper, anyone?
sly is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2007, 12:17 PM   #3
JC
JC's Avatar
All falcons from EB2 onwards that have smartlock or smartshield have a factory immobiliser.
With all the work you've been doing on yours, have you changed the ECU or BEM at all? If you have, then you need to get them coded together by ford, or the car won't start.
Have you checked the fuse panel to the right of the steering column? You could've blown the smartlock/BEM fuse.
Mods: Tune, ShockWorks, GTE 19” - 8” & 9” with 245 & 275/35/19 Michelin Pilot sport 5s
Daily: SZ Territory RWD 6R80, 20 x 8.5” rims 19” with 245s and Gabriel shocks & SSL King springs
Ford Performance Club ACT
Old 08-12-2007, 01:32 PM   #4
Falcon87
Falcon Unbelievable
Falcon87's Avatar
What's the BEM? Excuse my ignornece...
Old 08-12-2007, 03:59 PM   #5
JC
JC's Avatar
Body electronics module. The ECU runs the engine (hence Engine Control Unit), the REM does all the other electrics in the car, including smartlock/shield and immobiliser and recognises the ECU that it came with - if you change one or the other, you need to get them coded together.
Old 08-12-2007, 08:11 PM   #6
sly
Sly like a G6
sly's Avatar
How about the interior light? Is it working? Apparently if it blows it can immobilise the car. A change of globe works wonders, so I'm told.
Sleeper, anyone?
Old 10-12-2007, 04:46 AM   #7
Falcon87
Falcon Unbelievable
Falcon87's Avatar
Has all been fixed now...It was a fuse in the engine bay fuse box...The fuse that had blown was the Engine Fuse....So glad i don't have to take it to Ford anymore!!!!! Saved me heaps!!!!!!!!
We just saw the fuse blown and tryed another fuse and yay it worked!!!
