Old 18-11-2007, 01:04 PM   #1
4dlvr
4dlvr
Default service intervals???
does anyone know how often you should service your car, and what you chould change/replace every certian amount of km's..
i dont have the owners manual and im not a fan of mechanics.
so if anyone can post it out it would be greatly appreciated
eg of what i want
10,000km oil, sparkplugs, oil filter
15,000km oil, oil filter
20,000km brakes, oil
etc.
thanks in advance
96 EF FAIRMONT
Garrett gt40 turbo , iceman plenum, head ported, polished and balanced, wade turbo cam, wade double valve springs, bosch 023 fuel pump, 36lb injectors high flow cat, 4' dump and 2.5' redback exhaust.
215rwkw @7psi
4dlvr is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2007, 02:14 PM   #2
FOCUSonTHIS
FOCUSonTHIS's Avatar
I change my oil and oil filter every 10,000km, then the next 10,000km I change oil, oil filter, air filter, fuel filter and spark plugs....and keep doing it in that order. Do brakes pad and discs when required.
2015 MK7 VW GOLF GTI
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
FOCUSonTHIS is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2007, 01:33 AM   #3
zetec
Zoom Zoom
zetec's Avatar
Brakes when needed, generally around 40-50,000km.
Brake Fluid every 2 years since it's hydroscopic (attracts water) and loses efficacy
Tyres rotated every 10,000km
Coolant every 4-5 years from memory
2012 Mazda3 MPS
zetec is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2007, 02:25 AM   #4
4dlvr
4dlvr
sweet, so theres not much to do in terms of servicing, no timing belts ot chains???
my ignition leads are still original ford ones and im at about 40,000km should i get redy to change them>?
also my car is running a bit rough, in terms of idleing and is develping flat spots any ideas????
ill give the leads and spark plugs a change and see if that fixes it.
change the air filter(probly not the problem but ive been wanting a k and n pannel filter for a while now.
ill check the experment tomoro morning and let use no what happens
if not il try and clean the throttle body.
96 EF FAIRMONT
215rwkw @7psi
Old 20-11-2007, 02:37 AM   #5
zetec
Zoom Zoom
zetec's Avatar
Belt is 150,000 from memory.
As for Leads and plugs, you're best just going to a Ford Dealer to buy the owners manual, that way you've got it all. You'll need the manual and the Service and Warranty guide
2012 Mazda3 MPS
Old 20-11-2007, 08:23 AM   #6
FOCUSonTHIS
There is an owners manual on ebay for $15. You might have to buy the service book from Ford.
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 20-11-2007, 10:24 AM   #7
Piotr
Non-Regular Member
For my Fiesta I just go by the book
2005 Renault Sport Megane 225
Piotr is offline   Reply With Quote Multi-Quote with this Post
Old 21-11-2007, 11:39 PM   #8
4dlvr
4dlvr
changed sparkies, and leads and it made no diffrence,
then i cleand the throttle with carby cleaner, disconnected the battery for a while to reset the ecu and it was all fixed.
funny how a tiny bit of dirt in the throttle body can make the motor go stupid
96 EF FAIRMONT
215rwkw @7psi
Old 27-11-2007, 01:38 AM   #9
zetec
Zoom Zoom
zetec's Avatar
The MAF seems to be very prone to getting dirty and running rich. I suggest you celan the exhaust pipe and see how long it takes for it to get dirty again, I reckon it'll be running a lot cleaner and leaner now and not dumping black soot.
2012 Mazda3 MPS
Old 28-11-2007, 07:47 PM   #10
4dlvr
4dlvr
ill give it a go zetec, i should done it before aswell so i could have somthing to compare to.
but since the car has been much smoother everywhere in the rev range, especially when idleing
96 EF FAIRMONT
215rwkw @7psi
