RBS
Old 27-11-2007, 09:51 AM   #1
nutter_x
Nange Road Warrior
nutter_x's Avatar
Unhappy Torque Convertor?
Hi everyone,
I've noticed lately in my series 2 XR6 that once it's been driven for half an hour or so, at any condition (ie: slowly or spirited), once I come to a standstill and have a half decent crack at the throttle the car won't boogey until 1750-2000rpm. Is it the torque convertor or does the AU transmission have a failsafe that is been tripped and if so, should a trans cooler fix this? It's a bit annoying when your at the lights and the best you can do is j-u-s-t edge out in front of Fiesta's (hanmgs head in shame) from a standstill. And FYI the transmission is in Performance mode all the time (or at least the last two thousand k's)
Thanks in advance
nutter_x is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2007, 12:39 PM   #2
Eu-GenixX
Eu-GenixX's Avatar
my AU I Futura drives a little like that... it feels absolutely dead below 2000rpm... and when it hits 2500 or so.. it seems to just wake up and think... i better get a move on now.. and it takes off... very very slow off the line... i just put it down to diff ratio and gearing... would be interested if this is not the case....
also.. the sudden surge of power seems more pronounced when at less than 100% throttle
Eu-GenixX is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2007, 01:08 PM   #3
BillC
Do you have extractors? A mate of mine had an AU ute and he went and put pacemaker extractors on and seemed to loose a lot of down low power. Anything above 2500/3000 it went like a rocket but it came with the cost of loosing down low power.
BillC is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2007, 04:14 PM   #4
nutter_x
Nange Road Warrior
nutter_x's Avatar
Yeah I have extractors fitted, but they are tuned for low down response, not top end. (tri y's)
I think it's the trans because it'll be fine for half an hour or so...then go retarded. I'm putting a cooler and shift kit on it soon, so hopefully it'll sort itself out.
Old 27-11-2007, 06:09 PM   #5
Dark Horse
_Oo===oO_
Dark Horse's Avatar
When was the last time you had the fluid in the 'box changed?
COURAGE - ENDURANCE - MATESHIP - SACRIFICE
Dark Horse is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2007, 12:20 AM   #6
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
nah , i think its the pacies , mine was good off the line before , but now takes awhile for it to wind up and move , once i see 2400 its off screaming ..
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2007, 09:37 AM   #7
nutter_x
Nange Road Warrior
nutter_x's Avatar
About a month ago...I've decided I'll make it an annual occurance now...
I'm curious about it been the extractors. If it was them, wouldn't it do it all the time, not just after half an hour or so?
Old 28-11-2007, 10:07 AM   #8
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
id assume its cos they would heat up ..
AU2PWR
