Furious Performance
Old 14-11-2007, 06:40 PM   #1
sly
Sly like a G6
sly's Avatar
Default Yet Another S1 Brake Upgrade Option, Fits E Series Too
Picked up a copy of "Street Machine Fords" Issue 13 the other day. There's a story on a front brake upgrade for EA - AU1. It's an exchange package based on modified uprights (stub axles, spindles, steering knuckles, depending on which school you went to). You fit it up and send your old uprights back to the supplier to do another kit.
The upright is modified by machining off the pad retaining lugs and enlarging the holes to fit a dog bone which carries a new caliper. Calipers used are PBR units, either VE Commodore (requires 17" wheels) or C4 Corvette which allows 16" wheels to be used. A BA caliper was tried but wouldn't fit under 17's.
It's not cheap at $1695 RRP, BUT it does include:
  • new calipers
  • new rotors
  • new pads (low-dust based on BMW compound, other options available)
  • new ADR-compliant braided lines
  • new upper and lower ball joints
  • new hubs and bearings
  • the dog bones
and only requires changing the uprights, you keep the existing lower control arms and swaybar. While a complete s/h BA setup is cheaper (anywhere between $500 to $1000), if you just bought the s/h suspension bits then added new calipers, rotors, pads, braided lines and balljoints, it wouldn't be hard to spend this much.
And of course the BA route isn't available to E-series owners AFAIK.
Apparently this kit from UPC is available through Autobarn.
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring.
Sleeper, anyone?
sly is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2007, 06:45 PM   #2
StealthAu
interesting, more to look into now
StealthAu is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2007, 07:00 PM   #3
The Monty
Just slidin'
The Monty's Avatar
Good to know someone out there is trying to look after us people with 1920 style brakes.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 14-11-2007, 07:06 PM   #4
sly
Sly like a G6
sly's Avatar
Funnily enough it wasn't a giant leap for them to develop. It's the same kit they do for saloon car racing.
Sleeper, anyone?
Old 14-11-2007, 08:50 PM   #5
GK
Walking with God
GK's Avatar
Thumbs up
Thanks for sharing that info Sly, good one!
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 14-11-2007, 08:56 PM   #6
private9
www.TUFFCARPARTS.com
private9's Avatar
I'm not sure if this is the same kit, but there's a kit recently launched that uses neither the E or A series offsets - might be something to look out for.
private9 is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2007, 09:06 PM   #7
sly
Sly like a G6
sly's Avatar
Do you mean "neither" or either? Neither would be difficult as none of the E- or A/B-series wheels would fit...
Sorry, just having a smartrrse moment... AFAIK this kit can be ordered with either E-series or A/B-series offsets, not sure if they just fit a hub to suit or supply the upright from the same model. Probably the same kit.
Sleeper, anyone?
Old 14-11-2007, 09:23 PM   #8
private9
private9's Avatar
The one I'm referring to uses neither offset IIRC. Basically the wheels will either fit something like 20mm in on an E series and like 10mm out on an A series. This is all from memory though, so I'll try and find where I read it and confirm.
Old 15-11-2007, 02:24 PM   #9
SammyDen
these sound incredibly similar to those ones with the offset problems.
SammyDen is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2007, 04:04 PM   #10
private9
private9's Avatar
That's what I was thinking too. I think the ones with the offset prob used a Mustang rotor.
Old 15-11-2007, 05:08 PM   #11
twr7cx
Member
twr7cx's Avatar
I've spoken to Tony from UPC and he has informed me that these kits do not give E-series AU-onwards offset. These only give a 20mm increase, which is not enough to equal AU-onwards offset. He says aset up providing AU-onwards offset is still underdevelopment.
You can purchase these direct from him (, or on ebay (username MR-SPARES) as well - but he doesn't seem to provide any discount for by-passing Autobarn...
His details:
UPC-Ultra Performance Components PTY LTD
Factory direct 03 9723 9924 or 9723 9961, 8.30am-5.00pm
competitionengineering@optusnet.com.au
http://stores.ebay.com.au/MR-SPARES
Current vehicles: MY12 Land Rover Discovery 4 TDV6, MY03 Land Rover Discovery 2 HSE Td5 off road modified and 1989 Mazda NA MX-5 toy car.
Previously: 1992 Ford EBII Fairmont, 1994 Ford EF Falcon XR6 supercharged, 2003 Ford BA Falcon XR6 Turbo 325rwkw, and 2002 Ford AU3 Falcon XR8 Pursuit 250 270rwkw.
twr7cx is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2007, 08:52 PM   #12
SupahStah
Tha Stah
SupahStah's Avatar
does anyone know what disks they use? if you knew that then you could make a "dog leg" out of decent thickness and strength steal and some vy calipers from holden or something else. im sure it can be done for under 1000 bucks.
i heard some were about somone running vt twin piston brakes on an e-series? anyone heard anything about this?
1998 EL XR6: |Custom POD Filter Intake, Pacemaker 4499's, Redback 2.5" Catback - straight through tail pipe.|. 113,000kms.
Best E/T: |15.080 @ 91.03mph | R/T: 0.848 | 60': 2.175 | 660': 9.674 |
Colour: |Regency Red.|.
Soon To Come: |Largish Cam + Chip|
ETA: *When the bank account is ready *
SupahStah is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2007, 10:04 PM   #13
sly
Sly like a G6
sly's Avatar
They make their own rotors. You would also need to grind off the pad lugs.
You would also need to know what you were doing, engineering-wise, so as not to weaken the uprights. This kit's dog bones are designed (ie engineered) to absorb stresses internally. It ain't as simple as hacking into a chunk of steel with an angle grinder.
Something tells me the C4 Corvette calipers are not a million miles away from the VT ones. I'm offline for most of this week, will check the PBR cattledog later, see if the C4's are listed and compare with the VT part no's.
Sleeper, anyone?
Old 29-12-2007, 05:57 PM   #14
twr7cx
Member
twr7cx's Avatar
Got an e-mail from Tony, says that the brake upgrade kits in the AU-onwards offset to suit E-series should be ready by the 8th of January.
