ASL
Old 16-02-2007, 01:21 PM   #1
J.O
Posts: n/a
Default Shaking Tail Pipe
My tail pipe is vibrating and the sound it makes is annoying! I just wanted to know where i can by a replacement for the rubber absorbers that hold it in place cus i think that may be the problem? If it isn't possible to buy one new, do the ef/el ones fit, i could pick one up from the wreckers.
Thanks.
Old 16-02-2007, 01:39 PM   #2
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Exhaust Shops , Wreckers
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2007, 01:45 PM   #3
J.O
Posts: n/a
about how much do they cost?
Old 16-02-2007, 02:18 PM   #4
Interceptor
HSV - I just ate one!
Interceptor's Avatar
couple of dollars
Interceptor is online now   Reply With Quote Multi-Quote with this Post
Old 16-02-2007, 03:27 PM   #5
Au2falcons
Winter all year round
Even auto one or auto pro will have them. They are a universal part.
Some people drive sports cars on the weekend....I drive my AU! It's not what you drive...it's how you enjoy it.
Recommend trading with Mechan1k, Offyaguts, EDMONTY, PhantomXR8, HOTC2R, Partie & JC
Au2falcons is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2007, 03:44 PM   #6
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
$3 Each
AU2PWR
Old 20-02-2007, 06:36 PM   #7
J.O
Posts: n/a
I bought the rubber mountings and fitted them, the old ones were badly worn/cracked. But the shaking still occurs periodically and there is a metal on metal ringing sound that sounds as if it is travelling the pipe. The sound doesn't happen when in park, only when put in reverse and drive (from park), reversing out of driveway and when idleing in traffic.
Help...It's really annoying!
Old 20-02-2007, 06:40 PM   #8
b2tf
not here much anymore
b2tf's Avatar
Check your gaskets, and also that the hangers arent touching inside the rubbers.
2024 F150 XLT
Old 20-02-2007, 06:46 PM   #9
J.O
Posts: n/a
I replaced the rubbers in the exactly the same way they wre originally.
Where abouts are the gaskets and what should i be looking for?
Old 20-02-2007, 07:07 PM   #10
b2tf
b2tf's Avatar
gaskets are between the exhaust manifold and the centre pipe (exhaust manifold is the bit that attaches directly to the engine), and there's also one between the centre pipe and the tailpiper (just near the rear suspension). If one's let go or broken it might be the exhaust pieces rubbing against each other.
Also check that your exhaust isnt rubbing or vibrating on anything.
2024 F150 XLT
Old 20-02-2007, 07:18 PM   #11
J.O
Posts: n/a
If i was to change the gaskets would i need to put any kind of sealant with it???
Old 20-02-2007, 07:22 PM   #12
Racecraft
they call me Tibbo
Racecraft's Avatar
is it a factory exhaust, they have a habit of changing shape , you might notice the scrapes on the underside of the tip..
If it is an aftermarket jobbie just get the local exhaust shop to heat up a few of the bends and it will pull away form the offending area..
Racecraft is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2007, 07:55 PM   #13
J.O
Posts: n/a
what do you mean by scrapes
Old 20-02-2007, 09:37 PM   #14
Au2falcons
Firstly grab you exhaust (when cold) and shake it a fair bit to see if it's making contact with something.
If the sound is a light metallic shuffle it is most likely rusted particals in a muffler or in the heat shield around the cat convertor. Best to get an exhaust place to check it out.
I had the issue with the cat convertor and it was really annoying, when the car is idle there is a shuffling noise coming from under the car. I ended up replacing the cat (the expensive option) but when I removed the old cat I peeled back the shield, the rust flakes fell out, put the shield back together and it seemed fine. When I shook it there was no noise, but I never tried it the car.
Old 20-02-2007, 09:39 PM   #15
Racecraft
they call me Tibbo
Racecraft's Avatar
look at the underside of the tip and you will see scratches where it has made contact with something
Old 21-02-2007, 04:20 PM   #16
Futura01
horsepower
mines strarting to do the same, and it's a aftermarket jobbie and i think the annoying vibrations are caused by broken brackets or rubbing on underside like racecraft has said!!!
Futura01 is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2007, 09:07 PM   #17
TwistedEL
TwistedEL's Avatar
I have this problem and I really should look at it and work out what the problem is
I suspect it's the tip rubbing against the rear bumper.
Someone has suggested to me it might be engine mounts (doubtful, but anything is possible)
Mine also does it only when in gear and only when under about 1000rpm
TwistedEL is offline   Reply With Quote Multi-Quote with this Post
