Adams Polishes
Old 16-01-2007, 11:58 PM   #1
chief
FTF Club Moderator
chief's Avatar
Default Diff gears question
When changing diff gears your speedo will be out, so how does one get around this problem. I thought the edit would be able to do it, but have heard it cant.
If I goto 3.7 gears how much will my speedo be out? This will stuff up the auto shift points as well, wouldn't it?
So to the people that have changed diff gears. How did you fix this delima? (sp?)
Albert Einstein:
Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom.
(It is more difficult to alter a preconception than split an atom)
Falcon Tickford FPV (FTF) Car Club of NSW
Fords in the Park 2010
I use and recommend Stingray Car Security.
http://www.stingraycar.com.au/
chief is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2007, 02:14 AM   #2
EvilChief
Boost Addict
i used to have 3.7s in teh rear, inc ombination with the 17/255 is was running the speeda was only 5% out which wasnt too bad.
but it was the ideal ratio choice between taking off and quater mile shifting were perfect
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build)
Ford BA XR6T Ute - daily driver
Ford FG XR6T Sedan - cruiser
do you see a general trend? I DO
Can't live with it, can't live without it!
EvilChief is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2007, 10:32 AM   #3
Stav
Smile
Stav's Avatar
The edit will fix the shiftpoints.I changed speedo cog in the gearbox to correct the problem somewhat.Ultmately a good electronic speedo corrector should do the job.There are people who can do it for a fee
Old 17-01-2007, 11:59 AM   #4
xr8ute
Back on the road
xr8ute's Avatar
Speedo corrector between the vehicle speed sensor, and the Dash. Then either the edit (to change value for diff ratio), OR another speedo corrector between the dash and the ECU to reverse the correction you made for the speedo/dash...
AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute
5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor.
Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash.
xr8ute is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2007, 03:52 PM   #5
howesy
howesy's Avatar
If you get a speedo corrector and intercept the wire as it comes away from the box then the value has changed before it goes anywhere. First you need to get a gps and work out how many K's you are out and percentage it. Mine worked out to be around 11% out after changing the diff and correcting the factory. Mine was way out now at 100kph i am doing 99 which is where i want it. I went from 3.45 to 3.08 but the principle is the same you are just going the other way. And if your not really patient and double and triple check the orientation of each piece on the board then dont build your own kit. There is one from states that does the job, bit more expensive but you can have dual settings so when you change diffs you flick a switch back to original or other setting.
http://www.superlift.com/accessories/truspeed.asp
Just one available
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2007, 10:25 PM   #6
ClassicAU
i have a 3.73 LSD and 235/45/17 tyres and my speedo is out by 6km/s at 100km/h. This was corrected from an insane 22km/h difference by a number 19 speedo gear in the transmition. I dont know if a bigger gear exists to get it closer.
ClassicAU is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2007, 10:32 PM   #7
Casper
Contributing Member
Casper's Avatar
is that the black gear?
Older, wiser, poorer.
Now in Euro-Trash. VW Coupe V6 4motion.
Casper is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2007, 10:48 PM   #8
ClassicAU
[QUOTE=Casper]is that the black gear?[/QUOTE
I honestly cannot remember what colour it is. All I know is its a number 19 as it was the largest one my mechanic had at the time. But thinking about it, for some reason red sounds more familiar, but I am still not quite sure. Sorry about that Casper.
Old 17-01-2007, 11:48 PM   #9
Sleeperau
Highway Taxi
Wink Speedo
There is a speedo calibration guide on www.fordmods.com.au. This takes into account tyre size, diff etc. Mine was exactly 10km out at 100kmph. I used the black speedo cog. Shift points are affected. A unichip can't help but as previously mentioned an edit or Chiptorque chip will fix the problem.
Close only counts in Horse Shoes & Hand Grenades. :evil_laug
Sleeperau is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2007, 11:51 PM   #10
Free347
Black is for a 3.45 as far as I can recall.
Free347 is offline   Reply With Quote Multi-Quote with this Post
