ASL
Old 08-01-2007, 12:06 PM   #1
andrew_osg
AUIII SR
andrew_osg's Avatar
Default Fuse Layout
Does anyone have a copy of the fuse layout?
or any info on what the problem could be with my Cruze control, it turns on when selected but will not activate, the 3 buttons on the steering wheel do not seem to work :
Regards
Andrew
andrew_osg is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2007, 01:31 PM   #2
Casper
Contributing Member
Casper's Avatar
check you havent blown a brake light.. its usually the reason.
Older, wiser, poorer.
Now in Euro-Trash. VW Coupe V6 4motion.
Casper is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2007, 01:54 PM   #3
andrew_osg
AUIII SR
andrew_osg's Avatar
Default Brake Lights
I have just installed LED brake lights, Could this stuff the system up?
Old 08-01-2007, 01:54 PM   #4
Casper
Contributing Member
Casper's Avatar
yup, thats the culprit.
Old 08-01-2007, 02:06 PM   #5
andrew_osg
AUIII SR
andrew_osg's Avatar
Thanks alot for your help, Ill change them back.
Old 08-01-2007, 03:24 PM   #6
Mechan1k
Mechan1k's Avatar
How easy was that ... problem solved.
No fuses were harmed in this thread. :
Old 08-01-2007, 08:27 PM   #7
StealthAu
does anyone know why led's arn't able to be used? the only thing I can think of is some sort of resistance meter linked to the brakelights
StealthAu is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2007, 08:31 PM   #8
duaned
duaned's Avatar
I would say the cruise control uses current sensing to identify when the brake pedal is depressed. Normal 12V brake bulbs, say 20W will draw 1.6A at 12V each. LED's draw only mW so they can't be detected by the BEM. Hope I'm right here!
duaned is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2007, 08:34 PM   #9
StealthAu
yeah sounds right, so bassically if you knew where to look, changing a resistor would eliminate this problem?
