10-02-2006, 07:26 PM | #1 | ||
With the advent of Fash Tune, G&D have been tuning an increasing number of Falcons.
Those of you with an AU will be well aware of the effort required for each KW gain. In the context of V8s and turbo sixes picking up 28 rwkw after a tune and mods may not seem a big deal. When you start at 119 rwkw and gain close to 28 rwkw you are approaching a 25% increase in rear wheel power. G&D started with a stock AU six. All modifcations were bolt on - the engine internals were not touched. First the exhaust went to be replaced by Pacemaker competition spec extractors and a G&D spec mandrel bent 2.5 exhaust system fitted with a high flow metal substrate catalytic convertor. The air inlet was replaced with the G&D Air Box and Intake Kit. Using Flash Tune and G&D’s tuning expertise healthy gains were made in both power and torque throughout the rpm range. If you want to book your AU in for a tune or simply want to know more about what G&D can do for your AU give Glenn or Matt a call on 5996 1813. Onscreen view to give an indication of the multiple parameters available for tuning with Flash Tune. |
10-02-2006, 07:36 PM | #2 | ||
Audi S3
im curious as to how much it would cost for what you have written above,
or just the flash tuner. with tuning (if needed. not sure of all the details on how they work) and if you guys know about what sort of stuff happens with warranties if those mod's are done (or would i be ebst off ringing ford- my car is under extended warranty)
10-02-2006, 07:57 PM | #3 | ||
Very good numbers from an XR6. Auto or manual?
Also, would have been nice to see what each mod actually did. Oh, and its coming to Heathcote next time right?
10-02-2006, 08:00 PM | #4 | |||
Audi S3
and im not to sure on how to read them, but it looks like the car has lost some down low... is that the case or am i jsut retarded :P
10-02-2006, 08:03 PM | #5 | ||
thats impressive for headers/exhaust, intake and tune..
my car has made 136.7rwkw with just cat/back system and intake.. what gains do you think there are to be had with headers and custome edit tune? |
10-02-2006, 08:04 PM | #6 | |||
Congrats and enjoy your new power.... |
10-02-2006, 08:05 PM | #7 | ||
Has to be a manual, I agree.
Hasnt lost anything down low though, its an overall increase and the real low part of the graph is irrelevant anyhow, thats major low rpms no on would drive at anyhow. The real gains are there to see up high. Mind you, at 119rwkw stock it's a hell of an engine to start with anyhow.. most XR6's dont run that stock.
10-02-2006, 08:12 PM | #8 | ||
G&D Performance Australia
It's a manual,all testing was started from a low 1500rpm.Next step will be a camshaft upgrade.Unfortunately the owner isn't a drag racer but maybe we can pursuade him _2: Looking forward to applying this formula to some BA I6's.
10-02-2006, 08:14 PM | #9 | ||
Looks like I'll have to up the power or change the diff in mine. Too many manual XR6's with good power numbers getting around at the moment.
10-02-2006, 08:17 PM | #10 | |||
Big numbers for a stockish AU (more than my ef anyway)
10-02-2006, 08:18 PM | #11 | ||
i need headers and a custom edit tune after seeing that..
10-02-2006, 08:23 PM | #12 | ||
Well done Glenn and the boys at G & D for getting behind other Ford models, it's another string to the bow and going by the interest generated there's no shortage of potential customers wanting their AU's going quicker
10-02-2006, 08:24 PM | #13 | ||
Now With 2 Cylinders More
can you run a turbo off a flash tune ? or would an aftermarket unit still be needed
10-02-2006, 08:27 PM | #14 | ||
Formerly known as TS 50
Waiting to see some T3's get tickled if the XR6's are anything to go by it should be good!!
BLUEPRINT T3 TS50 #109, MANUAL WITH BREMBOS
10-02-2006, 08:45 PM | #15 | |||
OR get something like the JMM interceptor that has its own MAP sensor.... |
10-02-2006, 08:50 PM | #16 | ||
Smile
Thats a really good improvement for a stock internal engine. Just two question though if you could ..What would be the differences between manual and auto's power? Also the head on the test car appears to be a hp motor...would these results be similar with a standard AU six head?
Cheers Stav
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
10-02-2006, 10:37 PM | #17 | |||
10-02-2006, 10:44 PM | #18 | |||
10-02-2006, 10:47 PM | #19 | ||
Built Ford Tough
I like the look of the airbox. I've got a replacement intake pipe that fits the EF-size pipe mouth, not the smaller AU size - would your box mate to the pipe?
I'm on the other side of Melbourne, so getting to Cranbourne is tough. If you could do a tune on a Saturday I would definitely be interested.
Black on white '83 SWB F100 C6 auto 351C on gas and on the ground --> Project Thread '55 F100, just a roller at the moment, new project Silver MY12 Volkswagen Amarok |
10-02-2006, 10:50 PM | #20 | ||||
AU DIE HARD
10-02-2006, 10:54 PM | #21 | |||
Competition is good, spurs me on!
10-02-2006, 10:58 PM | #22 | |||
Solution Was Boost 4?, 6 & 8
--------------- Glenn nice work, good to see you guy's at G@D having a real interest in all cars...
[SIGPIC][/SIGPIC]
AUTOTECH TUNED EDELEBROCK CHARGED 2017 GT Mustang Plenty of RWKW |
10-02-2006, 11:08 PM | #23 | ||||
AU DIE HARD
10-02-2006, 11:14 PM | #24 | |||
(I know. it will kill me)
10-02-2006, 11:32 PM | #25 | ||
buickman
Looks like I might go the flash tuner in the future as I won't be selling the AU in a hurry as in the next year I will trade the wifesMazda SP20 in for a Mazda CX-7 as the family car.
10-02-2006, 11:52 PM | #26 | |||
Highway Taxi
Close only counts in Horse Shoes & Hand Grenades. :evil_laug |
11-02-2006, 12:08 AM | #27 | ||
Built Ford Tough
Mine was 123rwKw stock.
11-02-2006, 12:16 AM | #28 | |||
Hmm Project XW VAN !!!!
I'm sure they could work something out. I would make sure of it lol. : While they play with your car you can come round for a drink : Sorry I cant remember your real name. I was in the truck. Whoosha is my old man. P.s Eyes off the rattle gun.... :jab: lol
I'd rather be BLOWN than stroked Yella Terra Supercharged Power Output? ENOUGH TO BREAK EVERY THING MORE TIMES THAN I CARE TO COUNT POWERED BY VISA MASTERCARD AND MORE VISA (And now a mortgage extension) Disclaimer : : Anything that seems or sounds illegal is all in my head and due to an over active imagination... :
11-02-2006, 12:17 AM | #29 | |||
(I suspect Scminer1's EF is another of these engines).
11-02-2006, 12:18 AM | #30 | |||
