Old 30-01-2005, 11:56 PM   #1
fairmont1998
fairmont1998's Avatar
Default KA Laser not kicking down.
This is a quiet section! Hope someone can help.
We have a KA Laser as a run around car and the auto in it does not kick down until you use full throttle. I have noticed a pipe on the auto that looks like it should have a vac hose on it but it doesn't. Also I can't see any hoses adrift in the engine bay. Does it need to be connected to vacuum and where do I connect the hose to for the vacuum?
I have pointed out the connection on the auto in the attachment.
Current Rides:
2012 KK Jeep Cherokee Limited CRD - Still going strong
2019 MG ZS Essence
1988 RD Mitsubishi Colt GL - 59kW of Fury
2022 Kia Stinger GT
fairmont1998 is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2005, 11:57 PM   #2
fairmont1998
How do I get the image to display and not the link, damn it!
Current Rides:
2019 MG ZS Essence
2022 Kia Stinger GT
Old 03-02-2005, 08:44 PM   #3
dozer
Those autos should have an electric kick down, which is a switch located at the accel pedal. As far as i am aware there is no vac signal there.
HOLDEN WHO???? :lookedat:
dozer is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2005, 11:03 PM   #4
fairmont1998
The electric kickdown is the WOT kickdown, ie 3rd to 1st. This specimen won't even kickdown from 3rd to 2nd when you come out of a corner at 25-30 km/h. Makes for some spirited driving with the old 1.5 litre ;)
Current Rides:
2019 MG ZS Essence
2022 Kia Stinger GT
Old 10-03-2010, 10:09 AM   #5
Chrisshu
Default ka kick down
Hi, there is a switch on the accellerator that can be adjusted. With ign on but not started, push down acc and you shoul hear a click from the relay. Chrisshu
Chrisshu is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2010, 11:08 PM   #6
phantom_87
phantom_87's Avatar
That is normal for KA Lasers kick down switch should only operate at full throttle and very reluctant to drop back to second out of corners until you give it full throttle then it will kickback to first not second.When they were first released back in the 80's we would get this complaint all the time.After enough complaints Ford had a couple of selected dealers with automatic section to come up with a quick and easy fix.What was eventually came out of this was a simple valve body mod by adding a small spring at the bottom off the 2-3 shift valve bore.The spring had to be light enough not to effect up-shift but heavy enough to assist it to change back to 2nd under vacuum rather than putting your foot down and operating the kick down switch This made it much nicer to drive but was only done on customer complaint bases only.You could try a longer modulator pin but this will cause higher shift points though.
The pipe you are looking at would more than likely be the breather if it is the the one on top of the auto next to the three bolt dome like cover(governor)
445RWKW of kennebell goodness
phantom_87 is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2010, 10:40 PM   #7
fairmont1998
Wow, old thread revived!
I never persued that issue but the car has moved on now.
Thanks for the answer phantom_87.
Current Rides:
2019 MG ZS Essence
2022 Kia Stinger GT
Old 14-03-2010, 10:49 PM   #8
tick5.0
Want some classic?
tick5.0's Avatar
That got me going, thought you might have got nostalgic and traded in the XR4 Darin.
Originally Posted by Walkinshaw
all i hear is wah wah wah a plastic car is quicker than my boat anchor
EF II XR8, Supercharged manual *** FOR SALE ***
XC Falcon, waiting for the Clevo & C4 - Sold
AE101 Corolla, the daily - Sold
SII RX-7, original - Sold
BF II GT
Alfa Romeo 156 JTS, the new daily
Z31 300ZX Turbo
tick5.0 is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2010, 09:28 PM   #9
fairmont1998
LOL, bought the mustard yellow rocket back? God help me if I did!
Current Rides:
2019 MG ZS Essence
2022 Kia Stinger GT
