Old 13-12-2020, 09:48 PM   #1
Aussie Falcon
Aussie Falcon's Avatar
Default AU1 Fairmont high fuel consumption
Hi,
I need help trying to solve a high fuel consumption problem on a 1999 6 Cyl AU1 Fairmont.
Driving is usually in the city with short trips and it's averaging 21L/100.
It's usually driven gently. I've tried 98 or 91 petrol and econ mode with little difference
The car drives and runs smoothly. There is a petrol\strong exhaust smell when car is cold on start up. Only modifications are\were a K&N filter and an XR6 intake scoop
The following have been replaced in recent months
Center and rear mufflers (due to corrosion)
new standard Air filter (was a K&N)
Coolant Temp sensor
6x new fuel injectors
new fuel pressure regulator
new inlet manifold gasket (leak was found)
new oxygen sensor
new idle control valve
Fuel filter was checked. Last replaced 2 years ago
spark plugs are about 5 years old
The car is in mint condition with low KMs and doesn't do more that 5k per year
what are the next steps?
Thanks
Aussie Falcon is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2020, 09:15 AM   #2
Peter B - CV8
Default Re: AU1 Fairmont high fuel consuption
What's the average speed reading that accompanies that fuel usage ??
Peter B - CV8 is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2020, 09:58 AM   #3
Aussie Falcon
sadly the Avg is 20km/hr.
It is only used for trips to the shops or Gym
Old 14-12-2020, 05:55 PM   #4
falconhell74
falconhell74's Avatar
Default Re: AU1 Fairmont high fuel consumption
Possibly a partially blocked cat converter and I would replace those spark plugs unless they are iridium or platinum plugs
XC GS OLD SCHOOL MUSCLE
Audi A4 S-line quttro
Xc falcon
Previous fords-
xc falcon 500 ,250 x flow 3 speed
xc gs worked 250 x flow 4 speed
xa Fairmont 302 auto wagon
xb falcon 250 log auto 4 door
xb falcon 200 log auto ute
xc gs project - had to sell :-(
xc gs 302 4 speed 4 door
xc gs 351 auto 4 door
zf fairlane 302 auto
zk fairlane 250 x flow carb auto
zl fairlane 250 x flow EFI auto
xg ute , BA falcon dedicated gas
xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5
falconhell74 is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2020, 09:15 AM   #5
Peter B - CV8
There's your answer. The car is spending the majority of it's time in the most uneconomical gears/speed/idling at lights etc.
Old 21-12-2020, 08:47 PM   #6
Aussie Falcon
Thanks for the advice
Old 21-12-2020, 09:36 PM   #7
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
City drive in my old AU II 310 kms from a tank for me. 340 in a good week
UK
