Old 08-06-2019, 12:33 AM   #1
sam the man
Default Accesory plug
Hi all,
My daughter has a '07 Focus, and loves it.
I was wondering if anyone knows how to change the accesory plug (cigarette lighter plug), which is live all the time, to change it so it turns off when the key is turned offf and removed.
This is because she uses a dashcam and phone charger, and has on ocassions left the plug in, which lets the acessories continue to run.
Unusual to have this wired like this from the factory?
sam the man is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2019, 01:08 AM   #2
94_ef
Default Re: Accesory plug
You might be able to use fuse taps in the fuse box to feed an ign pwr source into the lighter fuse line that runs to the socket being as it's bound to have it's own separate line. This is the easiest way to have a plug in solution that can be returned to stock in seconds. Other than that just throw a relay in somewhere.
2014 Ford Ranger XLS 4x4 Dual Cab.
2003 Ford BA Fairmont Ghia sedan.
1994 Ford EF Fairmont Ghia sedan.
1994 Ford ED Falcon GLi wagon. Discovered my love for Ford 4L.
94_ef is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2019, 01:11 AM   #3
94_ef
Also check out BlackVue Power Magic Pro
Old 08-06-2019, 09:47 AM   #4
sam the man
Do u think this is not standard wiring? Maybe I could find where it's been modified (between ignition and acc plug), and return to the way it should be?
Old 08-06-2019, 10:43 AM   #5
Fed
I think it's unusual sam, have you checked it yourself?
Maybe she's accidentally left it in the Acc position, I've done that twice now due to old age.
Fed is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2019, 02:28 PM   #6
LANKY 1
Are the Supercars on yet?
LANKY 1's Avatar
I have an 09 Focus and it is on all the time. Its an Ex-Rental but I wouldn't think that would be a reason. I dont drive it enough/far enough to warrent anything plugged in all the time so not an issue for me. However I do agree its a bit weird to be wired this way.
Could take it to an auto electrician and they should be able to change it.
Or find a way to DIY like 94_ef said
A Ford win is a good win!
V8 dreamteam
1st: 2012, 2021
2nd: 2015, 2016, 2020, 2022, 2023
3rd: 2014, 2018, 2019
LANKY 1 is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2019, 03:38 PM   #7
CatonaPC©
Originally Posted by LANKY 1 View Post
I have an 09 Focus and it is on all the time. I do agree its a bit weird to be wired this way.
No, nothing weird about it; my Golf had an accessory plug on all the time. In Australia, we think the norm is when the car is off, so too, the cigarette lighter (or radio). In Europe, theses two items work independently of the ignition or accessory position of the key.
CatonaPC© is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2019, 05:54 PM   #8
brucewarring
My LS Ghia is the same I have connected a 12v adapter to earth on the heater and to fuse 81 on the fuse board, easy to check with a test light just find one that turns on and off with the key in acc.....
brucewarring is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2019, 09:04 PM   #9
sam the man
Oh nice, great suggestions here.
Do you recall what fuse 81 controlled?
Old 14-06-2019, 12:59 PM   #10
brucewarring
Didn't control anything was a live blank for running lights if I remember
