Old 13-03-2015, 08:59 PM   #1
EL_Monty
EL_Monty's Avatar
Default 2000 laser engine dies when warm
hi all
my daughters 2000 laser 1.6 starts and drives well but it has today developed an issue of when hot it stalls and dies. it wont start until its cooled down? once cooled down it fires right up again.
anyone know where to look first?
thanks
EL
EL_Monty is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2015, 10:41 PM   #2
dirty hands
Over Thinker
dirty hands's Avatar
Default Re: 2000 laser engine dies when warm
coil packs failing ?
http://www.ebay.com.au/itm/FORD-LASE...item2edb1fe29f
not likely to be the ecu
could be this part failing
http://www.ebay.com.au/itm/Crank-Cam...item25a078d458
fuel filter been done ?
check the thermo fans work
if it is an auto .there would be other issues
the engines do not like being overheated
check dip stick for oil and water
how many km on the motor
i do work on A KQ mazda ford clone laser model 1.6 motor ocassionaly
the 2000 model http://www.drive.com.au/used-car-rev...824-13o37.html
My car goes Brumm Brumm
Old 14-03-2015, 02:56 PM   #3
EL_Monty
EL_Monty's Avatar
thanks man!!! .... turned out to be heat related alright......low coolant.
she hasnt checked it for a while obviously.
i assume it was getting too hot and killing to coils........ive flushed it out added fresh coolant, checked thermos both working, and road tested for an hour and no probs at all.
hopefully that was it but i think new coils and leads will be on her shopping list.
thanks for giving me a list of things to check
EL
Old 14-03-2015, 03:56 PM   #4
dirty hands
Over Thinker
if after an hour no problems like you had ..thats very good ..
Old 29-03-2015, 09:52 PM   #5
EL_Monty
EL_Monty's Avatar
well i have an update......car went well for a few days and developed another issue. again once it reaches operating temperature, it will lose drive.....like its arcing a spark once it cools a little all returns to normal.
in the last few days we have replaced both coils and leads and installed new plugs.....while the car runs much better it continues to stutter and fart once warm.....i can drive 20klms or 10klms its seems intermittent.
could crank angle sensor failing cause this?
regards
el
Old 30-03-2015, 07:29 PM   #6
dirty hands
Over Thinker
it hasnt done a valve or maybe a a stuck lifter
from what I know about crank angle sensors
some people suggest . to test this theory
pour cooler water over that CAS once it gets hot
see if it plays up
Old 30-03-2015, 09:01 PM   #7
11ford11
scan for codes
11ford11 is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2015, 10:36 PM   #8
dirty hands
Over Thinker
codes ? the engine check light does this model have one
or will an LED test light be eneough
next for a 2000 model
cant find a DIY fault codes list of instruction on the
bridging the wire on the diagnostic plug method and using the engine check light to flash the codes
if you have the radio code if the car needs one
you can undo the two battery terminals for a minute and clear any fault code readings
this will reset the computer
then try another test drive
Old 31-03-2015, 10:55 PM   #9
11ford11
diagnostic connector under bonnet - bridge terminal TEN to ground -LED test light or analog voltmeter connected from battery positive to terminal FEN - (marked on cover)
ignition on count pulses for codes eg,1flash followed by 2 flash = code 12
