Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Race Brakes Sydney
Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link
Old 19-08-2013, 06:08 PM   #1
Shonky.
Shonky.'s Avatar
Default difference between FG GT and GTP brakes
As per the title, what is the difference in factory brakes between GT and GTP?
Is it just front calipers, rear calipers and rear rotors?
Is everything else the same (lines, booster, master cylinder etc)?
Shonky. is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2013, 08:23 PM   #2
Shonky.
Shonky.'s Avatar
Default Re: difference between FG GT and GTP brakes
Further to my last, would you quote me (by PM if appropriate) for 6 piston front and 4 piston rear brembos, DBA T3 rotors, Ferodo pads, whatever fluid you would recommend, braided lines and anything else you think I need to make my car GTP configured but better.
Thanks
Old 19-08-2013, 08:36 PM   #3
GTBenny
GTBenny's Avatar
I think you're on the money with the differences Shonky. I don't think there is anything else.
What's your reason to upgrade and go for the 6 piston?
Benny.
GT 335 MKII, ZF6, Tein coilovers, YT snout, 61mm pulley, KPM 1500HP fuel system, 1000cc injectors, E85, KPM exhaust, BMC air filter, KPM Streetfighter intercooler, built tail shaft, Truetrac, 479rwkw - 950nm.
GTBenny is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2013, 10:21 PM   #4
Shonky.
Shonky.'s Avatar
Just want to price it at this stage.
Figure if I'm going to do rotors, pads, lines and fluid then the marginal increase with going up to 6+4 may make it viable, especially if I can get a few dollars for my 4+1 gear.
I have asked for Ferodos and DBAs based in part on your recommendation.
Did you consider/price it? (6+4 that is)
Old 20-08-2013, 09:03 PM   #5
GTBenny
GTBenny's Avatar
Yeah I sure did but thought for what I'm going to use the car for, spirited street use, then upgraded pads, fluid and rotors was going to be enough. I'd love to have the Harrop Ultimate brake kit or even the more capable 6+4 set up but couldn't bring myself to part with the cash. I'm really happy with the setup I have now. Ferodo DS2500's are awesome.
Benny.
Old 20-08-2013, 10:04 PM   #6
Shonky.
Shonky.'s Avatar
Yeah, there's a member on here with harrops on his white F6....porn!
I'm thinking if I can get my original disks machined I may be able to get $1500 or so for the stock gear to offset the bigger brembos. I see the 6pot fronts with rotors were around $2k, but prob more for the nice dba rotors. See what old mate says on price.
Do you know if you can take a few cuts off the factory rotor faces and stay within tolerance if they aren't too badly beaten up?
Old 21-08-2013, 11:56 AM   #7
FLOORED
Race Brakes Sydney
FLOORED's Avatar
PM being sent thanks
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop
Street to track is what we expertise in
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 21-08-2013, 09:15 PM   #8
Shonky.
Shonky.'s Avatar
thanks for your help on the phone today Matt!
Old 21-08-2013, 09:16 PM   #9
Shonky.
Shonky.'s Avatar
Old 21-08-2013, 09:31 PM   #10
GTBenny
GTBenny's Avatar
Yeah like most cast rotors there's some meat that can be machined away to true them up. But depends on how worn they are of course.
Benny.
Old 22-08-2013, 06:04 PM   #11
FLOORED
Race Brakes Sydney
FLOORED's Avatar
As long as the rotors are within the correct thickness and don't go under that after machining it is possible. The 355mm front rotors are 32mm std and min is 30mm
MATTHEW PEARCE
Phone 02 9609 1101
