Old 20-05-2013, 04:47 PM   #1
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Default A novel climate control display fix.
I had a few minutes to spare today and put my mind to a solution for my climate control display. I've been having ongoing issues with my CCs' after I bought a replacement for my original failed one . The replacement was one of the "fixed" ones you can get off of Ebay although I bought it from a third party out of a wreck and only discovered it was a modded one when it also failed and I pulled it apart. Anyhoo, I have been hunting high and low for conductive membrane tape with no luck and have approached many an electronics repairer only to be told it can't be re-glued and to bin it. But being the stubborn pr!ck that I am I wasn't going to give up that easily and tried to think outside the box for a solution. To this end, I noticed that when I pressed on the tape where it joined the circuit board with my fingers I could get the various elements to on the display to light up so all I needed to do was find a way to press the full length of the tape to the board all at the same time and make it stay there and the display should work. So this is what I came up with -
The smallest bulldog clips I could find and a thin strip of swede leather (or inner tube rubber would work too I reacon, I just happened to have a scrap of leather). Line up the tape over the contacts, wrap the leather over the tape to protect it and clip the whole lot down then remove the wire levers -
I plugged it in and tested it and it worked perfectly so I chopped out the fascia and back cover to allow for the clips then put the whole unit back together and slipped it back into place for a perfectly working climate control display. Who knows how long it will last, maybe indefinitely maybe not but at worst only a clip can come adrift which can be easily and quickly reattached, all for less than $5. It would seem to me that original untouched units that are starting to fade can also benefit from this method by just attaching clips as above to re-enforce the join without the expense of replacing or reconditioning them.
Only time will tell how long it will last but, hey, it didn't cost me anything to do and it's working perfectly.
The one in the pics is the second unit I just removed from the car and did up for the pics. The tape is completely stuffed as it was the "fixed" one and there's not enough tape left to fold over the board but you get the idea of what the other one is like.
Bushbasher
MINE- AUII Forte
7 users like this post:
Old 20-05-2013, 08:31 PM   #2
K_Man
Whoa, this is heavy!
K_Man's Avatar
Default Re: A novel climate control display fix.
This. Is. Awesome!
Thats real macguyver stuff there, I love it! Might give it a go in coming weeks, my climate is starting to go poo.
Liquid Silver 2002 AU III Fairmont wagon
Le Mans Red 1990 SA Capri Turbo
K_Man is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2013, 12:04 AM   #3
mik
mik's Avatar
very impressive mate, old school engineuity ..... i like it !
Old 21-05-2013, 05:29 PM   #4
InfernoSR
Sales Representative
InfernoSR's Avatar
So all in all, its the actual conductive tape thats the issue?! and yet people want a couple of hundred to repair the units... might look into doing a repair rather similar...
Old 21-05-2013, 09:55 PM   #5
FGII-XR6
FGII-XR6's Avatar
if you use the paper holders that you use for binding small bundles of paper , you use a small hand tool to put them on ( the ones that look like bulldog clips without the handles) these things you could do this without having to cut the housing as they are quite low profile
[SIGPIC][/SIGPIC]
Rides:
Old 21-05-2013, 11:21 PM   #6
Bushbasher
Bushbasher's Avatar
These are a great idea and much better than my bulldog clips. If I'd known of their existence I definitely would have tried them out. The method is sound though so maybe the next person to try this out can use them and tell us how they went.
Bushbasher
MINE- AUII Forte
Old 22-05-2013, 12:56 AM   #7
martos
martos's Avatar
Good post Bushbasher.I might try this myself.Mine only fails when car is parked in hot sun,once it's parked in garage for a night or few days it works fine again.
martos is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2013, 05:35 PM   #8
Bushbasher
Bushbasher's Avatar
Well it's been a week now and I thought I'd show everyone that the climate control is still working 100%. In fact it's working better than it ever has. Sorry for the quality of the pic but it was taken with my old phone.
Bushbasher
MINE- AUII Forte
Old 30-05-2013, 02:58 PM   #9
Silver'
T-Series Club Member Vic
Silver''s Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent write ups on AU technical issues.
I'd always assumed that the boards needed reflowing due to dry solder joins. I've a spare faulty TE50 unit that I'll have a look at myself now - cheers!
TE2 #116
Build/Maintenance thread here.
www.fte.ford.com.au lives! 2001 2002
Add a T-series to the Registry HERE
Silver' is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2013, 08:01 PM   #10
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For the effort put into the Australia day cruise to Albury Tech Writer: Recognition for the technical writers of AFF - Issue reason: AU Tech article.
Well done Bushy. Great thread.
Stu
2002 AU II LTD
5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust.
Quarter Mile: 13.73 @ 105.86mph
Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024
2002 XR8 pursuit 250
Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
auIILTD is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2013, 08:04 PM   #11
KR1STO
Just another mock-up..
KR1STO's Avatar
Yeah top thread..!
Might try something similar myself..
Desire isn't driven by the heart, the mind or the wallet.
Desire comes from another place.
It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night...
see my car here:
Built my own TL50!!!
[SIGPIC][/SIGPIC]
KR1STO is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2013, 11:18 PM   #12
Vincenzo
Vincenzo's Avatar
Bushbasher - you ability for thinking outside the square (lateral thinking) is amazing to say the least - brilliant.
Cheers Vincenzo
$DO || ! $DO : try
try: command not found - (YODA the Geek)
"WRC is for boys, Group B was for men" - Juha Kankkunen 4 times World Rally Champion
Romanes Eunt Domus - 'people called Romanes they go the house' - You mean Romani Ite Domum
[SIGPIC][/SIGPIC]
Vincenzo is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2013, 11:37 PM   #13
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Cheers Vincenzo
Yeah, Bushy is living up to his username isn't he. Very creative, very Aussie!
Stu
2002 AU II LTD
Old 01-08-2013, 10:48 PM   #14
Polyal
Virtuous Bogan (TM)
Polyal's Avatar
SO how is this going mate?
I might try it on the weekend before resorting to the ~$150 repair job by a "pro".
Anyone else confirm the procedure?
  • 2023 Mitsubishi Triton
  • 1973 ZF Ford Fairlane
Polyal is online now   Reply With Quote Multi-Quote with this Post
Old 01-08-2013, 11:19 PM   #15
Bushbasher
Bushbasher's Avatar
I can tell you that 2 months on my CC is still working perfectly and if you don't disturb the circuit tape and it's still stuck down to the board then it should be an idiot proof job as long as you're not too heavy handed. All you will need to do is fold the tape back over the board and put something over it to protect the tape then attach the clips. Those Nalclips look like they'll do the job well. Just make sure you put the clips hard up against each other so ALL the tape in pressed down. Any gap might leave a weak spot with no pressure. Once the clips are on plug it back in to test it and if all is good just reassemble and refit the CC, jobs right.
Bushbasher
MINE- AUII Forte
Old 01-08-2013, 11:29 PM   #16
Bushbasher
Bushbasher's Avatar
Just so you know. The circuit tape is glued to the circuit board and all the "pro" will do is cut the tape back, peel back the protective clear coat and re-glue the tape down. The one that I got hold of wasn't a particularly tidy job either and it also failed after a time. I don't know how old the the repair was by the time I got it but it failed on me after less than 18 months.
Bushbasher
MINE- AUII Forte
Old 04-08-2013, 05:22 PM   #17
Polyal
Virtuous Bogan (TM)
Polyal's Avatar
OK so I have the unit out, Ill have a crack at the tape tonight and report back.
I bought those clips from Officeworks so hopefully all goes to plan. I did snap on of the clips on the clock surround though...
Old 04-08-2013, 05:56 PM   #18
Polyal
Virtuous Bogan (TM)
Polyal's Avatar
Right so those clips are not that easy to use unless you are an octopus.
If its a matter of getting the tape to stay down then I am thinking glue gun?
Is this issue getting the membrane to sit flush against the front and back sections where the circuit board are?
Old 04-08-2013, 10:45 PM   #19
Bushbasher
Bushbasher's Avatar
Whatever you do don't use a glue gun, or superglue or any other glue you might care to think of. Been there, done that. I tried that and all it will do is stop the CC from working because the glue isn't conductive. If your tape is still stuck down all you need to do is press the tape down to the board to create a good contact. Take the guts of the unit out to the car and plug it in and press the tape down with your fingers where it's glued to the back of the board and watch the LED segments come alive as you press. What you are trying to do in press the whole tape down together. DON"T un-stick the tape from the board unless you absolutely have to and only then if the segments don't come back with the fix. That'll mean the tape filaments have died from fatigue. If that's the case as it was with mine, remove the tape and trim it back at the point where it was glued down,(approx. 6mm of tape). Then start picking at a corner till you can get the clear coat to lift then peel it back to expose some fresh tape. Don't try to glue it down, it doesn't work. Very carefully line up the filaments with the connectors on the board, (this must be exact), and clip it down to the board. There should still be enough tape to fold it over the board and attach the clips.
You DID buy the little tool to spread those clips didn't you? If you didn't you're never going to get them to spread.
In short, what I've described is exactly what I did as I had to shorten my tape and after trying various glues I had LOTS of fun trying to get the board connectors and the tape clean of glues without killing either one which is why I'm saying to not try to glue it cos you'll just make it worse.
Sorry about the surround clip but maybe you can superglue it back together before you put it back on. And if all else fails, take comfort in knowing mine has been broken since I've had it and it's never moved once sat in place and you wouldn't know there's anything wrong with it.
Bushbasher
MINE- AUII Forte
Old 04-08-2013, 11:15 PM   #20
blownv8au
Pro Street Au Ute
blownv8au's Avatar
Bushbasher is the speed alert and tripmeter part of that circuit. I bought a te50 today and the tripmeter side is stuffed. If it is I'll use your tips and have a crack tomorrow.
Daily. AU XR8 s2 ute auto
Weekender. AU XR8 s2 sedan. 427 windsor, t56 magnum. 3.9 locker.
blownv8au is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2013, 11:23 PM   #21
Bushbasher
Bushbasher's Avatar
Yup, it's all in one. Once you take the fascia off it's just 1 screen, have a look at the pics, 1 tape, 1 screen and 2 plugs coming into the unit. I'd guess that one is the A/C controls and the other is the trip/fuel usage/speed alert controls.
Bushbasher
MINE- AUII Forte
Old 04-08-2013, 11:30 PM   #22
blownv8au
Pro Street Au Ute
blownv8au's Avatar
Cool, i was looking on my phone before and couldn't see it real well. I really need to go and get some glasses.
Thanks I'll see if it's repairable tomorrow.
Old 04-08-2013, 11:44 PM   #23
Silver'
Silver''s Avatar
Thumbs up Re: A novel climate control display fix.
Congrat's! It would be great if you could add or update it in the club registry.
TE2 #116
Old 06-08-2013, 05:20 PM   #24
Polyal
Virtuous Bogan (TM)
Polyal's Avatar
Bushy, all good I havent got the glue gun to it but naturally I didnt buy the tool to open those clips. Ill see if I can swing by tonight and grab it.
When you say make it connect..Im assuming you are talking about the vertical sections on the lip of the board? as there is slack in the top (horizontal) section??
Hope that makes sense.
Old 06-08-2013, 05:41 PM   #25
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Well done, might need this in the future.
UK
Old 06-08-2013, 07:07 PM   #26
Bushbasher
Bushbasher's Avatar
What I'm talking about is the copper tabs circled below
your tape should still be stuck down to that. Plug it in to the car (without the casing) and press on there and you'll press the circuit tape back down onto those tabs and the LED elements should start coming back to life. What you are going to do is fold the loose tape over the edge of the board then put the clips over the edge of the board effectively pressing the tape to the tabs. Just make sure you put the clips hard up against each other so you don't miss any connections. Just find something to insulate the tape from the clips so you don't risk damaging it, I used a thin piece of chamois leather that you wipe the car down with. with all the clips in place you should have a solid connection across the full tape. Plug it back in and test it and if it's all good put it back together and reinstall it. Mine is still 100% after 3 weeks now with just the bulldog clips. If any of the elements don't come back you may have broken tape. If that's the case you'll have to heat the tape (with a not too hot iron) and release the tape then cut it back, peel back some of the clear coat and then clip it back down like I described before. If after all that you still can't get it going give me a couple of weeks and I should have a working one available to exchange.
Bushbasher
MINE- AUII Forte
Old 06-08-2013, 08:19 PM   #27
Polyal
Virtuous Bogan (TM)
Polyal's Avatar
yeap...so you only have to do the backside?
Also after zooming in have you got slack/excess on the bottom edge of the clips on the backside? When you say have the loose tape over the edge you mean the back edge, noty towards the center?..sorry :/
Even if this doesnt work for me thankyou!..Im off to get that tool for the clips in 10mins
Old 22-08-2013, 12:26 AM   #28
Bushbasher
Bushbasher's Avatar
Ok, After buying another Sportsman I now have a second climate control, but of coarse the LED display was flaky and had a mind of it's own and was coming and going as the mood took it. So I pulled it from the car today and saw that it's a virgin unit so I went and got some Nalclips and the fitting tool and set about fixing the display. After a little modification to get the tool to fit over the circuit board the way I wanted it to I had the display sorted out in no time using some inner tube rubber from an old bicycle as insulation. As soon as I find the camera I'll put up some pics but in the mean time, if anyone needs a working unit I'll be happy to exchange it for your faded unit, so long as yours is fixable, for no more than the cost of the postage and any donation to the cause that you'd like to contribute as I still have to buy the clips and replacement bulbs so all the display and buttons light up correctly. If anyone's interested just PM me and we'll work something out.
Bushbasher
MINE- AUII Forte
Old 27-02-2014, 01:14 PM   #29
mif73
CNC fixer guy
mif73's Avatar
Hey guys, i had a couple of segments intermittently die so i pulled my mdc apart and fixed it with some foam tape and offcuts of pvc "c" channel extrusion to clamp over the ribbon cable and pvc.
It works well and does not require mods to the mdc case.
I did drill a hole on the back cover to allow replacement of the clock globe at a later date though.(funny its the only globe without an access hole in the back of the mdc).
I can supply pics if anyone is interested.
Cheers.
Ps: thanks go to bushbasher for the motivation to fix it.
Weekend Toy: S1 AU Fairlane V8 with LTD bits, Tickford 17" wheels, front and rear chin spoilers, series 2 front brake conversion with Super pro bushes, Pacemaker headers, rear muffler removed, Kings/Pedders lowered suspension, Koni adj rears, painted headlight bezels, HR 2300kg hitch, 2 stage shift kit, trans cooler, reverse cam and media player.
Wife unit's : 2010 update FG XR6, reverse cam, HR 2300kg Hitch, German Maestro speakers, parcel shelf sub, trimmed mudflaps, batman stickers.
mif73 is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2014, 01:58 PM   #30
Polyal
Virtuous Bogan (TM)
Polyal's Avatar
Yes pics please. Mine is still 85%
