Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > Early Falcon Car Club of Qld Inc
Early Falcon Car Club of Qld Inc The Queensland early model Falcon Club.
Old 06-02-2011, 08:04 PM   #1
trucknhell
Exclamation xm ute
need to find out what disc brake front end fits xm ute
trucknhell is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2011, 04:04 PM   #2
xwboss
xwboss's Avatar
You can fit XW to XF stubs, hubs and calipers, you will need to fit a bush on the outer tie rod end and shorten the tie rod. this is the cheapeast but tend to cause bumbe steer and reduces steering lock.
Places like CRS can supply kits to fit discs and calipers to original stub axles, this does not change steering or ride at all but is more expensive check out the link below, you will need to source discs and calipers as per there recommendation
http://www.rodshop.com.au/brakekits/brakekits.htm
Territory black VSI lpg
XW GS Fairmont 351C toploader 9inch
Mazda Bravo 4 X 4
xwboss is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2014, 11:11 PM   #3
robert xp
Default Re: xm ute
i have xf disc brakes on my ute xp
robert xp is offline   Reply With Quote Multi-Quote with this Post
