28-02-2010, 09:33 AM | #1 | ||
Hi Every one
I switched on the cruise control the other day and nothing happened, looked at the dash and no curise on. Thankin you in advance. VJJP. |
28-02-2010, 09:35 AM | #2 | ||
Check your brake lights - if one or more of the bulbs has blown, cruise will not work. Could also be a fuse in the fuse block under the panel near your right knee when sitting in driver's seat.
28-02-2010, 09:55 AM | #3 | ||
Brake lights generally only effect the car when you try to turn the cruise control off using the brake pedal, and they have this problem when the brake light swtich is buggered.
28-02-2010, 09:58 AM | #4 | |||
Just another mock-up..
you sure...? i thought the same as JC, that it wouldn't allow it to work at all... had it happen with mine before and yep, the culprit was a blown tail light..
Desire isn't driven by the heart, the mind or the wallet. Desire comes from another place. It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night... see my car here: Built my own TL50!!! [SIGPIC][/SIGPIC]
28-02-2010, 10:01 AM | #5 | ||
That was a problem with the late EL's and I wouldn't think they wouldn't change the switch mechanism, the globes could be at fault on an AU, they were never a problem on the EL, my late EL used to blow brake globes all the time and it never affected the cruise
28-02-2010, 10:04 AM | #6 | ||
Barra Turbo > V8
Busted globes do affect cruise in AU's mine wouldnt work when i had not 1 but 2 busted brake light globes at the same time : soon as i replaced them worked fine
2011 XR6 Turbo Ute - Manual - Lux Pack - Twin 2.5" Stainless Exhaust - Antz Turboside Intake - CCForged Phatlux wheels - Tuned by LS Tuning and Performance |
28-02-2010, 10:07 AM | #7 | ||
Well there you go - sorry Jude
28-02-2010, 08:21 PM | #8 | ||
When in doubt, GAS IT!!
Our wagon never had a problem when a globe went but if the brake light fuse pops then the cruise won't engage. The "cruise" icon lights up on the dash but the cruise control won't set.
Bushbasher
28-02-2010, 08:33 PM | #9 | ||
Just slidin'
Deffinately check your brake lights, if one goes, your cruise control wont engage.
MD Mondeo - For the family
28-02-2010, 08:39 PM | #10 | ||
Shame Holden, Shame
Could also be your brake booster switch.
Essendon FC '11 EFII "XR8" Fairmont V8 185KW ELII XR8 engine, box & exhaust|Dual Fuel|Tints|FTR's|Factory bodykit |K&N panel filter|Interior LED Conversion|Leather steering wheel|Slotted rotors|Ghia wood + chrome|Subwoofer| METALLICA |
28-02-2010, 09:48 PM | #11 | ||
Walking with God
I had the same problem on my SR as described by JC. "Cruise" appeared on dash, but "set" would not. Both brake bulbs were blown. Replaced both and cruise returned.
GK
01-03-2010, 10:10 AM | #12 | ||
Thank you all very much for the responce. I did not have the time to check the brake lights, will do so today and keep all posted.
VJJP |
15-08-2022, 08:44 PM | #13 | ||
16-08-2022, 04:14 PM | #14 | ||
Next upgraded Mk1 Leopard
Mate he hasn't but posting since 2012
16-08-2022, 08:00 PM | #15 | ||
Cookie Monster
Hi All,
Issue is most likely within the combination switch. The wires get broken for the cruise switch. The wires rub themselves thin at the joint for the blocker stalk. Its an easy fix. Remove combo switch. Resolder broken wire located just at blinker stalk joint. Chased this one for ages on my car. Its a silly design, wires get pinched at the joint as the blinker stalk gets used. I know this is an ancient thread, but it may help someone out there |
2 users like this post: |
11-10-2022, 02:19 PM | #16 | ||
I know this is an old item, but thought I would share my experience and FIX.
The Brake switch was the cause of the Cruise control. Not because it was Broken. I have an XR8 Manual. Apparently I am told its common problem for the clutch Brake cradle assembly to bend and also like mine to bend the firewall out, or distort the bracket assembly. If it was common I had never heard of it. I removed it to have a look also I had another to compare it to, and indeed it was bent and the firewall was also pushed out. So I took the spare unit to a manufacturer and got him to make it stronger, Also I got a piece of 1/8 steel and shaped it to fit on the fire wall. When it was all in place the Brake-light switch now lined up, and the cruise control worked. |
