Not sure if anyone has posted this in here yet but how many KM have you got on your AU and what's gone wrong with it?
Mine ('99 AU Futura I6) has done 225***km and nothing has gone wrong with it yet touch wood. Replaced plugs and leads the other day but it hasnt had any real problems though the thermostat needs replacing but its a good engine.
I6 All the way |
Irregular member
I've had it for 5 years, from 72*** kms to 148*** kms.
Auto trans gasket replaced, battery replaced twice, coolant hose leak fixed, engine has an intermittent very light oil leak. CD stacker jammed twice (warranty). Factory amp died once (warranty). Muffler came off pipe, had it removed. I think that's it.
2000 AU II FAIRLANE 75th ANNIVERSARY - big and shiny My hovercraft is full of eels! Movie Car Chase of the Week: Gene Hackman driving a 1971 Pontiac LeMans to chase an elevated train in The French Connection (1971). |
Flairs - Truckers Delight
673k, original unopened donk. Drives the same as my white AU did with less than half the kays.
Bearded Hermit
AU2 futura 6 cylinder
3 years, 130,000k-185,000k in that time -power steering high pressure hose busted, replaced about 6 months ago -brake master cylinder replaced just this weekend -cd player stopped playing cd's, replaced 3 months ago -coolant thermostat replaced about 18 months ago |
I should add I've had my car for just over a year, about 15 months, had 195*** on it when I bought it. Have no idea what the last owner was like on it or how often it was maintained but i look after it well as you should with any car.
I6 All the way |
Lost Boost Gained Class
DEC 98 AU forte
Brought with 221,XXXK's on it Now has 278XXX K's on it things that have gorn wrong Spark Plugs 2 times Spark Plug Leads Battery Coil Pack Cat Giveing way Rusted out Exhust And Car not starting in Park (still have the Prob) think its the tranny switch
2006 BF Fairmont Ghia
2001 AU Falcon |
I've had my AU just over a year. It has 218,000 when I bought it. It now has 246,000.
So far I've replaced: all fluids, both engine mounts, balancer, serpentine belt+tensioner radiator+hoses, both oxygen sensors, plugs+leads, both coilpacks, brakes and tyres. It will need a water pump and thermostat shortly and I look forward to a new exhaust. |
i have a 2002 AU3 SR with 185xxx k's on it. no major problems (touchwood). i bought it in 2005 with 70k's on it (wife used to drive an hour to work in it for a year or two)
it has a very annoying dash rattle new exhaust (old one rusted) new mags (16's not big enough, not really a fault as such ![]() new idle control sensor thing a year or two ago new battery (old one died august this year) the annoying boot leak has been fixed yet to sort out the rear brake squeek hopefully it lasts another 3 problem free years, by then i should be able to afford to update... hopefully... |
i have 316.000kms and replaceing over 20 things
Oh yeah and speaking of what's gone wrong with it, my handbrake has never worked... Did any AU actually leave the factory with a working handbrake? haha
#11 | |||
I6 All the way |
#12 | ||
Walking with God
99 Futura Wagon
Purchased March 2003 with 80,000 kays. Now has 207,000. 01 SR Sedan Purchased December 2005 with 73,000. Now has 154,000. GK
Just slidin'
I have sold my Monty, bought at 157 000 and sold at 285 000. Replaced two batteries, and that was it.
Blue car I bought as a repairable write off, after it was fixed, it had 104 000k's and apart from the accident damage, and all the mods, Ive only had to replace the extension housing seal as I had night at the drags on the slicks, and I dont think it liked it much, lol. Blue car has 140 000 on it now, although as the diff gears make it read out, it really only has 127 720k's on it.
MD Mondeo - For the family
#14 | ||
Rockin '67
01 s2 forte
purchased feb 07 - 73,000 Now has 87,000 I don't do much driving. |
#15 | |||
Walking with God
GK
#16 | ||
64 Deluxe 4 door
![]() Join Date: Jun 2007
AU3 - bought at 50k
just done the 125k service door actuator 2 batteries 2 exhausts front rotors
XM Deluxe FG XR50 BA Pursuit Ute |
#17 | ||
I ♥ EDM
![]() Join Date: Aug 2006
AU3 XR8
163k at purchase 183k at present after 6 months. Got it cheap and was a poorly maintained reps car. Heater Valve Serpentine Belt Driver door actuator Will need new rad hoses, SP's & leads shortly Fortunately drivetrain survived previous owners neglect. Runs beautifully, gotta love a Ford ![]() |
#18 | |||
#19 | |||
I ♥ EDM
#20 | ||
Missing the boost :(
2002 Au XR8 with 106,000 on the clock.
BA XR6 Turbo
301rwkw mild tune ![]() Modified by XR6Turbo Developments |
#21 | ||
546,000km, will be pushing 550k after new years.
On it's second g/box, original unopened engine that burns no oil. Could do with new rotors, springs, shocks and all suspension bushes. Has a bit of rust around the boot struts. Front crank seal is leaking a small amount of oil. Expected with the amount of kays. All in all a farkin great car. |
#22 | ||
Things i have replaced
new header tank new hoses new thermos new rad new idle tensioner new gear box mounts new engine mounts new front and rear shocks new front and back brakes new front rotors new gear box rear main seal new uni join new thermo stat seal new remote for central locking new bbm gasket stepper motor extension housing Still to replace drivers side actuator lhr door steering rack lower front bar support front and rear bushes roof liner cruise buttoons tbar thats all i can think of
#23 | ||
More things i have done
18 inch mags sprots exhaust and extractors half painted kit
#24 | ||
2001 fairmont 200K new rad, new thermo fans new shocks [all round] new thermostat new coolant header tank [new coolant] new pads and discs, new plugs and leads [what a 2 fit] and a new battrey. then i wrote it off. Bummer!!!!
#25 | |||
i forgot about my slotted rotors that i got on a group buy
![]() Quote:
to fix it: 1. i took the wing off and covered the top and underside of the mounting holes with some silicon/glue stuff, i think it was called 'drip check', then put the wing back on. 2. i also drilled 3 small holes (inside the bootlid) below where the number plate sits on the bootlid to let any built up water escape. parking facing up hill seemed to help a bit. the biggest fix, and most expensive was to buy a new house with a double garage to park in ![]() others have suggested new boot rubbers might help. hope that helps |
#26 | ||
All Bran = Regular Member
2002 Fairmont Ghia. Bought at 75000k now 170,000k.
Only thing that has actually gone wrong was the exhaust which was replaced at around 130,000. I've replaced a few bits as preventative measures and have a few mods but that's not what you asked ![]() |
#27 | ||
Giddy up.
2001 AUII XR8, bought new, just clicked over 53 thous, not a single problem (touch wood) since bought.
#28 | ||
Resident AFF detailer
2002 AU3 Futura, just hit 220,000 kms over the weekend.....I've had it since 184,000.
The only thing of any mention that's gone wrong was replacing one battery at last service 4,000 kms ago, as 3 of the 6 cells were faulty......nothing else has 'died' as such, things have been replaced as normal service items (plugs, leads etc), and I did replace the rotors, which were pretty badly shagged.....but nothing has failed!
#29 | ||
AU1 XR8 - Bought Oct 07 - 140k on it, now at 174k
GT 335 11.3@124.1mph 383rwkw/513rwhp Forced Performance Tuned |
#30 | ||
Barra Turbo > V8
T2 TE50 just clicked over 180k, DRIVEN NOT HIDDEN. Still brings a smile when i crank over the ol wheeza
2011 XR6 Turbo Ute - Manual - Lux Pack - Twin 2.5" Stainless Exhaust - Antz Turboside Intake - CCForged Phatlux wheels - Tuned by LS Tuning and Performance |
