13-12-2007, 12:55 PM | #1 | ||
Falcon Unbelievable
Unleash the power of your instrument cluster
for all FORD vehicles Unlock the many hidden functions of your dash *** You will need a cluster with digital odometer *** Saw this on ebay and they want $4.99 for it....Thought id ask here as im not going to buy it lol...So doe's anyone know how to un lock it? |
13-12-2007, 03:18 PM | #2 | ||
_Oo===oO_
Not sure why one would want to spend $4.99 on that. :nutsycuck
The easy part is the theory. The hard part is getting the timing exact to get into and out of Diagnostic mode. Entering Diagnostic mode The diagnostic mode can be entered by using the following method 1) With the ignition key in the off position, turn the Ignition Key to the On Position. 2) Using the Odometer Button, Press the Odometer Button Down, then release 5 Times within 10 Seconds (Note : You must be very accurate with the timing. Depress the Button for 1 second, then release for 1 second. Do this 5 Times in 10 seconds) 3) Release the Odometer Button for 5 seconds. 4) Depress the Odometer Button for 7 Seconds. 5) Release the Odometer Button for 5 Seconds. 6) Depress the Odometer Button for 7 Seconds. You should now be within the AU Instrument Cluster Diagnostic Mode Within Diagnostic mode, there are 19 Diagnostic Screens that are available. At the moment we do not have enough information as to what all the screens actually are. To Exit the Diagnostic mode, Depress the Odometer Button for 11 seconds. Not all of the information in the diagnostic codes are known, though. Diagnostic Codes Mode Top Line Bottom Line 1 Petrol in Litres (No Level Buffering) Petrol Sender Resistance (Unbuffered) 2 Coolant Temperature (Degrees C) 3 Engine RPM Vehicle Speed (KM/H) 4 Oil Pressure (Bar, 1 decimal Point) Battery Voltage (Volts) 5 Instant Fuel Consumption (L/100Km) Instant Fuel Consumption (x 0.1 Litres) 6 Fuel used since Trip Avg L/100 Reset (x 0.1L) This Value is used to calculate the Trip computer Average Fuel consumption L/100Km Kms Travelled since Trip Avg L/100 Reset 7 Buffered Fuel Tank Level (In Litres) Value used for Petrol Gauge Buffered Fuel Tank Lever Sender Resistance 8 Gear Position (PNRD321) 9 Unknown - 0000 Unknown - 1111 Changes on AC Clutch Engage 10 Unknown - 0000 Unknown - 1111 11 Unknown - 0000 Unknown - 1111 12 Unknown - 0 13 Unknown - 0 14 Unknown - 0000 118 15 Unknown - 0000 255 16 98 112 17 Unknown - 0 0 18 -o-d ---- 19 Unknown Police - (Ex Chaser) Instrument Clusters In addition to the above diagnostic modes, the Police (Chaser) Instrument clusters also have a Speedo Calibration mode. The Police (Ex-Chaser) instrument cluster allows re-programming of the Speedo Reading, (and consequently the Odometer), so as a Precise Speedo Reading can be made. This also means that the Speedo can be re-calibrated, when making changes to the Factory fitted wheels, Tyre Profiles, as well as altering differential Ratios. To determine if you have a Police (Ex Chaser) Instrument Cluster fitted, try the following Routine, to enter the calibration mode. To Calculate Calibration figures for the Police Instrument cluster, when making the above modifications, please check the Diff and Tyre Calculator Page. Warning : Playing with the Instrument Calibration feature will modify your Speedo, and Odometer readings. Please be sure of the consequences of changing these settings, and also Make note of your Original Calibration Setting This will ensure that you can return the Speedo Calibration Back to its original condition, if modified. Entering the Police Instruments Calibration Mode - (Police AU Series I models) 1) With the ignition key in the On position, press and hold the Odometer reset knob for 5 seconds, then release. 2) The Odometer will then display "SPEEDO #.#" - where #.# is the Speedo calibration Percentage, and is set to "0.0" Percent from the factory. 3) To increase the Percentage adjustment, Press the Odometer reset shaft for a short period of time (0.2 to 0.7 seconds). This will increase the adjustment by 0.5% 4) To decrease the Percentage adjustment, Press the Odometer reset shaft for a long period of time (0.8 to 4.9 seconds). This will decrease the adjustment by 0.5% 5) To exit the Speedo calibration mode, press and hold the Odometer Reset shaft for a period longer than 5 seconds. Entering the Police Instruments Calibration Mode - (Police AU Series II - AUIII Models) 1) With the ignition key in the Off position, press and hold the Odometer reset knob 2) Turn the Ignition Switch On, and continue to hold the Reset shaft in for 5 seconds, until the cluster enters calibration mode, (Typically 5 seconds) 2) The Odometer will then display "SPEEDO #.#" - where #.# is the Speedo calibration Percentage, and is set to "0.0" Percent from the factory. 3) To increase the Percentage adjustment, Press the Odometer reset shaft for a short period of time (0.2 to 0.7 seconds). This will increase the adjustment by 0.5% 4) To decrease the Percentage adjustment, Press the Odometer reset shaft for a long period of time (0.8 to 4.9 seconds). This will decrease the adjustment by 0.5% 5) To exit the Speedo calibration mode, press and hold the Odometer Reset shaft for a period longer than 5 seconds.
4 users like this post: |
13-12-2007, 10:46 PM | #3 | ||
Falcon Unbelievable
Thank you!
13-12-2007, 11:31 PM | #4 | ||
Uterus M.I.A.
And your right about the timing of the sequence it has to be perfect for it to work
13-12-2007, 11:31 PM | #5 | ||
Falcon Unbelievable
I can't seem to do it!!!!!!! Is there any other ways of inputing it?
13-12-2007, 11:51 PM | #6 | ||
Makes it easier while looking at a watch ... the seconds have to be EXACT.
Also Mode 2 (2nd function) I worked out to be DTE as well.
13-12-2007, 11:54 PM | #7 | ||
Highway Taxi
[QUOTE=Mechan1k]Makes it easier while looking at a watch ... the seconds have to be EXACT.
Very true, it took me a couple of times to do it. Use a watch to time the seconds! Good luck
Close only counts in Horse Shoes & Hand Grenades. :evil_laug |
14-12-2007, 02:09 AM | #8 | ||
I tried about a dozen times before getting out the stop watch... First go. I could have saved all that frustration. :p
14-12-2007, 02:15 AM | #9 | ||
edit: woops, meant to make a new thread.
14-12-2007, 07:00 PM | #10 | ||
Barra Turbo > V8
Nearly thought about posting this after i seen my mate able to do it in his VX i thought that there would be something similar in the falcons
2011 XR6 Turbo Ute - Manual - Lux Pack - Twin 2.5" Stainless Exhaust - Antz Turboside Intake - CCForged Phatlux wheels - Tuned by LS Tuning and Performance |
18-02-2008, 02:47 PM | #11 | ||
Landau = GT with the lot!
Does anyone know if the works the same for BF?
18-02-2008, 06:56 PM | #12 | ||
I have an ex Queensland Police car (Series 1)... If you hold the old button down while driving (obviously in a straight line, with a passenger watching the display) you can call up the speed calibration function.. This is a great feature, especially if you drive under those radar displays on the Hume at Wodonga and Beverage.
18-02-2008, 07:25 PM | #13 | ||
Barra Turbo > V8
I tried it 4 times without a timer and on the 5th time without a timer i got it
18-02-2008, 10:17 PM | #15 | ||
Lol...I got this both times I've tried it tonight...this information would've been really good a while ago for me...pity I only found this tonight when I'm selling my car....lol....maybe I can let the new buyer know.
Mike |
17-07-2008, 01:06 AM | #16 | ||
wow gave this a go.. It works.. Yet to see the tacho and speed but damn that would come in handy.
17-07-2008, 07:02 PM | #17 | ||
Rockin '67
Does anyone have the ef/l one?
03-08-2009, 09:48 PM | #18 | ||
How is this meant to work when on the last 5 within 10secs sequence you are releasing the button already, how the heck are you meant to release it again for 5 secs?
04-08-2009, 01:58 PM | #19 | ||
Irregular member
Use a stopwatch because it's easy to go too fast. I did it last night.
Press and release it 5 times in 10 seconds. (eg. two seconds taken for each cycle of holding it down for a second and releasing for a second). Make sure you let that last release second pass, then count another 5 seconds released. Then hold it down for 7 seconds. Release for 5 seconds, then hold it down for 7 seconds and release. it'll go black and then flash Ford. Press the odomotor switch to cycle through modes from there.
2000 AU II FAIRLANE 75th ANNIVERSARY - big and shiny My hovercraft is full of eels! Movie Car Chase of the Week: Gene Hackman driving a 1971 Pontiac LeMans to chase an elevated train in The French Connection (1971). |
04-08-2009, 03:19 PM | #20 | ||
The Monty
whats the point of it tho? like what could u do while in the d-mode?
04-08-2009, 06:35 PM | #21 | ||
ROCKING THE EL FUTURA
did it in the first go i used my watch first time, but as brad said whats the point.
BA MK11 XR8 ENFORCER NOW SADLY GONE My build that was http://www.fordforums.com.au/showthread.php?t=11267696 ENVI BA XR6T BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX NOW A EL FUTURA EB MONTY NOW IN THE SHED BACK IN THE E-SERIES THREAD DIGGEr |
27-09-2009, 10:52 PM | #22 | ||
Cruising...
so this works on all AU's??
and is there any chance of buggering it up..i have a knack for stuffing up electronics |
27-09-2009, 11:06 PM | #23 | |||
27-09-2009, 11:16 PM | #24 | ||
Cruising...
haha not exaclty, would be a long story :P, but seriously though, it works accross the range?, including the povo pack?
err...low end clusters?? |
27-09-2009, 11:37 PM | #25 | ||
yep i'm guessing all clusters..theres nothing you can screw up.
27-09-2009, 11:41 PM | #26 | ||
LIFELONG DJR SUPPORTER
not certain on AU I
28-09-2009, 11:06 AM | #27 | ||
Flairs - Truckers Delight
Aha, got mine going last night after about 9 attempts. Very very awesome.
28-09-2009, 06:21 PM | #28 | ||
Cruising...
Just got mine to work, first time round
nice bit of tech. |
28-09-2009, 07:14 PM | #29 | ||
does it stay on or go away?
28-09-2009, 07:28 PM | #30 | ||
Cruising...
It stays on till the battery gets disconnected or a system relearn/boot is done.
Thats what ive heard anyways. |
