#31 | ||
#32 | ||
#33 | ||
I got em on my WS Fiesta, they're a good grippy tyre
#34 | ||
I recommended them to my sister when she needed new tyres on her Swift. Wish I hadn't because they are very noisy..
2013 Ford Focus ST
#36 | ||
So grippy but noisy hence the varying comments?
#37 | ||
Has anybody found speakers 7 & 8 on the 8 speaker system in the ST, can only see 6 myself, 2 in each door and the 2 in the back seat???
#38 | ||
I have a question. Any know if the shifter cable can be tightened up at all? I've noticed quite a bit of shifter wiggle. Or at least more than I'd like to have!
#39 | |||
Have a look if there are tweeters combined in the two in the back. They may count any double up in the space as extra speakers. |
#40 | ||
#41 | ||
It's not massive amounts. I don't think mine is any worse than how it is brand new. There is some wiggle in the shifter, and I'm sure everyone will say so. I've sat in three STs, and it was present in all. It's also present in the Focus ST.
I really like the shifter to be tight, with no wiggle. I've found some steel bushings from JBR that are for the Focus ST. It's supposed to do exactly what I said: tighten up the shift. I just don't know if they fit the FiST, but seeing as though they are the same gearbox, they should. |
#42 | ||
Da Shifty One
Im about 1000kms in after 4 days ownership, but havent had a chance to check out the tyre pressures. Will give Front 37/Rear 33 a go, but will check what they were on before. I have a funny feeling it is 45.
I spent last night reading up on the user manual and have two things I cant figure out: 1. There is red light covers on the rear of each door. I assume these turn on somehow, when the doors are open? Are they meant to turn on or is just a reflector?? Mine dont illuminate. Can find anything in the manual or going through the vehicle settings. 2. The manual mentioned something about if the windows are open and you turn off the car then lock doors they will go up or down by holding one of the remote buttons. Like an auto open or close fuction. Either it was too early in the morning or im retarded it didnt work. 3. When I turn off the car, the radio will still stay on. Not sure it it will auto turn off when i exit the car and lock the doors. Any help is greatly appreciated. |
#43 | ||
Running recommend tyre pressures of 36/26 at the moment, feels alot nicer than when it was 45 all round, especially goin over those "Sleeping policemen" !!
On the lights in The doors, they are only reflectors, do not illuminate on mine. With the windows and the key fob, pressing buttons does not open/close windows, unless somewhere there is a setting for this to operate. I had an 02 zetec Focus in the past and that was 1 of the features on that car where windows and sunroof could be opened/closed with key while unlocking/Locking the car. Stereo in mine turns off when you kill engine and open any door. 1000ks in 4 days, have had mine 10weeks and not at 1500ks yet! Working 5 graveyard shifts a week don't help! |
#44 | ||
Da Shifty One
Hmm ok would have been nice if those red reflectors illuminated. The window thing i will need to check the manual again as im pretty sure it mentioned something about an auto close. Ill report back later. With the radio it definitley doesnt turn off when the engine is off. Will suss out later.
#45 | ||
I tried the auto open/close windows but couldn't figure it out either. Perhaps a feature on the US model only as they get plenty of stuff the Eu model doesn't.
Couldn't find an option for it in the vehicle settings By the way I tuned off hill start assist as it holds the brakes far too long and it causes bunny hops every time. Anyone know how to accelerate off from hill start assist without bunny hopping? I couldn't work it out. |
#46 | ||
Anyone waxed their car yet and what did you use?
#47 | ||
I got nanolex paint prot put on instead.
#48 | ||
Meguiar's NXT Generation Tech Wax 2.0
Been a Meguiar's user for nearly 20 years - good stuff...
New: Fiesta ST in Molten Orange - Even bigger Ear to ear grin!! As Top Gear said: "This is EPIC!" Richard Hammond (Again): "It's supurb. It's the biggest grin maker I think the world has ever seen..." Old: BF MKII F6 #00390 in Breeze. Sunroof, 19" Dark Argent wheels, Reverse Sensors, Electric Pedals, Leather, FPV Mats... Ear to ear grin!! |
#49 | ||
Da Shifty One
Been through the manual and it does have a section on the Global Opening/Closing on Pages 48+49, but it may only be applicable to 4 door cars. I tried it but nothing.
Edit: Searched a few other forums and it doesn't work on US or Euro spec ST's. But can possibly be programmed via the ODBII port. Manual also doesn't mention anything about the radio turning off, as per my question in above posts. Can anyone else confirm if it is the same for them? Last edited by MISTA FIESTA; 20-11-2013 at 08:44 AM. |
#50 | ||
Turning off the engine does not turn off the radio. Opening the door does.
#51 | |||
When you kill the ignition, the radio goes on a timer and will turn off itself. (Haven't timed it but somewhere between 5 & 10 mins) Otherwise it turns off, when either passenger or drivers door is opened. Another feature I found while doing some investigations, is a tyre pressure monitoring feature found in the menu, should alert you if a tyre begins to loose pressure!! as long as you activate it when the tyres are inflated to where you want them! |
#52 | ||
Gentle acceleration is the key here, but if you want to floor it of the line every-time, I would suggest leaving it turned off!
#53 | ||
Da Shifty One
Ok looks like mine isnt a hybrid in regards to the Radio thing. I tried it out this morning and radio turned off when I opened the door.
Yeah i stumbled upon the tyre pressure sensor thing also. Might need to redo it after checking the pressures. ie the 45PSI issue. The hill start assist takes a bit of getting used to, but i think i got it down pat now. Works well as a launch control too. |
#54 | ||
Molten Orange Maniac
Hello everybody have been talking to a ford engineer mate about the tyre pressure monitoring system, the way it works is it watches the wheel rotation speed via abs sensors and he said that it only realy tells you the tyre is flat, it will NOT let you know that pressures are a bit low as it does not see small differences in rotation speed
Mrmavx |
#55 | ||
That's the same system most manufacturers use. They count tyre rotations. They usually work pretty well, or at least the VW system does. A drop in 5psi and it would light up the warning sign on the dash.
I don't think it will trigger off a flat only. Otherwise it's a pretty useless system. |
#56 | |||
When I had the new wheels fitted (day 4) the alert went off about 2 kms up the road. I did the reset trick thinking maybe the pressures were different but no change. Most of these systems work using a wireless pressure monitor in the valve - this is why changing wheels and tyres meant I had to disable this feature.
#57 | |||
mrmavx |
#58 | ||
How do people rate the Bridgesrone Potenza RE050A that come on the car? How do they compare to other tyres available on the market? I don't find them overly noisy but it's hard to compare when I've only had these tyres on the car. Grip seems fine in the dry but I have had plenty of wheel spin in the wet.
#59 | ||
Da Shifty One
I have found them pretty good in the wet, especially on a rainy day through Canberra's twisties. Going about 20over recommended it gripped well but one some occasions it would slip a bit. In the dry absolutley superb. I am a Bridgestone Fanboy and have used RE001 & RE002's in the past with no faults. These were replacement tyres from the OEM Pirelli P Zero Neros on the XR4. The WT fiesta comes with Conti Contact Sport 3's which were also pretty good but after 20000kms they lost any grip in the wet. If I were in need of new tyres for the ST i will be going either the RE002's in a 215/40R17 size.
#60 | ||
Will wider 215 fit on the stock rim???
