Old 29-05-2006, 10:37 AM   #1
nat_daly
Nat D
nat_daly's Avatar
Default ABS light constantly on
hi all,
the abs light is constantly on in my ED and its not functioning, now im led to believe it's just a fuse, however i cant find the ABS fuse, where is it located? does anyone know?
thanks for help
old ride#1: ED XR6 5 speed-gone to new home:(
old ride#2:dumped EL fairmont 5l
new ride: Winter white AU2 XR8-manual
nat_daly is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2006, 01:05 PM   #2
nat_daly
Nat D
nat_daly's Avatar
nobody knows huh?
Old 29-05-2006, 01:34 PM   #3
GOLDIE
Next to the battery there is a seires of large fuses the one marked alb is the one you want.
9 times out of 10 it is not the fuse but the abs unit under the lh front gaurd.
Ian
Acid rush txr6,5.1 surround sound,350 rwkw's,major interior trim work.
GOLDIE is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2006, 01:41 PM   #4
nat_daly
Nat D
nat_daly's Avatar
is that on an ED tho?
Old 29-05-2006, 03:32 PM   #5
nat_daly
Nat D
nat_daly's Avatar
just found the problem.. the wire has snapped leading to the fuse from the battery.. i have temporarily connected it up, where would i be able to pick up a new wire/cable?
Old 29-05-2006, 03:36 PM   #6
GOLDIE
That wire you are talking about is a fuse link it is blown so something must have caused it to blow.
As for replacement either ford or a auto electrian should be able to help you.
Ian
Old 29-05-2006, 03:39 PM   #7
nat_daly
Nat D
nat_daly's Avatar
should i keep it attached or not?
cuz i just attached them back together and the abs light is not on and its working now
the wire looks very old and stuffed, it might just be cuz of age?
Old 29-05-2006, 03:55 PM   #8
BlackLS
Replace the wire with a fresh one. Make sure your fuse is still good.
Thread Tools
Display Modes
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
