13-11-2005, 01:02 PM | #1 | ||
Crusin
as i am trying to lower my EL at the moment and i am going to put other springs in it can someone please give me a run down on how to do all of it at the moment i am finding it hard to remove the original spring and i dont know what to do could anyone help me please
If you live in usa check this website: Cvs weekly ad. |
13-11-2005, 01:14 PM | #2 | ||
what stage are you at ? are you doing the rear springs first or the fronts ? Have a read of this thread should explain how to do the fronts. The rears are easy as, i think someone explains it in that thread.
http://www.fordforums.com.au/showthread.php?t=20880 |
13-11-2005, 01:16 PM | #3 | ||
Crusin
im starting of with the back thanks for the thread mate
13-11-2005, 01:17 PM | #4 | ||
also if you're doing the fronts without spring compressors DO NOT remove the top shock nut untill you get the assembly out of the car. Once it's out get up against a wall and put something infront of the top nut while you slowly undo it ( i used an old seat cover) this will stop the nut going flying off when it pops off.
13-11-2005, 01:52 PM | #5 | ||
You take the top seat off standard springs without compressing the spring!?!? Got more guts than me....
Current Rides: 2012 KK Jeep Cherokee Limited CRD - Still going strong 2019 MG ZS Essence 1988 RD Mitsubishi Colt GL - 59kW of Fury 2022 Kia Stinger GT |
13-11-2005, 02:40 PM | #6 | ||
Driftin shopping trolleys
mmm ud think it shoot out pretty bad... but i did it the same way on my car and there was barely any excitement at all it simply just fell apart.
13-11-2005, 02:59 PM | #7 | ||
yeah it comes off with a little bit of force, but as long as you're prepared for it she'll be right.
13-11-2005, 03:07 PM | #8 | ||
Shoot.
LOL I can see the thread now, "I lost an eye removing the front shocks." It's best to be safe and just buy a set of spring compressors for $30 or so to do it properly.
20V Turbo |
13-11-2005, 04:51 PM | #9 | ||
Front spring removal = bench vice + blankey :P
13-11-2005, 05:02 PM | #10 | |||
Now Fordless
13-11-2005, 05:28 PM | #11 | |||
13-11-2005, 07:59 PM | #12 | ||
I too changed my springs on my own, and have seen a couple of others done this way. If you're carefull then there's no dramas. I don't know how you'd cop a spring in ya face. There's not much force at all.
But yeah if you don't know what you're doing or you're a soft **** get some compressors. :P |
13-11-2005, 08:32 PM | #13 | ||
El-M, I would take the fronts somewhere to have them removed and put back on. The tool that most Ford dealers have make it SO easy to do and they can make sure the top plate goes back in the right place. Mark the Shocks too to make sure they go back in the same place and same side that you took them out of
BTW, it isnt being a soft **** to do the thing PROPERLY. Most who dont do it properly are future victims of self inflicted injuries. |
13-11-2005, 08:34 PM | #14 | ||
rofl copter
spring compressors can be more dangerous... wen they are fully compressed they are under more force then anything, and if they do happen to snap (like what happened to my brother) then ull be in alot of crap because the compressor will blast off and if ur lucky itll miss u... then u have to worry about the spring, pay somone to do it and supply the springs is my suggestion
GQ patrol.
.... thats all |
13-11-2005, 08:59 PM | #15 | ||
^^^exactly, I'd rather one tiny little nut come off then a big **** spring compressor. I am happy that my springs have been installed PROPERLY, and not by some mechanic who may have missed something here or there. I've seen this happen.
Anyways this is going off topic. ELmalaca did you get your springs in ? did you use compressors ? :P |
14-11-2005, 07:42 AM | #16 | |||
The only way I can see it being dangerous if if you were to undo the little nut while it was directed at your face. Just lie the spring assembly on the ground and have something ready to catch the nut. Spring compressors take about 5 times longer.
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
14-11-2005, 06:26 PM | #17 | ||
Crusin
thanks for all the advice guys i will let u;s know how i go with it when i get some time to actually do it cheers
14-11-2005, 08:08 PM | #18 | ||
Two > One
I thaught i was dodgey
14-11-2005, 08:18 PM | #19 | ||
Dodgy? Dodgy is cutting a half-coil off superlows. Which I'm about to do.
1998 Ford Fairlane - 4.0L
18x8 RJR rims - Tinted - King Suspension - 2.5" D&T Cat Back Exhaust |
15-11-2005, 12:11 AM | #20 | ||
BASS ON BOARD!
go the grinder!!!
lol. I always get my mods done by my mechanic. it may cost me slighly more (mates rates) but i know its done properly and that its going to be reliable. and if i have any dramas he will know exactly what it is. dont ge me wrong im all for doing things myself hence why i pulled the dash out to remove the pedal box to weld the clutch pedal on. i guess if you use occy straps in the engine bay for what ever reason the system will only be as strong as the occy strap. im sure this is so far off the origional thread but oh well, we all get carried away at some stage :
Nothing interesting to put here. |
16-11-2005, 08:46 PM | #21 | ||
Fairmont6
do yourselvlves a favour and buy some spring compressors, i worked with a bloke who lost his thumb and pointer finger on falcon springs. it was under diff circumstances cause the strut had fallen apart and he was pulling it out the car with no top nut left. if u seen what i have ull pay the extra 30 bucks for some compressors, all i bodge job fellas take note
18-11-2005, 04:52 PM | #22 | ||
On here daily
hey, i have king spring lows on my car and i wanna change the fronts to super lows cos the back sits too low for the front. would i need spring compressors again or will the springs be short enough just to drop over the shock. i have lowered GT monroe shocks.
JIM |
21-11-2005, 05:09 PM | #23 | ||
Crusin
hey guys i have successfully lowered the back of my car and all is good sits good but now the front is too high and i was just thinking is it pretty much the same procedure when changing to front springs or is it hard ??? can someone please tell me and also give me some advice on how to change these springs and also can someone tell me what shockers i should get and how much the will set me back thanks guys
Andrew |
21-11-2005, 05:47 PM | #24 | |||
Shoot.
I wrote this if you did the back then you can do the fronts.
20V Turbo |
Thread Tools | |
Display Modes | |
