Site Support If something isn't working or you have a suggestion ( a nice one !! ) let us know here. |
17-08-2021, 11:57 AM | #1 | ||
Hi Team,
What is the best code reader for an EL XR6, I have seen the a link (attached) for a particular model and was looking for opinions on the best type to purchase. https://www.tiperformance.com.au/pro...c-code-reader/ |
22-11-2021, 06:35 AM | #2 | ||
XB,XF,ZL,EA,EL,BA,SY,SZII
Depends on how you define "best". In lieu of $270 for the linked reader, I would rather make my own LED test lamp and count the flashes myself for about $5.
22-11-2021, 06:56 PM | #3 | ||||
Regular...with metamusal
i bought mine thru fordmods. still have to use it on the EB i'm too slack to bother counting |
22-11-2021, 07:07 PM | #4 | ||
From memory the plug that you need to make your own led code reader is the same as the main power window wiring plug
Money Talks, but all i ever hear is it saying Goodbye!! |
22-11-2021, 08:01 PM | #5 | ||
Re making your own adapter to use with an older Ford OBD-1 scanner (like this: https://www.summitracing.com/search/...=INNOVA%203145 or https://www.ebay.com.au/itm/17494936...frcectupt=true ) see my post here: https://fordforums.com.au/showthread...ht=code+reader an http://www.fordforums.com.au/photos/...2&ppuser=24537 and http://www.fordforums.com.au/photos/...2&ppuser=24537 and http://www.fordforums.com.au/photos/...3&ppuser=24537 It's one of the BCM harness plugs (the lower one) that fits the OBD port. You also need a female OBD socket either taken from an earlier model such as an EA or bought online (one of these https://www.repairconnector.com/prod...r-Pigtail.html )
regards Blue Last edited by aussiblue; 22-11-2021 at 08:30 PM. |
22-11-2021, 08:44 PM | #6 | ||
Of course when I made my adapter I already had a Innova 3145 and (bought for US$20.00 when the Australian dollar was at it peak) I had been using with my NB Fairlane (ex Ford Prototype based on the NA) on hand as well as plenty of BCN sockets, rotary switches, on/off switches, project boxes and the like floating around (as I still do) so my only outlay was on the BCM plug and the OBD1 socket. It probably cost me all of $20.00 out of pocket.
regards Blue |
23-11-2021, 08:29 PM | #7 | ||
That adapter of yours really is a work of art aussieblue. A bit like a Jackson Pollock, but art nonetheless! I used to just connect the test lamp wires and jumper wire directly to the pins in the OBD socket. Of course that meant I had to keep a pin-out diagram handy to know which ones to use.
23-11-2021, 11:55 PM | #8 | ||
24-11-2021, 12:48 PM | #9 | |||
regards Blue |
24-11-2021, 01:44 PM | #10 | ||
26-11-2021, 06:19 AM | #11 | |||
03-01-2023, 10:37 PM | #12 | ||
I think the answer to the extra pins on the diagnostic connector is here https://www.fordforums.com.au/showthread.php?t=11316133 Likely a remote start facility.
regards Blue |
Thread Tools | |
Display Modes | |
