Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Blue Power Racing Developments
Blue Power Racing Developments The home of Blue Power. Website Link
Old 01-08-2011, 10:27 AM   #1
Theo@BluePower
Bluepower
Theo@BluePower's Avatar
Default **ZF tuning software is here**
After a detailed course run by Herrod's on the weekend we can offer the ZF trans tuning, Herrods has gone out and found what not to do and what to do with the ZF transmission.
This will speed up the process for all the tuners that attended there course as a lot of the R&D time has been done via Herrods and i am sure we are all very thankfull for there input.
The transmissions and their operation via a 32bit motorola processor is not quite what we expected, and operates in a different manner to what we thought it would.
To all our customers that have ZF transmissions we now can fix all the issues we all been wanting to do.
Eg:
Charles FG XR6T - That thud when coming to a stop when going into first.. now can be fixed.
Garry BF GTP S/C - Lazy 6 Spd auto... can be fixed
This software is still new to all us tuners, there is going to be still lots of R&D done by us all.
This software is very complex and not a 5 minute job like the good old 4 spd was and for this reason there will be a cost involved in tuning a 6spd auto.
This week we will be testing some of our cars to test the softwares limits as after a change has been made we need to travel about 100km for all the changes to take full effect. This is why some of you that have had there cars reflashed by ford say there car feel's a lazy, As the auto is relearning you driving style..
Also, New tuning prices for vehicles with ZF6spd tuning required as part of the calibration will be revised.
Please phone us on 9305 3000 to see how this software will benefit your particular application, and what cost's will be associated.
Bluepower website
47 Cooper Street Campbellfield Vic
03 9305 3000
Theo@BluePower is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2011, 12:55 PM   #2
xpl0sive
Default Re: **ZF tuning software is here**
Awesome news guys, been waiting for you guys to announce this ever since Herrod announced it's release. Will be giving you guys a call soon.
Cheers,
Nuri
xpl0sive is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2011, 08:27 PM   #3
Herrod Motorsport
www.sctflashtuning.com
Herrod Motorsport's Avatar
Currently the accredited Herrod SCT ZF Transmission tuners can adjust the following characteristics of the 6HP26 transmission –
-​TCM based vehicle speed limiting
-​Shift schedule, which allows changing transmission shift points and how long the
​vehicle holds onto each gear in all transmission modes
-​Kick-down sensitivity
-​Change of shift pattern for differential gear changes
-​Manual mode downshifting
-​Eliminate holding second gear till standstill
-​Adjust torque converter stall settings
-​On-coming and Off-going clutch shift behaviour for built transmissions
-​Running Line Pressure for high power applications
-​Shift pressure per shift event based on actual gear
-​Maximum shift time and amount of slip for each shift
-​All of these pressure and time/slip settings are discrete for up-shift and downshift
-​Torque limits for general transmission operation
-​Torque reduction for each shift event
-​Maximum transmission torque capability for built transmissions
-​Torque characteristic to adapt for different viscosity transmission fluids
This is a brief point form description of the kind of effects and results that can be achieved via adjustment and calibration of the several hundred files in the transmission
Australia's No1 Ford Enhancement Specialist
103 Northgate Drive
Thomastown
VIC 3074
Phone: 03 9464 5100
Fax: 03 9464 5166
Herrod Motorsport is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2011, 09:30 PM   #4
cjf
GT Hardcore
cjf's Avatar
Its going to be interesting to see what the results are with this new software.
BF GT - 6spd ZF Auto - 292.8 rwkw 1/4 mile 13.385@ 108.32mph @ Willowbank 5/03/11. in Qualifiying STREET SERIES ROUND 7
http://www.fordforums.com.au/showthread.php?t=11295036
Cragsted Race Engines -http://cragsted.com.au/
BPR CAI , PACEMAKERS 4-1, BALLISTIC 100cell RACING CATS, CROW CAMS GTP,
K LINE , XFORCE ,PSI VALVE SPRINGS, MANLEY H BEAMS, SRP PISTONS & RINGS, ACL RACE BEARINGS MELLINGS BILLET OIL PUMP, POWERBOND UNDERDRIVES, TT1-160 THERMOSTAT.
cjf is offline   Reply With Quote Multi-Quote with this Post
Old 02-08-2011, 12:00 AM   #5
Gonz
BA XR6T UTE - ANIM4L
Gonz's Avatar
as long as they know what not to do we'll all be thankful, well done Herrods, thanks heaps for the effort and work you have put into it, well done for the maner in which you have rolled it out too.
Gonz.
BA XR6T"ANIM4L" UTE UNDER CONSTRUCTION!
WA Member of proUTES.com : we need more FORDS!!
CHECK OUT MY OLD AU UTES!! IN HERE!
CHECK OUT MY OLD FG UTE!! IN HERE!!
CHECK OUT MY LATEST BA UTE!! IN HERE!!
YOUTUBE POWERCRUISE VIDEO!! CLICK HERE!!
YOUTUBE INCAR VIDEO!!CLICK HERE!!
Gonz is offline   Reply With Quote Multi-Quote with this Post
Old 06-02-2012, 02:10 AM   #6
soulink
i know this is an old thread but can't see any newer, what is the status on it now? Have you guys done alot of testing and are comfortable with tuning the ZF now? also if i have a 6sp ZF in a worked xr6 N/a that currently will run a 13.8 the way it is now, will a tune on the trans actually make a difference?
Thanks
soulink is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2012, 02:29 AM   #7
Redrum
Force Fed Fords
Redrum's Avatar
Bluepower are tuning ZF's. I drove a FG Turbo with 350rwkw with tuned auto, I liked it.
2021 Focus ST-3 Mountune Enhanced
Redrum is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2012, 01:18 PM   #8
Theo@BluePower
Bluepower
We have been tuning 3-4 ZF's a week since the software came out..
At this stage we have not seen one issue with the way we have been tuning them..
We have a lot of cars that we are pushing harder still testing with more aggessive settings for drag racing in 400+kw cars.
Alot of the other tuners have been breaking input sharfts with 300+kw cars which is why we tread a lot more carefully with your investment..
Bluepower website
03 9305 3000
Old 13-04-2012, 02:37 PM   #9
MWTB
I'm old and I fell
MWTB's Avatar
I called up earlier today regarding a tune and had Chris on the phone for about 10 minutes so I didn't want to call up and bother you again, but what do you guys charge for a ZF tune? Also having a custom tune done. Cheers.
BF2 XR6 turbo
82lb injectors, Walbro fuel pump, bigger cooler, Plazmaman piping, SS Growler, tune, ZF tune, Crow valve springs so far.
Ozracing coilovers, Pedders sway bars front and rear.
315rwkw
MWTB is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2012, 08:52 AM   #10
Bluepower
KenneBell Australia
Bluepower's Avatar
We'll sort something out with you mate since you are travelling so far.
Chris
Bluepower Racing Developments
Proud Australian Distributors of Kenne Bell superchargers
The Quickest, The Fastest, The Baddest Boss Blower of all.
www.bluepower.com.au
Bluepower is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2012, 08:05 PM   #11
56FTRUCK
Does this allow the zf to be fitted to older cars, I'm told until this nsoftware is available it's not an optin
56FTRUCK is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2012, 09:41 AM   #12
Theo@BluePower
Bluepower
The only way this could be done but i could be wrong is you need to have the ZF, Engine and ECU from the same car and then put all that combo into the car and it can be done .. as for putting a ZF not using the factory ECU i dont think it will work as the ECU and ZF are paired
Bluepower website
03 9305 3000
Old 16-05-2012, 06:45 PM   #13
56FTRUCK
Well thats better info than i had, i got toldthere was a lot of info that thetcu gathered from sensorsin the car that need to be turned off
Old 13-06-2012, 12:13 AM   #14
56FTRUCK
Is this a job you gents would embark on at all ?
Old 14-06-2012, 11:15 AM   #15
Bluepower
KenneBell Australia
Bluepower's Avatar
Its a wiring job that we would not take on, if we recieved the car in running order, we could re calibrate, but conversions of this nature are not something we do as a rule.
Chris
Old 05-07-2012, 10:12 AM   #16
my_gxl
Unintended Perfectionist
my_gxl's Avatar
I am thinking of getting my ZF tuned when I get an engine tune tweak in a few weeks at Elite.(after fitting one of your air boxes). Any tips/questions I should be asking?
Mostly street driven in D, however I tow in perf, and run around lakeside raceway in manual.
Can the shift programs in D be left alone, perf auto firmed a little, and manual be made firmer?
Also I saw below that the stall speeds are adjustable. How far up can the minimum RPM that the engine can be before drive gets transmitted,ie could the lower limit be raised so that the car won't move until 1000rpm? I assume that would also lift the stall speed, which is ok as i will run it at the drags some time just to see what it does.
my_gxl is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2012, 03:46 PM   #17
Burts21
Burts21's Avatar
has blupower racing tuned many supercharged gs falcons with the ZF?
FPV P001 FG GS,Nitro 357 RwKw
Burts21 is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2012, 05:29 PM   #18
Herrod Motorsport
they sure have
103 Northgate Drive
Thomastown
VIC 3074
Phone: 03 9464 5100
Fax: 03 9464 5166
Old 26-10-2012, 06:08 PM   #19
anolade
trigger happy
my gs ute has been into the bluepower racing shop and came out a beast
2011 FPV GS ute Sunburst build no 202
manual leather seats car mats
376rwkw with defilipo catback Air filter CAI
enhanced by team at Blue Power Racing Developments
Now sold off and no longer owns a ford
anolade is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2012, 05:11 PM   #20
Burts21
Burts21's Avatar
sweet
what was did u get changed in the auto tune?
did u have your engine tuned before u got your ZF tuned?
Old 18-04-2014, 08:58 AM   #21
Bonn
Bonn's Avatar
FYI - have just posted a new thread about my ZF issues (surging, jerking hunting) and wondered if anyone in Sydney does this tune??
cheers
Bonn
FG Falcon Ute
Daily: E-Gas 4.0 I6, 3 seat 1 tonner, 2300kg Tow Pack, Carryboy, XR6 rims.
6 Stacker, Sat Nav, Reversing Camera, Sunnie Holder, XR dash & St Wheel - thanks Mr FPV!
Jaguar XJ-S: Eaton S/C, I/Cooler, Haltech, DB7 rims, 1:15 Wakefield.
Jaguar XJ6 Wife's daily :2006 Quartz Metallic, FORD Duratec 3.0 V6, ZF 6sp
Previous relationships: FG GT, FG XR8 (+BA XT 5.4, BA AU, EF, EB, EA, EA & XF work cars)
Jags XJ12 & XJ6, BMW E39 Wagon, BMW F11 M-Sport wagon, 20 of GMH FC-HQ
Bonn is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2014, 12:28 AM   #22
Blinks_e85
Theo, just wondering how exactly to get rid of the clunk when going back into first, or when lifting off before a change and it still bangs into the next gear. I am getting my zf tune done soon and the more info I can give my tuner the better. Thanks
Blinks_e85 is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2014, 09:19 AM   #23
Theo@BluePower
Bluepower
Your tuner should know how to fix this issue.. If he doesn't you might want to look somewhere else as the last thing you want is a broken ZF.
Each tuner tunes cars differently so what works for us may not work for others...
Bluepower website
03 9305 3000
Old 23-07-2014, 09:26 AM   #24
Blinks_e85
I haven't mention the thud issue just said I want a tune. Was going to run through any finer details when I drop the car off. I have slight pinion backlash too so that's not helping either.
