Old 31-12-2007, 03:14 AM   #1
b2tf
not here much anymore
b2tf's Avatar
Default AU V8 models: Basic questions answered!
In an attempt to avoid the same threads coming up weekly, here's a few tips/answers/comments about the AU V8 range.
Q: How do I tell if my XR8 is a 200 or 220kw model?
A: There is only one 100% foolproof way to do it, and that is to call ford with your vin and verify it. The number is 13FORD.
The other ways are looking for the following features:
* "220" Badge on rear bootlid
* Tickford wings engraved into throttle body
* Colour Coded Exterior Mirror Scalps
As a general rule, 220kw motors were introduced into AU XR's from April 2001. This means late Series II models, and all Series III models got the 220kw donk.
NOTE: This does NOT apply to XR8 Utes, where the maximum engine power available from factory was 200kw. No ute ever had the 220kw engine factory fitted. Again the April 2001 date is correct to identify your ute and determine whether it is a 185 or 200kw version, the 185kw utes also have a spacer between the throttlebody and the intake manifold. If your ute has the spacer there, it's a 185kW spec engine. If it doesnt, you've likely got a 200kw motor.
Q: How much power does my XR8 have? Its a Series I.
Power Outputs for the entire AU XR range were as follows: (from factory)
AU Series I, Sedan and Ute: 185kw
AU Series I, NON XR Sedan and Ute: 175kW
AU Series II, Sedan: 200kw (late April onwards 220kw)
AU Series II, Ute: 185kw (after introduction of Pursuit model, 200kw)
AU Series II, NON XR Sedan and Ute: 175kW
AU Series III, Sedan: 220kw
AU Series III, Ute: 200kw
AU Series III, NON XR Sedan and Ute: 175kW
The exception to this is that the AUII onwards V8 LTD models did have 185kw, with the difference being made up primarily from a twin system exhaust fitted to that model.
Q: What model got the 5.6L stroker engine?
This engine went into Series III AU models known as T-Series. There were 4 models - TE50, TS50, TL50 and a ute model known as the Pursuit250 (although this was technically just an XR8 with a bigger engine). These models can be identified by their bodykits, bigger engines, 18" alloy wheels, brembo or tickford premium brakes (both were available), and in the case of the sedans, a build plate in the engine bay stating the model name and number (Utes did not get this).
More info on the T-Series range can be found in the T-Series Room HERE
Q: What's the difference between a "Pursuit" Ute, and the rest of the range?
This is where it gets tricky. Ford released a model called the "Pursuit", which was an XR8 Ute (XR6 VCT utes were also available), with MOMO gear such as steering wheel and shifter, leather trim, Tickford Bodykit and Sports Bars on the back all included for an extra $1k. (The XR8 versions also had a 200kw motor as opposed to the 185kw regular offering, but after the introduction of Pursuit Utes the 200kw motor became the standard offering in all XR8 Utes). These were known and badged as Pursuit Utes, and are not to be confused with the Pursuit250 as described above.
Q: I own a V8 AU but its not an XR. How much power does it make, and what is different on the engine compared to a XR model?
For all non-XR V8 models the power remained at 175kw in all series except the AUII LTD as mentioned above. These engines have the same heads as the 200kw-spec motors (these heads are known as GT40Ps), same intake manifold (5.6L stroker has a specific manifold though, this is the only exception), but a smaller (65mm) throttle body and MAF sensor. Exhaust systems, particularly exhaust manifolds, also differed in design and were not as high-flowing as the XR types although the LTD models as mentioned got a twin exhaust system as standard.
Q: My car has a Herrod/SVO badge on it. What does this mean?
It means at some point the car has been worked on by an aftermarket company. Herrod and SVO are two of the biggest, and both did a lot of work on AU's. If you have the badges, best to call them and see what has been done.
Q: Can the V8's in AU models be modified and if so what can I do to it?
In a nutshell, yes they can be modified and you have a wealth of options seeing as the Windsor V8 has been in service for decades. Cylinder Heads, Cams, Manifolds and even Stroker Kits are all relatively easy modifications but they do require a bit of careful planning and a budget to work with. Exhaust systems and intakes are often the first mods that AU Windsor owners carry out and there's a wealth of info in these forums as well as the 'Workshop Builds' section. Also check out the Windsor V8 Forum HERE to see what other owners have done, and to get advice on what cam will be best for your car.
2015 VW Amarok 4MOTION, 6M, Tuned, Lifted and BFG'd
2016 VW Passat R Line Wagon, the family hauler
'97 EL GT - Burgundy, Manual, original
2016 VW Crafter MWB 6M - tuned, the work van
Old 31-12-2007, 08:12 AM   #2
Tickford Kid
Formerly known as TS 50
Tickford Kid's Avatar
Non XR V8s had 175kw engines.
BLUEPRINT T3 TS50 #109, MANUAL WITH BREMBOS
Tickford Kid is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2007, 09:41 AM   #3
LPGUTE
LPGUTE's Avatar
Ya i remenber V8 was a 175kw. a good write now i just need to get a V8 to compared it lol...unless... i'll have to use my house mate V8 lol.
Many Thanks
2001 AUII Factory LPG Manual XL Styleside Box
High series bonnet
Clear Side Indicator
K&N Air Filter
BAXR6T Snorkle
Low Fronts, Super Low Leafs
LPGUTE is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2007, 11:25 AM   #4
b2tf
b2tf's Avatar
Bugger it I KNEW that wasnt right, was looking at it as I wrote it. Ta!
Old 31-12-2007, 01:13 PM   #5
TICK4D-TAS
Club Moderator
With the 200kw motor, the Left cylinder head will have '200' stamped on it.
As Austin has said, the easiest way to check is to call Ford. The t/b and badges can be put onto any car.
Also the 220kw motor got an engine oil cooler and runs the smaller oil filter, as where the 200kw motor doesnt have the cooler and runs the standard Ford oil filter.
2002 T3 TE50 Racecar
2002 T3 TS50
2010 FPV F6 Ute
2015 PX2 Ranger Wildtrak
2016 FGX XR6 Sprint
TICK4D-TAS is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2007, 01:18 PM   #6
Kryton
Kryton's Avatar
AU LTD's had the 185kw engine.
all other non XR models were 175kw.
http://www.drive.com.au/buy/market_v...&body=4D+SEDAN
Kryton is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2007, 02:24 PM   #7
JC
JC's Avatar
While we're picking, the XR8 utes on 200kw guise would have had the EGR spacer as well - all 200kw motors did. The 220 is the only one with a single solid TB/EGR setup.
Austin - as a moderator, can't you go back and edit your original post? I think it's worth doing because anyone that reads it will go, "Oh, OK, so that's the story", only to read further down and find all the corrections, which then makes people question the correctness of any info posted in a "one stop Q & A" type thread. I'd correct it with the right info, delete the below corrections, then close it so it's a one post thread (oh, and sticky it)!
FOR SALE: Pioneer AVH-X3800DAB
The Hammer: FG GTE | 376rwkw | 1/4 mile 11.946 @ 118.71mph 1.797 60'
The Project: FG GT 5th anniversary Black
The Daily: 2001 Mercedes C180
Old 31-12-2007, 02:28 PM   #8
Kryton
Kryton's Avatar
maybe leave it open for a week incase any other info comes along.
Old 31-12-2007, 02:37 PM   #9
peterban
AULTD
peterban's Avatar
What differences are there in the LTD motor that gave it the extra 10 kw?
peterban is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2007, 02:48 PM   #10
b2tf
b2tf's Avatar
JC I would but i cant mod AU forum.
We'll get the right info going, then I'll re-write the lot and get rid of this thread, and sticky one up. After that I'll have a go at doing the 6 cyl models.
Old 31-12-2007, 02:50 PM   #11
JC
JC's Avatar
Basically twin 2" system, instead of single 2.25" on the Fortes etc.
Old 31-12-2007, 02:54 PM   #12
Tickford Kid
Didn't know that. Learn something new everyday.
Old 31-12-2007, 03:56 PM   #13
DJM83
DJM83's Avatar
I was going to suggest that Aust, this question has been asked a zillion time. An I6 one would be good to, but us V8 boys wouldnt know anything about that :
2011 XR6 Turbo Ute.
DJM83 is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2007, 10:26 PM   #14
Tech Trainer
Are you sure about that?
Tech Trainer's Avatar
Another way to tell if it is a 220kw is the 220s have an engine oil cooler mounted behind the grill.
When I grow up, I want to be half as good as you THINK you are.
Tech Trainer is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2008, 12:23 AM   #15
xr8ute
Back on the road
xr8ute's Avatar
So that would mean they had the tickford 4-1 pipes, and dual 2 1/4" catback exhaust?
xr8ute is online now   Reply With Quote Multi-Quote with this Post
Old 27-12-2008, 08:25 PM   #16
dreadly
My utes a series 2 Au xr8. Hand built 200kw, not 185 ;)
dreadly is offline   Reply With Quote Multi-Quote with this Post
Old 27-12-2008, 08:55 PM   #17
Peuty
Afterburner + skids =
Peuty's Avatar
This thread should be a sticky.
Daniel Peut Photography
AUII XR8 220 - Manual + V8 = skid time
Old 27-12-2008, 09:56 PM   #18
b2tf
b2tf's Avatar
I've stuck this one and made a few edits but any more info that we can come up with will be added provided it's correct.
Old 28-12-2008, 01:27 PM   #19
FTe_XR8
formerly "3x-puursui7"
i dunno if u wanna add this, but i had the issue with the wrong filter first time i went to service my 220. I did have the other brand part numbers but cant find them atm.
the K&N part# HP-2004
also this is the dimensions and stuff straight from their website.
Height: 4.1 in (104 mm)
Outside Diameter: 3.66 in (93 mm)
Thread Inside Diameter: 0.75
Thread Number: 16 UNF-2B
PSI Relief Valve: 8-11
Anti Drain Back Valve: Yes
all hail the mighty V8's
http://www.aufalcon.com.au/3x-puursui7
FTe_XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 28-12-2008, 04:31 PM   #20
b2tf
b2tf's Avatar
200 spec V8's take a Ryco Z9/Valvoline V01
220 spec take a Ryco Z89
Old 28-12-2008, 09:04 PM   #21
SSD-85
я звезда хардбаса
So the 220 au2 xr8 sedans didnt necessarily have the 220 insignia on the engine cover....?
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 28-12-2008, 09:37 PM   #22
Whoosha
AU DIE HARD
Whoosha's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Writing tech articles Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For all the things you do behind the scenes.
They all should have but it would appear some may have missed out . the confusion with the AU S2 220s is that it was a at cost option ($1200 from memory) in the later S2s not standard as some think , I ordered mine new in september for a late october to early november delivery , I was then informed in the second week of september that the 220 would be available as a option as it would soon be the standard motor for the S3.So we can only assume none were available before this date. the late S2s also came standard with side skirts, colour coded mirrors also a at cost option of the Rebel/race bodykit or the standard body kit these were both later optional on the S3..the 220 motor was fitted with a oil cooler as std. far as the utes go we tryed to get the 220 fitted to them but even with inside help had no luck myself and 5 other work mates and 2 family members all brought these cars at the same time so I can only asumme these are the facts. But as with most things thats not to say there were no exceptions to the rule. I still have all the original purchase order and options folder put away some ware .
Originally Posted by Riksta
Old 28-12-2008, 09:48 PM   #23
SSD-85
я звезда хардбаса
It's really strange, because mine has all the indictations of a 220 (incl. build date), bar the different engine cover.
Old 28-12-2008, 10:14 PM   #24
b2tf
b2tf's Avatar
Engine covers are easy to change so I wouldnt be relying on it to determine whether it's a 200 or 220 spec engine.
Old 28-12-2008, 10:15 PM   #25
5.0 ED
5.0 ED's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with sound technical advice. Technical Contributor: For members who share their technical expertise. - Issue reason: has helped a number of AFF members with their cars, particularly with EEC tuning
there was no 5.6litre TL50's produced i believe.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm.
5.0 ED is offline   Reply With Quote Multi-Quote with this Post
Old 28-12-2008, 10:15 PM   #26
Peuty
Peuty's Avatar
As b2tf said, engine covers tend to rub and get trashed easily, so it wouldn't be out of the question for it to have been replaced at some stage.
Old 28-12-2008, 10:17 PM   #27
SSD-85
я звезда хардбаса
I know, it's just odd that the decal isnt on it despite it being a 220 engine, just a curiousity
Old 28-12-2008, 10:23 PM   #28
b2tf
b2tf's Avatar
3 made, 2 accounted for on these very forums.
Old 28-12-2008, 10:36 PM   #29
tud184
Is the 347 the biggest stroker kit you can get for the 5ltr windsor
tud184 is offline   Reply With Quote Multi-Quote with this Post
Old 28-12-2008, 10:40 PM   #30
b2tf
b2tf's Avatar
No you can get 363 also
Thread Tools
Display Modes
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
