Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > Ford Coupe Club of Australia > Coupe Restoration & Build
Old 19-12-2013, 04:01 PM   #1
mr-mach1
mr-mach1's Avatar
Default Rear Window Louvers
Anyone sporting rear window louvers on their coupe ? I have a set of what I was told where Goss Factory louvers (?) which I'm considering installing. My concern it putting holes in the roof and sail panel to attachment as well as how they look installed. Anyone have pics of them installed ?
Thanks
Leon
mr-mach1 is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2013, 11:18 PM   #2
MR REKLAW
BF XR8 Ute
MR REKLAW's Avatar
Default Re: Rear Window Louvers
http://www.google.com.au/imgres?clie...7&tx=175&ty=75
Cheers Geoff
_____________
HIS
2006 BF MKII XR8 Ute,Shockwave Blue.
HERS 2003 LX Focus Sedan,Silver.
Past Rides:- XD Panel Van,XE Panel van,XF Wagon,ED Wagon,BA Fairmont.
Greetings Earthlings.
MR REKLAW is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2013, 08:43 AM   #3
JG65TE
JG65TE's Avatar
Got em on both our cars. Hoping to find one for the 3rd too. Mind you, ours are aftermarket aungers. Don't need to drill the roof. See if I have any pics from the back of the cars. I personally like the look but I am a bit old school
JG65TE is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2013, 07:42 PM   #4
CJR09
RPO 77
CJR09's Avatar
these are mine
had/have the aungers - they kept blowing off - at least the original bolt on and stay there - if you do the hinges properly they can be made so they will never leak if that is your concern
Q: If you have tried to sell it three times now and it is still not sold, do you think it might be over-priced?
A: It is over priced - just like all the other falcon coupes for sale!!
CJR09 is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2013, 05:33 AM   #5
mr-mach1
mr-mach1's Avatar
Originally Posted by CJR09 View Post
these are mine
Yes, leaks are a big concern. I have the rubber nut inserts for the front. What is done to keep the rear studs from leaking ?
Old 21-12-2013, 08:48 AM   #6
CJR09
RPO 77
CJR09's Avatar
I like the sound of your nut washer - are you able to Post a pic of that setup? - Don't worry found it Google my friend!
I use a captured nut with medium set liquid thread seal on the hinge
On the lower pass through bolts I use a large epdm commercial roofing washer
Old 21-12-2013, 09:04 AM   #7
CJR09
RPO 77
CJR09's Avatar
Looking at those rubber nut inserts - they could be the go on the lower pas through bolts as well
Take the rubber nut insert - delete the Internal thread and use a the washer and wing nut as per oem to clamp it tight creating the seal from underneath
Old 21-12-2013, 02:16 PM   #8
mr-mach1
mr-mach1's Avatar
I was thinkin of using a rubber grommet on the bottom.
Old 23-12-2013, 11:09 AM   #9
mr-mach1
mr-mach1's Avatar
Thought I'd post a pic of the rubber nut for the top louver screw.
