18-01-2019, 01:09 PM | #1 | ||
I recently had a mechanic tell me that it is impossible to over-tighten a hose clamp so much that it could cause a flange to break. This was after they replaced the radiator hose in my car, and the flange on the thermostat housing broke off (see pic.)
Seems unlikely to me, what do you think? Cheers. |
18-01-2019, 01:31 PM | #2 | ||
Cabover nut
I've broken a few new hose clamps over tightening. SS, mild steel.
Broken a alloy pipe flange under it over tighening one as well. New stuff seems to be chinese junk.
18-01-2019, 01:33 PM | #3 | ||
it would depend what you did it up with. A phillips head screwdriver will only let you go so far, but a 7-8mm socket can go a lot harder.
FGII XR6 IN LIGHTNING STRIKE R52 SIII IN GUN METALLIC |
18-01-2019, 01:53 PM | #4 | |||
But care should be taken not to overtighten hose clamps, otherwise they may fail too. |
4 users like this post: |
18-01-2019, 02:01 PM | #5 | ||
Mopar! But Own F6's..
Do you use coolant? Is it the proper ford coolant?
F6 TYPHOON FPV 335 GT |
18-01-2019, 02:07 PM | #6 | |||
regards Blue Last edited by aussiblue; 18-01-2019 at 02:24 PM. |
2 users like this post: |
18-01-2019, 02:46 PM | #7 | ||
18-01-2019, 02:47 PM | #8 | ||
18-01-2019, 02:49 PM | #9 | ||
Yes; plastic deforms then breaks.
regards Blue |
18-01-2019, 03:18 PM | #11 | ||
Always used TRIDON clamps. They don't cut into the hose like some other brands.
Should always be done up with an 8mm 1/4 drive until the worm drive binds. If reusing an old hose either switch the drive around 180 degees or trim if excessively swollen. |
18-01-2019, 09:42 PM | #12 | ||
Giddy up.
Hose clamp's should never be done up tight, let alone super tight.
Just firm, if the correct hose is used and in new condition then the clamp should only be firmly done, if you over tight them then you run the risk of future leaks. The clamp should be just positioned on the far side of the ridge on a housing and done firmly, people often over tighten clamp's thinking the tighter the better but in actual fact you squeeze/squash the hose and cause leaks. |
18-01-2019, 10:34 PM | #13 | ||
It's also good practice to put a thin layer non hardening gasket goo around inside of the hose end far enough to go past that ridge. It helps the hose slip on and prevents leaks by filling any nicks, dents and casting imperfection in the fitting it's going on. It was normal procedure when I first started working on cars and was even prescribed in various factory workshop manuals but seems to fallen out of favour in recent decades. I usually use this: https://www.permatex.com/products/ga...ealant-liquid/
regards Blue |
19-01-2019, 08:57 AM | #14 | |||
Modern manufacturing techniques have reduced the variation so it is no longer a problem (in modern countries). The tolerances they make stuff to nowadays is amazing in comparison to back then, unfortunately others things have also progressed - we also now know how to make something last *exactly* 3 weeks longer than the warranty... |
19-01-2019, 09:58 AM | #15 | ||
Plastic coolant flanges go brittle with heat and age so it is possible that over tightening the hose clamp could cause this.
XC GS OLD SCHOOL MUSCLE Audi A4 S-line quttro Xc falcon Previous fords- xc falcon 500 ,250 x flow 3 speed xc gs worked 250 x flow 4 speed xa Fairmont 302 auto wagon xb falcon 250 log auto 4 door xb falcon 200 log auto ute xc gs project - had to sell :-( xc gs 302 4 speed 4 door xc gs 351 auto 4 door zf fairlane 302 auto zk fairlane 250 x flow carb auto zl fairlane 250 x flow EFI auto xg ute , BA falcon dedicated gas xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5 |
19-01-2019, 12:47 PM | #16 | |||
regards Blue Last edited by aussiblue; 19-01-2019 at 12:53 PM. |
19-01-2019, 01:11 PM | #17 | ||||
What Gates says at https://www.gatesaustralia.com.au/~/...april-2015.pdf :
And Supercheap https://www.supercheapauto.com.au/bl...ator-hose.html : Ok I know SC are not always the best place for tech advice. Quote:
regards Blue Last edited by aussiblue; 19-01-2019 at 01:22 PM. |
19-01-2019, 01:28 PM | #18 | ||
Typically cast parts also have a joint ridge where the two parts of the mold join running the length of the pipe fitting on both sides like on this apparently OEM BA Falcon thermostat upper housing
from ebay https://www.ebay.com.au/p/BA-BF-Falc...Ltd/1171348148 Sealant will help seal the hose there. Even plastic parts often have these mold join lines e.g.: https://www.ebay.com/p/Coolant-Coole...18/23014214355 Ditto with this Ford OEM FG one albeit the the ridge looks smaller and smoother except on the underside outer lip and look at the lump there https://www.ebay.com.au/itm/GENUINE-...H0-:rk:43:pf:0 So more precision hmmm? Perhaps we've gone full circle and the focus on cost of parts rather than quality means the use of sealants on coolant hose will be back in fashion again.
regards Blue Last edited by aussiblue; 19-01-2019 at 01:41 PM. |
19-01-2019, 09:22 PM | #19 | ||
No one has said sealant is a bad idea, combined with tightening firm, it is a rock solid combination
The old gasket goo / aviation cement #3/4 use to be top shelf of every tool box, that's not the case any more. regarding quality, (as with many things - including hose clamps) you usually get what you pay for, I wouldn't use no name brand hose clamps or thermostat housings - cooling and oil systems are too important. |
19-01-2019, 09:50 PM | #20 | ||
Well you won't overtighten a spring/constant tension clamp.
IMO they are better than the screw drive clamps. Anyone have any negatives/bad experiences with them? - apart from getting them off, which is usually because of not using the correct tool. |
20-01-2019, 12:13 AM | #21 | ||
I prefer this type of stainless T bolt hose clamp but there is probably even more chance of over-tightening and breaking something.:
I find the spring/constant tension clamps lose tension with age.
regards Blue Last edited by aussiblue; 20-01-2019 at 12:18 AM. |
20-01-2019, 12:37 AM | #22 | ||
20-01-2019, 12:37 AM | #23 | ||
*barks incessantly
You can definitely over-tighten a hose clamp on a car which has plastic inlet/outlet pipes on the radiator. With heat cycles and age the plastic gets brittle and it's not uncommon to see them collapse. I don't reckon it would even be that hard to crush a brand new plastic hose if you got a bit over-excited and kept tightening it.
20-01-2019, 08:37 AM | #24 | |||
I think if someone doesn’t have the ‘feel’ for tighten a conventional clamp with a ratchet, then they should probably leave the job for someone else. When I was an apprentice at a truck shop we were Iveco service agents. Probably the worse built trucks with more PD issues than anything else. Around ten years ago the NZ fire service ordered some 80 Euro cargos, which ****ed coolant out of nearly every hose. I was sent to where they were kitted out for a week to seal up all the hoses with that aviation sealer... I can still remember what it smells like and it took about one week for it to run off my skin but it did the job. |
20-01-2019, 01:33 PM | #25 | |||
Cabover nut
20-01-2019, 01:44 PM | #26 | ||
The heat shrink (e.g. Gates Powergrip) ones never seen to have caught on here like they did in the US. https://www.youtube.com/watch?v=4O91YqHbp8c
Anyone ever used them or found them in a production car here?
regards Blue |
20-01-2019, 01:46 PM | #27 | |||
BA/F6 BF/F6 SSV/R TTG
Over tightening will be a contributing factor but not the main cause
20-01-2019, 01:58 PM | #28 | |||
Cabover nut
"Honey did you bring your 12v hair dryer."
20-01-2019, 02:18 PM | #29 | ||
The other issue with cast aluminium is that the cooling and/or quench cycles ( see http://www.themetalcasting.com/alloy-cooling-rate.html etc) can have an impact on both the strength of the product and the susceptibility to fracturing so the skills, experience, quality controls and cooling technology employed in the casting factory/foundry will be a factor. Where castings are left to air cool on racks, or cooled with blown ambient air even very variable ambient temperature or climatic location of the factory site may also be a factor (perhaps sometimes the sub zero sometimes in some Chinese factories V generally much warmer Kilkenny Castings in South Australia).
regards Blue |
20-01-2019, 02:41 PM | #30 | |||
regards Blue Last edited by aussiblue; 20-01-2019 at 02:54 PM. |
