Old 18-01-2019, 01:09 PM   #1
PeteBlu
Question Can a hose clamp be over-tightened?
I recently had a mechanic tell me that it is impossible to over-tighten a hose clamp so much that it could cause a flange to break. This was after they replaced the radiator hose in my car, and the flange on the thermostat housing broke off (see pic.)
Seems unlikely to me, what do you think?
Cheers.
PeteBlu is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2019, 01:31 PM   #2
roKWiz
Cabover nut
roKWiz's Avatar
Default Re: Can a hose clamp be over-tightened?
I've broken a few new hose clamps over tightening. SS, mild steel.
Broken a alloy pipe flange under it over tighening one as well.
New stuff seems to be chinese junk.
Old 18-01-2019, 01:33 PM   #3
Mont5.0
Mont5.0's Avatar
it would depend what you did it up with. A phillips head screwdriver will only let you go so far, but a 7-8mm socket can go a lot harder.
FGII XR6 IN LIGHTNING STRIKE
R52 SIII IN GUN METALLIC
Mont5.0 is offline   Reply With Quote Multi-Quote with this Post
9 users like this post:
Old 18-01-2019, 01:53 PM   #4
Silver Ghia
Silver Ghia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: As Silver Ghia his contributions to the AU and BA technical areas have been of high quality and valuable to the member base.
Cheers.
Looks badly corroded, which would have caused it to break off.
But care should be taken not to overtighten hose clamps, otherwise they may fail too.
Silver Ghia is online now   Reply With Quote Multi-Quote with this Post
Old 18-01-2019, 02:01 PM   #5
bangm001
Mopar! But Own F6's..
Do you use coolant? Is it the proper ford coolant?
F6 TYPHOON
FPV 335 GT
bangm001 is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2019, 02:07 PM   #6
I think he has a Mondeo with a plastic thermostat housing. And they are more vulnerable to stress fractures like that. Pretty corrosion resistant thought :-)
Old 18-01-2019, 02:46 PM   #7
PeteBlu
Yes, and yes. Can I ask why?
Old 18-01-2019, 02:47 PM   #8
PeteBlu
Correct. And the stress fracture could be caused by over-tightening the clamp do you think?
Old 18-01-2019, 02:49 PM   #9
Yes; plastic deforms then breaks.
Old 18-01-2019, 02:57 PM   #10
Silver Ghia
Ah, it looked like badly corroded aluminium. Sorry.
Yes, plastic would break.
Old 18-01-2019, 03:18 PM   #11
xeeclipse
Always used TRIDON clamps. They don't cut into the hose like some other brands.
Should always be done up with an 8mm 1/4 drive until the worm drive binds. If reusing an old hose either switch the drive around 180 degees or trim if excessively swollen.
xeeclipse is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2019, 09:42 PM   #12
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Hose clamp's should never be done up tight, let alone super tight.
Just firm, if the correct hose is used and in new condition then the clamp should only be firmly done, if you over tight them then you run the risk of future leaks.
The clamp should be just positioned on the far side of the ridge on a housing and done firmly, people often over tighten clamp's thinking the tighter the better but in actual fact you squeeze/squash the hose and cause leaks.
Old 18-01-2019, 10:34 PM   #13
It's also good practice to put a thin layer non hardening gasket goo around inside of the hose end far enough to go past that ridge. It helps the hose slip on and prevents leaks by filling any nicks, dents and casting imperfection in the fitting it's going on. It was normal procedure when I first started working on cars and was even prescribed in various factory workshop manuals but seems to fallen out of favour in recent decades. I usually use this: https://www.permatex.com/products/ga...ealant-liquid/
Old 19-01-2019, 08:57 AM   #14
383hq
This was common when manufacturing variation was much larger than it is today - back in the day when dad would pack a spare fan belt, tools, water for anything more than a 30 mile journey "just in case"
Modern manufacturing techniques have reduced the variation so it is no longer a problem (in modern countries). The tolerances they make stuff to nowadays is amazing in comparison to back then, unfortunately others things have also progressed - we also now know how to make something last *exactly* 3 weeks longer than the warranty...
383hq is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2019, 09:58 AM   #15
falconhell74
falconhell74's Avatar
Plastic coolant flanges go brittle with heat and age so it is possible that over tightening the hose clamp could cause this.
XC GS OLD SCHOOL MUSCLE
Audi A4 S-line quttro
Xc falcon
Previous fords-
xc falcon 500 ,250 x flow 3 speed
xc gs worked 250 x flow 4 speed
xa Fairmont 302 auto wagon
xb falcon 250 log auto 4 door
xb falcon 200 log auto ute
xc gs project - had to sell :-(
xc gs 302 4 speed 4 door
xc gs 351 auto 4 door
zf fairlane 302 auto
zk fairlane 250 x flow carb auto
zl fairlane 250 x flow EFI auto
xg ute , BA falcon dedicated gas
xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5
falconhell74 is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2019, 12:47 PM   #16
I'm not convinced when it comes to cooling system parts; some of the Chinese castings, even for OEM parts, for thermostat housing and water pumps I've seen are fairly rough. Yes the plastic radiator tank pipes and thermostat housings are much more perfect. I think the quality of the castings from the Japanese and Australian factories from the 60's, 70's and 80's was better. The other problems using sealant overcomes is the modern phenomena where pinholes have been punched in hoses where price or number tags have been attached to them with plastic ties.
Old 19-01-2019, 01:11 PM   #17
What Gates says at https://www.gatesaustralia.com.au/~/...april-2015.pdf :
Hose suggestions: Replace with the recommended Gates hose. Gates uses
compounds that offer better resistance to the negative effects of compression set.
Clamp torque suggestions: To avoid cold water leaks, adjustable tension clamps must
be retightened after a brief run-in period. Another solution is to use constant-tension
clamps, which automatically adjust with the heating and cooling of the system.
Connector suggestions: A beaded connector offers better sealing and retention
characteristics. The smoother the finish of the connector, the less tendency to leak under
the clamp. Brass and cast iron fittings adhere to common rubber compounds after time,
which reduces possibility of leaks, as does the use of sealants and viscous gels.
And Supercheap https://www.supercheapauto.com.au/bl...ator-hose.html :
Ok I know SC are not always the best place for tech advice.
Apply some sealing compound to the inside of the new hose fittings and place the loosened clamp over the hose ends before sliding the new hose into position on the engine block and radiator fittings.
Old 19-01-2019, 01:28 PM   #18
Typically cast parts also have a joint ridge where the two parts of the mold join running the length of the pipe fitting on both sides like on this apparently OEM BA Falcon thermostat upper housing
from ebay https://www.ebay.com.au/p/BA-BF-Falc...Ltd/1171348148
Sealant will help seal the hose there. Even plastic parts often have these mold join lines e.g.: https://www.ebay.com/p/Coolant-Coole...18/23014214355
Ditto with this Ford OEM FG one albeit the the ridge looks smaller and smoother except on the underside outer lip and look at the lump there https://www.ebay.com.au/itm/GENUINE-...H0-:rk:43:pf:0 So more precision hmmm? Perhaps we've gone full circle and the focus on cost of parts rather than quality means the use of sealants on coolant hose will be back in fashion again.
Old 19-01-2019, 09:22 PM   #19
383hq
No one has said sealant is a bad idea, combined with tightening firm, it is a rock solid combination
The old gasket goo / aviation cement #3/4 use to be top shelf of every tool box, that's not the case any more.
regarding quality, (as with many things - including hose clamps) you usually get what you pay for, I wouldn't use no name brand hose clamps or thermostat housings - cooling and oil systems are too important.
Old 19-01-2019, 09:50 PM   #20
snap0964
Well you won't overtighten a spring/constant tension clamp.
IMO they are better than the screw drive clamps.
Anyone have any negatives/bad experiences with them? - apart from getting them off, which is usually because of not using the correct tool.
snap0964 is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2019, 12:13 AM   #21
I prefer this type of stainless T bolt hose clamp but there is probably even more chance of over-tightening and breaking something.:
I find the spring/constant tension clamps lose tension with age.
Old 20-01-2019, 12:37 AM   #22
snap0964
Yes they do, and replacing them is easy enough - can't say though I could ever find any the size for the upper and lower rad hoses.
Old 20-01-2019, 12:37 AM   #23
Junkyard-Dog
*barks incessantly
Junkyard-Dog's Avatar
You can definitely over-tighten a hose clamp on a car which has plastic inlet/outlet pipes on the radiator. With heat cycles and age the plastic gets brittle and it's not uncommon to see them collapse. I don't reckon it would even be that hard to crush a brand new plastic hose if you got a bit over-excited and kept tightening it.
Junkyard-Dog is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2019, 08:37 AM   #24
smoo
smoo's Avatar
Haha, I think the question should be, has any had any good experiences with them? Bloody dogs of things, especially if it’s in a tight spot or they need to come off/on with the engine hot.
I think if someone doesn’t have the ‘feel’ for tighten a conventional clamp with a ratchet, then they should probably leave the job for someone else.
When I was an apprentice at a truck shop we were Iveco service agents. Probably the worse built trucks with more PD issues than anything else. Around ten years ago the NZ fire service ordered some 80 Euro cargos, which ****ed coolant out of nearly every hose. I was sent to where they were kitted out for a week to seal up all the hoses with that aviation sealer... I can still remember what it smells like and it took about one week for it to run off my skin but it did the job.
smoo is online now   Reply With Quote Multi-Quote with this Post
Old 20-01-2019, 01:33 PM   #25
roKWiz
Cabover nut
roKWiz's Avatar
Must say I've had a couple loose their tension. Many the smaller ones around a heat source.
Old 20-01-2019, 01:44 PM   #26
The heat shrink (e.g. Gates Powergrip) ones never seen to have caught on here like they did in the US. https://www.youtube.com/watch?v=4O91YqHbp8c
Anyone ever used them or found them in a production car here?
Old 20-01-2019, 01:46 PM   #27
arronm
BA/F6 BF/F6 SSV/R TTG
arronm's Avatar
Cheers.
Plastic = hard and brittle. Cast metal = corrosion.
Over tightening will be a contributing factor but not the main cause
BA BF FPV starter button repairs. PM me.
Nizpro equipped and Tuned by the BEST in the west
Xtreme Ford Tuning
479RwKw Fuel limited, more pumps and power too come.
F6#0507 & #0639 Pro racer and Tech expert
NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below.
https://youtu.be/oa4IfguGQ-A
arronm is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2019, 01:58 PM   #28
roKWiz
Cabover nut
roKWiz's Avatar
Looks nice but wouldn't fancy carrying extra removal tools and having to replace one out on the side of the road.
"Honey did you bring your 12v hair dryer."
Old 20-01-2019, 02:18 PM   #29
The other issue with cast aluminium is that the cooling and/or quench cycles ( see http://www.themetalcasting.com/alloy-cooling-rate.html etc) can have an impact on both the strength of the product and the susceptibility to fracturing so the skills, experience, quality controls and cooling technology employed in the casting factory/foundry will be a factor. Where castings are left to air cool on racks, or cooled with blown ambient air even very variable ambient temperature or climatic location of the factory site may also be a factor (perhaps sometimes the sub zero sometimes in some Chinese factories V generally much warmer Kilkenny Castings in South Australia).
Old 20-01-2019, 02:41 PM   #30
Yes definitely an issue. They've been using them for about 20 years in North America including on some production cars and they are also called shrink band clamps (see https://books.google.com.au/books?id...0bands&f=false etc.) and Boa Clamps (as in boa constrictor and with a wide variety of brand names. I can see why manufacturers would like them on assembly lines; probably much quicker to fit and a quaranteed seal but I wonder what their in use life is like.
