17-06-2017, 10:14 PM | #1 | ||
Needav8
On an AU3 XR8....
What do these do? I ask because my speedo works fine, but my ECU is throwing a code for the VSS......? Will the VSS effect the engine/tune etc in any way if throwing a code?
Back in the game with an '02 AUIII manual XR8 |
18-06-2017, 09:08 AM | #2 | ||
Chairman & Administrator
Maybe not - the VSS is used as an input to the PCM and ABS systems as well as providing data to the cluster via CAN bus.
Observatio Facta Rotae
18-06-2017, 01:20 PM | #3 | ||
So what is the fault code ??
18-06-2017, 04:03 PM | #4 | ||
Needav8
I use Forscan and it literally says VSS, not sure what the code number was.
Was throwing a cam posi sensor fault too which I replaced and it went away.
18-06-2017, 04:06 PM | #5 | ||
Needav8
18-06-2017, 07:22 PM | #6 | ||
Needav8
So I got under there today.
There was some oil seepage on the sensor, cleaned it all up then pulled the plug apart, wasn't easy as there was some green corrosion on the pins. Cleaned it all out and put it back together full of RP7 and the VSS fault code is gone...
10-05-2018, 04:50 PM | #7 | ||
2009 Fg xr6 turbo
Im getting this code on my s3 xr8 too,im assuming its the speedo sender that causes this?
Might have to give mine a clean too,my speedo also works fine. |
10-05-2018, 05:51 PM | #8 | |||
Au Falcon = Mr Reliable
cheers, Maka
Ford AU Series Magazine Scans Here - www.fordforums.com.au/photos/index.php?cat=2792 Proud owner of a optioned keeper S1 Tickford Falcon AU XR6 VCT - "it's actually a better-balanced car than the XR8, goes almost as hard and uses about two-thirds of the fuel" (Drive.com 2007) |
11-05-2018, 07:30 PM | #9 | ||
FG XR50 TURBO
I think I had the same issue with my AU Fairmont turned out to be a faulty ABS module
as Maka has mention what other codes are you getting ?? https://fordforums.com.au/showthread...le#post6009355 cheers Dean |
