Old 07-09-2017, 09:57 PM   #1
DOOZIE DAISY
Default S3 xr8 ac compressor wont turn on?
Just disconnected my battery while fitting new coil packs to my xr8,all hooked up again and the ac compressor wont turn on now.
Am I missing something?
It worked a couple of months ago when I checked it?
The ac button light comes on when you press it but the comp isn't kicking in,i read that low gas can cause the comp to not kick in?
DOOZIE DAISY is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2017, 10:10 PM   #2
XC50077
Drive'n Cruise'n Live'n
XC50077's Avatar
Default Re: S3 xr8 ac compressor wont turn on?
Check the fan switch is actually switched to 1,2,3 or 4. I had it only partially engaged and Air con switch wouldn't illuminate .Cheers.
XC50077 is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2017, 10:37 PM   #3
DOOZIE DAISY
Yeah fan switch is definitely on,fuse is good,relay has been swapped for a good one,when you press the on button the relay doesn't click on.
Almost like the ecu isn't telling it to turn on.
Ac button lights up when pressed.
I thought there was some trick I missed after reconnecting the battery.
I read in another ba thread if you wait for the error symbol to go out from the dash after you connect the battery again but it never went off.
Old 07-09-2017, 11:09 PM   #4
DOOZIE DAISY
Was hoping it may have been a simple fix I could sort tonight.
Ill book it in to get sorted.
Old 08-09-2017, 12:45 PM   #5
DOOZIE DAISY
As I kind of suspected,something was telling the compressor to not turn on,it was because the gas was low/non existant.
Leak near the receiver drier most likely the a/c guy told me,hopefully it doesn't turn out to be a dash out job if its not the drier...
Old 20-09-2017, 08:15 PM   #6
DOOZIE DAISY
Just for the record if the ac system is low on gas the compressor will not kick in, like a self preservation function to save the compressor from damage,just in case someone else has the same issue.
