Old 09-05-2007, 05:38 PM   #1
Riksta
Captain Malcolm Reynolds
Riksta's Avatar
Default "Fog" lights in front bumper C2R kit
Well, the other night I noticed that the two little lights I have in my front bumper are no longer turning on.
I've just been out to my car and checked out the fuses, I checked the book and there is one in the under-the-bonnet fuse box marked "space for spare" or something, and mine actually has a fuse in there, so I thought it could be that one controlling them, but the fuse in there is fine. If it is hooked up with another fuse, then surely something else in the car wouldn't be working, and everything is fine.
None of the wires to them seem to be broken or anything. The little switch mounted on the dash that turns them off & on also lights up green when you turn them on, like it previously did, but the actual lights themselves still remain off.
I'm kind of stumped, any suggestions?
Currently: 2014 Mazda6 GT (Daily) and 1999 Mazda MX5 (Fun Car)
Previously: 2001 Ford Escape XLT; 2010 MC Mondeo; 1984 FD LTD; 2001 AU2 Falcon Forte; 2005 LS Focus Zetec; 1988 RE Colt; 1982 RB Colt; 1974 KE20 Corolla
Originally Posted by Nikked
Riksta likes VN's so much, he has the ashes of a VN in a jar on the mantle piece, a vile of VN engine oil hanging from his neck and a BT1 build plate locked up in a safe, buried under 6ft of concrete.
Originally Posted by Day-mow
pretty much what has happened here is i trolled you. and it was fun.
Riksta is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2007, 05:46 PM   #2
HLC
Audi S3
wouldnt the "space for spare" fuse be a spare fuse lol?
Old 09-05-2007, 05:50 PM   #3
T3man
T3man's Avatar
You need to test if there is power to the lights first. You need a multimeter or test probe.
If there isn't then you need to trace the circuit to/from the switch on your dash. There will be a break in the circuit somewhere.
If there is power to the lights then it is two blown globes (or two bad earths).
Old 09-05-2007, 06:05 PM   #4
Riksta
Riksta's Avatar
LOL you have a point. I just assumed it meant it was a spot to wire anything new up to!
T3Man, good idea, I'll raid the shed see if I can find a multimeter, and check the globes.
If it gets too much effort for me, the car's going in soon for a couple of things to get fixed under warranty, so I'll get them fixed too :P
Old 09-05-2007, 06:17 PM   #5
JC
JC's Avatar
There should also be a fuse near the battery - this wasn't factory wiring, I assume, which means it will have it's own power supply from the battery, and any auto-lecky worth their salt would put an in-line fuse within 30cm of the battery.
So..if it's not a blown fuse and it's not blown globes, then more than likely it's a dicky relay.
Ford Performance Club ACT
Old 09-05-2007, 06:35 PM   #6
Riksta
Riksta's Avatar
Thanks heaps JC, I'll check it out.
Old 09-05-2007, 09:30 PM   #7
bodes-sh
also, have you checked to make sure the output of the switch hasn't come unplugged? i mean the wire that goes to the relay to turn the lights on
Old 10-05-2007, 01:22 AM   #8
Riksta
Riksta's Avatar
Yeah, checked all that tonight.
On flicking the switch for those lights off and on, it seems that the relay is clicking.
Also, there's power getting right down to the lights fine (or so the multimeter says).
I'm putting my money on blown globes now, will check that out most likely on the weekend when I've got time to start unscrewing the things and stuff...looks like the lights mounted behind the bumper could be sealed beams - if they are I will be replacing them with something that I can change the bulbs over easily in!!!
Old 10-05-2007, 09:16 AM   #9
bodes-sh
also as suggested above, before you go pulling the lights, check the grounds on them, unless you already did, and make sure they are grounding properly
Old 10-05-2007, 01:15 PM   #10
Riksta
Riksta's Avatar
Was all checked, dad's an electrician (not auto) so kind of knows what to look for, got him to give me a hand
Everything seems fine on the electrical/wiring/grounding side of things.
Old 10-05-2007, 01:20 PM   #11
T3man
T3man's Avatar
Yes, I think they are sealed beams - if you want to replace them with the same light (which you may have to do because I think the mount is specific for those lights only) I have seen them in Auto Parts shops much cheaper than from the C2R people. I've also seen them at the Parklea Markets. That's if they are the (I think) SIS brand or something???? My son has them on his car which is not here for me to check out so am going just on my (sometimes bad) memory
Old 10-05-2007, 02:51 PM   #12
Riksta
Riksta's Avatar
T3man, what I might do is see if I can check out supercheap or somewhere of the like, see if I can find some that mount & fit in there, but have changeable bulbs. Would be a lot easier and cheaper in the long run than changing the whole unit over everytime they stuff up.
Of course, if this is not possible I'll stick with the sealed beam units.
