Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Pit Lane Performance
Pit Lane Performance Pit Lane Performance, tuning for power and satisfaction. Website Link
Old 05-01-2018, 04:45 PM   #1
ratter
ratter's Avatar
Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful.
Default Barra Ghost cam tunes
As many people realize, you're only as good as the tools you use, and part of that is using the best tool for the job to get the desired results.
With the recent release of PCMtec tuning software, we have been able to access tuning tables in the Australian Ford ecu that were once non accessible.
As an example, we can now get full access to the camshaft control tables that control the VCT settings.
What that means is we can now adjust the cams to help with power levels or for modified camshafts to work better or even as a bit of a novelty give a "Ghost Cam Tune,"
What is a "Ghost Cam Tune"?
A "Ghost Cam Tune" is a tune that idles roughly like an "Old School" car used to idle like, once large performance cams were fitted, giving the tuned car an impression of performance.
We have attached a video showing the results of a quick adjustment to a otherwise stock FG XR6T, please notice though that this is just a quick adjustment and could possibly be improved upon with some more adjustments.
https://www.facebook.com/pitlaneperf...5918268392394/
What does that mean for you?
Here at Pit Lane Automotive and Performance, we can offer you the best way to tune your car based on your requirements as we can offer SCT, HP Tuners and now PCMtec as tuning software options when your car is tuned.
20 Rosella St Frankston 03 9783 8122
Authorised KPM, Herrod Motorsport & SCT Tuning Agent,
ratter is offline   Reply With Quote Multi-Quote with this Post
6 users like this post:
Old 05-01-2018, 04:49 PM   #2
Default Re: Barra Ghost cam tunes
Ratter... Can a "Ghost Cam Tune" be added to a car that has already be tuned at not a high cost without having to retune everything again?
Thanks
________________________________________________
2014 FG MKII XR6 Turbo - Kinetic Blue
Herrod Tuned • 289rwkws (387rwhp) - 776Nm • 17 PSI • 1000cc Injectors • Herrod Intake • Herrod S/S Catback • TS BOV • Catch Can • SCT X4
PW Intake Pipe • DBA T2's • DRLs • CQuartz Ceramic Coating • Audio Upgrades • Gauges • Perimeter Alarm • Michelin PSS's
Index to Mods & Tips In My Show ' N Shine Thread
_Thread_______________________________ Thread
Old 05-01-2018, 05:14 PM   #3
Mercury Bullet
I love these but 2 questions.
1. Can it damage the engine?
2. Can you do it on Miami's with no exhaust vct?
www.bseries.com.au/mercurybullet
2016 Falcon XR8. Powered by the legend that is - David Winter.
XC Cobra #181.
1985 Mack Superliner, CAT 3408, 24 speed Allison.
Mercury Bullet is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2018, 07:50 PM   #4
ratter
ratter's Avatar
Thanks
At this stage it appears it can be added to an existing tune but it would be flashed direct to the ecu
Old 05-01-2018, 07:52 PM   #5
ratter
ratter's Avatar
it’s probably not good on standard cats although early testing showed reasonable afr’s so may possibly be ok.
No, it can not be done on our 5.0’s
Old 05-01-2018, 08:50 PM   #6
Fairlane 5OO
Fairlane 5OO's Avatar
Great R&D Mick,
I am sure you will be able to get more out of an engine by adjusting the VCT through this.
Be interesting to see what you develop out of it in the future.
Fairlane 5OO is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2018, 02:39 PM   #7
ratter
ratter's Avatar
yes, there should be gains in the top end now we can control camshaft overlap, just need time to play with it
Old 06-01-2018, 03:06 PM   #8
I've always felt there would be some money to be made if someone invented a device that fitted inside the exhaust piping and controlled the exhaust flow through two separate pipes in an alternating pulsating manner when idling to create that "Old School" V8 harmonic note.
Then as the throttle was opened, the device would fully open to unrestrict the exhaust flow.
Old 06-01-2018, 05:22 PM   #9
sixman
sixman's Avatar
Ratter, do you have a preferred tuning platform for the barra?
FG MkII XR6T Limited Edition Manual
Bilstein shocks, SuperPro Bushes, MalWood Shifter
Front tyres: Goodyear Eagle F1 A2 245-35-19
Rear tyres: Toyo R888 265-30-19
3.5inch custom exhaust with imitation stock tip, PW Stage 2 cooler (black), ID 1000, XCAL3, Plazmaman intake, Herrod Spark Booster
BorgWarner EFR 9174
Autotech 420rwkw
sixman is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2018, 07:03 PM   #10
ratter
ratter's Avatar
I’m still most comfortable with SCT, but like to think I’m competent with HP and now PCMtec, HP still has a few tables that I use for tuning missing but they do fix things in most cases where they can.
PCMtec has more than enough but can not do ZF but this should change shortly.
I guess it gets down to exactly what a customer requires and using the best tool for the job.
Old 06-01-2018, 10:29 PM   #11
ratter
ratter's Avatar
I have attached a you tube link for those that do not have Facebook
https://youtu.be/Q_SVBXU27oY
Old 07-01-2018, 08:36 AM   #12
baboon
BA XR6T JTG LPG
baboon's Avatar
Contributor: For members who make a contribution worthy of recognition. - Issue reason: went to the trouble of posting up some great Vids of the AFF drag meet
This is great news and nice work on the FG XR6T above!
Would it be possible to have a Barra Ghost cam tune done on a dual fuel BA XR6T on JTG and be able to control the ghost cam idle on fuel changeover from petrol to LPG? If so, I might pay you a visit in the future!
baboon is online now   Reply With Quote Multi-Quote with this Post
Old 07-01-2018, 09:51 AM   #13
ratter
ratter's Avatar
It is not possible to do a ghost cam tune on a BA sorry, they do not have individual cam control
Thread Tools
Display Modes
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
