Old 24-12-2017, 12:06 AM   #1
cruza
Default Escort motor into mk1
I have put a 1600 711M escort motor into my mk1 cordy, the passenger side engine mount is nearly impossible to bolt up, so obviously I need a different mount, which mount do I need? Thanks in advance
cruza is offline   Reply With Quote Multi-Quote with this Post
Old 24-12-2017, 11:19 AM   #2
Rallye Sport
RS The Faster Fords
Rallye Sport's Avatar
Default Re: Escort motor into mk1
I think you'll need a Cortina Mk2 1600 x-flow mount. The crossmembers are pretty much the same between Mk1 & 2 so that'd be the only different part between them.
Mk1 GT Cortina Project.
FG XR50 Daily.
Old 24-12-2017, 11:55 AM   #3
cruza
Thanks for the info rallye sport, I will give it a go, at the moment it’s like having solid steel mounts
Old 17-04-2018, 10:30 PM   #4
xmchamp
From memory, this is correct and will work, did this when I was eighteen which is one hell of a long time ago, well into the last century.
xmchamp is offline   Reply With Quote Multi-Quote with this Post
Old 16-07-2018, 10:01 PM   #5
burnz
VFII SS UTE
burnz's Avatar
A question: can I legally put a 2.0 ecoboost into a 1974 mk1 1300 escort.. N.S.W.
I don't often hear the sound of a screaming LSX.
But when I do, So do the neighbours..
GO SOUTHS
burnz is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2018, 07:22 AM   #6
happy1
Hi,
do you mean subject to engineering report and inspection etc. ?
For sure no parts of the drivetrain of the 1.3 would match the power of your engine, so you would need to bring suspension and brakes up to RS2000 standard or beyond as part of your project.
(I have no idea about NSW rules).
Cheers,
happy1 is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2018, 09:54 PM   #7
burnz
VFII SS UTE
burnz's Avatar
Originally Posted by happy1 View Post
Hi,
Cheers,
thanks happy, yeah as per law..
also wondering structural body strength..
GO SOUTHS
Old 18-07-2018, 10:26 PM   #8
happy1
I am not an Escort Mk1 / 2 expert, but have seen modification of MK2 being approved from 1.3 to full RS2000 spec, which required welding in extra brackets for the arms holding the diff in place.
First of all you need to ensure your shell has no rust. If the floor pan, inner sills, and outer sills are not in 'new' condition, then you will not get approval for increased power.
The engineer may require that you perform stiffness testing of the shell. It's where a moment arm is attached in the front, and the torsion of the shell is measured.
Cheers,
Old 19-07-2018, 08:14 PM   #9
Rallye Sport
RS The Faster Fords
Which eco boost are you planning to use? from which model?
No such thing as RS2000 spec, all mk2, 2 litre cars have larger front struts thats all. Everything else is the same and transferable between Mk1 and 2
FG XR50 Daily.
Old 20-07-2018, 06:04 AM   #10
burnz
VFII SS UTE
burnz's Avatar
FG falcon will do..
GO SOUTHS
Old 21-07-2018, 09:27 PM   #11
Rallye Sport
RS The Faster Fords
Might need to do some measurements first, from what I understand they're too tall due to sump clearance. Let us know what you come up with it'd be an interesting conversion if its viable.
FG XR50 Daily.
