Old 16-11-2010, 09:33 PM   #1
Thunderchild
Thunderchild's Avatar
Default Diesel hazard
I was chatting with one of my work mates and we were discussing my Ranger work ute. He mentioned that a friend of his is a member of a Pajero club and that they had lost four members who were all killed investigating fuel problems with their diesels and had released the pressure on the common rail which he tells me is at about 2700lbs pressure and died instantly. I was wondering if is correct as I had never heard of this before.
Glenn
Thunderchild is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2010, 09:41 PM   #2
LS2 KLR
LS2 KLR's Avatar
This is a very real possibility, and I'm sure people have died from tinkering where they shouldn't. If pressure is released from the common rail first there will not be a problem.
LS2 KLR is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2010, 11:21 PM   #3
madmelon
Yes, even with a small volume of liquid, when ejected with a pressure like that it can cut straight through you. Also, the (somewhat older) practice of purging diesel rails/lines by cracking a fitting is a massive no-no as once the seepage starts at that pressure, it wont stop. Like a water jet cutter through anything in its path...
madmelon is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2010, 12:45 AM   #4
XR Martin
XR Martin's Avatar
I doubt the death bit, but people may have lost fingers or had deep cuts on the hands.
2004 BA wagon RTV project.
Old 17-11-2010, 01:22 AM   #5
jpd80
jpd80's Avatar
Even more probable is the injection of fluid into limbs, body and face, think about that..
this is a real possibility with hydraulic hoses in industry, the practice of running your hands
over operating hydraulic hoses to feel for leaks is strongly discouraged for obvious reasons...
jpd80 is online now   Reply With Quote Multi-Quote with this Post
Old 17-11-2010, 01:26 AM   #6
vztrt
IWCMOGTVM Club Supporter
vztrt's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: vztrt is one of the most consistent and respected contributors to AFF, I have found his contributions are most useful to discussion as well as answering members queries.
Newer diesels are getting higher and higher pressures (needed to get emission standards), now its to the point were the manufacturer recommends changing the fuel lines after the pressure has been released. So it could happen, but I've never heard of death.
Daniel
vztrt is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2010, 01:42 AM   #7
wrongwaynorris
wrongwaynorris's Avatar
Seriously doubt the death bit but injuries yes . Try working on a Caterpillar Acert engine , injection pressures of 23,000 PSI , NO thats not a typo Twenty Three Thousand PSI .
http://www.cat.com/technology/acert-technology
wrongwaynorris is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2010, 01:44 AM   #8
Windsor220
Now Fordless
Windsor220's Avatar
What were they doing releasing the pressure in the rail while the engine was running anyway?
Windsor220 is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2010, 01:51 AM   #9
fmc351
let it burn
I used to hydroblast at 13,000 psi, I saw what that did to railway sleepers the pipes and pipe bundles sat on. I remember one guy lost his thumb to a 1mm pin nozzle at the same psi. A major medical problem was as has been already mentioned, the ingress of fluid under the skin layer.
fmc351 is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2010, 02:02 AM   #10
burnz
VFII SS UTE
burnz's Avatar
Glenn
as other posts have stated 28,000 psi is the norm..
and iv'e normally us a farley water jet to cut any object, that said i wouldn't supprise me if a fatality occured playing with diesel fuel lines..
the effective cutting range on human tissue is around 350mm distance, a jet of diesel fired at the head, heart, lungs of even arm entering the blood stream may prove fatal..
I don't often hear the sound of a screaming LSX.
But when I do, So do the neighbours..
GO SOUTHS
burnz is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2010, 02:58 AM   #11
FPV GT
I Like To Shake It
FPV GT's Avatar
High Pressure Injection (HPI) Injury can indeed be fatal. However most of these injuries are restricted to the hands, and in some cases intially the patient is not even aware that a HPI has occurred.
Usually the injury looks very innocent, however it is damage to the tissues underneath the skin, and possible toxicity of the injected medium that cause the issues.
It has been reported that HPI injuries have travelled along the natural lines of the bodies internal structures reeking damage as it goes, causing mass trauma.
About two years ago in Port Kembla NSW, a man suffered a fatal laceration to the chest after an accident with a water blaster.
Regards
Paul
Regards
Paul
2016 S550 TY GT Coupe....some loud bits and some glass bits
I like My GT SHAKEN, and Blown
Happiness is a TY S550, a 1911 semi automatic, and the Lovey Lizzie by my side.
Originally Posted by Lovely Lizzie
whilst looking at man riding a pee wee 50
"That sure does nothing for his masculinity"
FPV GT is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2010, 10:06 AM   #12
ltd
Force Fed Fords
ltd's Avatar
It is very real. Not just the cutting from the fluid jet, but diesel poisoning (diesel fuel in bloodstream) alone is enough to kill someone.
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley
Powered by GE
ltd is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2010, 12:17 AM   #13
Mad Maxine
Mad Maxine's Avatar
And slightly off topic, but only just: this is why you should never use a compressed air hose to blow paint or dust off yourself - you can force the contaminant into your skin. I used to see spray painters do this all the time in the bad old days, not so much now, so many of you probably already know this.
Mad Maxine: Pray that she's out there...... somewhere
1977 XC GS Coupe
Mad Maxine is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2010, 06:46 AM   #14
wrongwaynorris
Actually more to do with creating an embolism , air under extreme pressure will permeate skin , get enough of it and you can form an embolism which if big enough will stall your heart when it reaches it .
Old 18-11-2010, 06:57 PM   #15
barra265t
Man, this is scary. So a water pistol can technically be a deadly weapon . Gee it sucks to be human.
barra265t is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2010, 08:02 PM   #16
fmc351
let it burn
Id think it would need some significant PSI.
Old 18-11-2010, 09:45 PM   #17
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
I've seen that done many times at work, but it seems to be the older guys who do it.
Old 18-11-2010, 10:10 PM   #18
CAMS290
trying to get a leg over
CAMS290's Avatar
And what a pile of crap they are too, nearly sent a mate of mine broke.
Piston rings in upside down from the factory, required engine rebuild.
Cat had to disconnect and by pass some electronic thingo so it would get better than 1.6kpl on B double work.
Cat shot themselves in the foot with that motor, almost as bad as the half assed 3406c back in the early 90's,
Cameron
CAMS290 is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2010, 11:07 PM   #19
Danny
GT4.
Danny's Avatar
Nope I do it a lot, so I don't get dust in the car.
Danny is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2010, 03:10 AM   #20
nb_351
building the xe...
nb_351's Avatar
doing the plant mechanics course at tafe, being mainly hydraulics we get told many a story...
one was a guy who ws a firefighter, went out to an accident, got a pinhead size skin puncture using the jaws of life... ended up needing amputation of several limbs due to mieral oil being used and spreading through his whole body, causing massive reactions and severe infections, requiring amputation... not good...
slowly but surely fixing up the king of the road
WANTED
P5 ltd/landau taillight centre panel
nb_351 is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2010, 03:12 AM   #21
nb_351
building the xe...
nb_351's Avatar
too true mate, most of our freighliners at work run the cats, and theyre rubbish... suit the rest of the truck mind you hahaha
but yeah theres always issues, blown this leaking that...
i always on breakdown calls for them lol
WANTED
Old 22-11-2010, 12:23 AM   #22
dad25
This is very true, diesel is a strong poison,a few week's ago in Adelaide
a guy die'd from swallowing diesel thru sigphonig it , Also any oxygen bubble
injected into your'e blood stream can be fatal thats why medics remove
all air from a syringe before injecting you,its also not a good idea to blow
compressed air directly onto your'e skin,any cuts can potentally let oxygen
into the blood stream.
dad25 is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2010, 12:36 AM   #23
music189
Exclamation small cars as well have high pressure
I was doing some training on a Hyundai i30 diesel a while back and with the scan tool conected we saw 198 k kpa on the scan tool while monitoring the live data that equals 28000 psi !!!!! no its not a misprint!!!
so dont open any of those high pressure lines, fiestsa,mondeo,and up coming Territory diesel will all have similar pressure to that
music189 is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2010, 02:54 AM   #24
barra265t
Isn't a simple fuel pump in let's say a compact diesel powered car quiet, small and runs on 12v and can hit around 28,000 PSI?
Old 22-11-2010, 07:06 AM   #25
kpcart
smart reply, i want to see replies to this. is 28,000 PSI deadly? lets find out...
kpcart is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2010, 07:11 AM   #26
fmc351
let it burn
You mentioned a water pistol. Im not aware of any such water pistol.
Old 22-11-2010, 01:19 PM   #27
barra265t
Haha, maybe not exactly a pistol.. hmm a water bazooka or water turret?
Old 22-11-2010, 02:59 PM   #28
vztrt
vztrt's Avatar
I know with the CAT engines that the PSI isn't increased till it gets to the engine. From the tank the pressures are quite normal.
Daniel
