06-04-2007, 03:46 PM | #1 | ||
that's the sum of it, i need to replace the top hose in my AUII 6cyl and i need to know how to bleed the system?
thanks in advance guys n girls. paul.
i was going how fast officer? |
06-04-2007, 03:52 PM | #2 | ||
fill the coolng system, leave the cap off the reservior, hold the revs on about 2k for about 5 or 10 mins will be completely bled, although with you only replacing the top hose, i doubt there will be much air trapped in the system
06-04-2007, 03:54 PM | #3 | |||
One assumes the Falcon would have a similar setup.
Some people think I suffer from A.D.D., but they... Oh LOOK! A Chicken! |
06-04-2007, 03:58 PM | #4 | |||
Was going to say that wth a top hose replacement it probably won't need bleeding ... unless you have dumped all of your coolant and given the engine cooling system a flush out (which won't hurt if you haven't done one in a long time). But as mentioned .. the procedure as mentioned above .... oh .... put you heater on full blast as well while doing this. It might take a while to get to full operating temperature though ... but it will get there eventually ... if i get bored of sitting on the accelerator for that long I just partially close the bonnet and let it idle till it gets there .... and top up reservoir if necessary as well.
06-04-2007, 04:04 PM | #5 | ||
also, if your lazy you can put a 5 or 10 cent peice between the throttle linkage and the idle screw on the throttle body
06-04-2007, 05:58 PM | #6 | |||
The top off the tank method is the only way to get the air out of the system.
06-04-2007, 09:22 PM | #7 | |||
06-04-2007, 11:15 PM | #8 | ||
thanks heaps everybody, i flushed the system and replaced the coolant 5000klms ago so no need to dump the lot, i'll replace the hose, and run it up to operating temp, check the res and top up if necessary.
cheers, paul.
07-04-2007, 09:33 AM | #9 | |||
I've posted several problems with my AU, and so far, nobody's suggested anything that's actually made a difference. I posted a few times about my dad's Fairmont, and not one person suggested what actually turned out to be the problem. Do I have a go at them for posting an answer when the solutions they offered turned out to not help? NO! I thank them for at least trying to help. Some people appreciate anyone at least trying to help. It's how a place becomes friendly. Ever heard of that, friend? :
07-04-2007, 09:58 AM | #10 | |||
Blown 5L coming
crash, i think maybe you need to relax, yes its true people do sometimes offer advice that is useless to the original poster, but there is no need to cause arguments over the subject, not only does it get off topic, but it puts in posts that are of no use to anyone and makes you look like a fool. besides, what is offered as advice to one person, may actually help anohter, did you ever think of that? late model cars, unless the coolant fill point is lower then the highest point of the cooling system, can be bleed in the above mentioned process. however, if the fill point is lower then the highest point of the system, there is often a bleeder valve similar to that of your braking system, as offered by crash in his first post. now we have this cleared up, be happy people....thats why our forum is so good, lots of happy helpfull people
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;) NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com Quote:
07-04-2007, 04:08 PM | #11 | ||
well, the dealers are closed till tuesday so i'll wait till then to change this hose, bummer really, i wanted to do it today and go for a roll tonight, oh well.....
au2sw, are you saying that because the reservoir with the pressure cap is above the radiator and cyl head that that is the fill point and it will self bleed through running it? i'm really paranoid about cooking my head, they're never the same after.
