Old 09-05-2010, 10:34 PM   #1
BradZ
I'm still alive
BradZ's Avatar
Default Pinto vs Kent
What are the differences between the two? Pros/Cons? And to save making another thread, will an altenator of a 1600 kent fit a 2ltr pinto?
2006 BF XR6
Winter White
Visual
-Lowered on SSSL's
-5000k Headlight conversion
-DJR Bobtail
-Darkest legal tint
-Tinted taillights
Audio
-Ford Premium Sound
-Pioneer 1000W 12'' Sub
-Pioneer Class D Digital 800W Amp
Performance
-Custom Cold Air Intake
Build Thread http://fordforums.com.au/showthread.php?t=11344773
BradZ is offline   Reply With Quote Multi-Quote with this Post
Old 10-05-2010, 12:36 PM   #2
Puzzlescort
Rally Nut
Puzzlescort's Avatar
kent are a pushrod motor ranging from 1100, 1300, 1500 & 1600
pinto are OHC mainly 2ltr in Aust although there is a 1600 also
a kent alt will not fit a pinto
Puzzlescort is offline   Reply With Quote Multi-Quote with this Post
Old 10-05-2010, 10:36 PM   #3
BradZ
I'm still alive
BradZ's Avatar
**********!!!! Just spent a lot of money getting one posted here...What part of it doesnt fit? It looks roughly the same shape.
2006 BF XR6
Winter White
Visual
-Lowered on SSSL's
-DJR Bobtail
-Darkest legal tint
-Tinted taillights
Audio
-Ford Premium Sound
Performance
Old 10-05-2010, 10:36 PM   #4
BradZ
I'm still alive
BradZ's Avatar
**********!!!! Just spent a lot of money getting one posted here...What part of it doesnt fit? It looks roughly the same shape. And in your opinion, which motor is 'better'?
2006 BF XR6
Winter White
Visual
-Lowered on SSSL's
-DJR Bobtail
-Darkest legal tint
-Tinted taillights
Audio
-Ford Premium Sound
Performance
Old 10-05-2010, 11:17 PM   #5
Jimmyd
Personal preference leans to Pinto - can pull reliable (and quite streetable) 130-150hp without too much trouble or breaking the bank, need a second morgage or a hairdrier on a Kent to get those numbers and will be no where near as reliable.
Just my opinion though, i'm sure some Kent boys will jump in with weight differnces etc.....
James
Jimmyd is offline   Reply With Quote Multi-Quote with this Post
Old 12-05-2010, 02:57 PM   #6
BradZ
I'm still alive
BradZ's Avatar
What part of a kent alt wont fit a pinto??
2006 BF XR6
Winter White
Visual
-Lowered on SSSL's
-DJR Bobtail
-Darkest legal tint
-Tinted taillights
Audio
-Ford Premium Sound
Performance
Old 12-05-2010, 04:43 PM   #7
eski666
eski666's Avatar
Pinto Power all the way, as said it makes easy reliable horse power. Kent engines can make up to 110hp as well but will cost a fortune to do.
Cant remember the differences in the alternators though, I adapted a S5 RX7 alternator to mine, works a treat!!
New engine on the way :
Weisco Pistons, Total Seal rings, Crower rods, BIG lumpy stick, TO4E with back cut exhaust wheel 1.0 rear housing 30psi!!, major head modification! Bring on the 1/4 mile :
eski666 is offline   Reply With Quote Multi-Quote with this Post
Old 12-05-2010, 05:28 PM   #8
V8falcons
V8falcons's Avatar
2ltr pinto guys sorry but no contest there.200+hp is acheivable with a bit of cash thrown at one.
A quick upgrade is an xf falcon 55amp job,cheap engough you just have to fit some spacers in there and away you go.
You old alternator wasnt a lucas by chance was it? There are really only good for door stops.........
T2 TE50 no:154 Narooma blue
AU2 XR8 ute
XR4 fiesta
V8falcons is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2010, 05:43 PM   #9
eski666
eski666's Avatar
Yeah I have used an XF one too but it wasnt giving me power I needed as I was running aftermarket EFI, with the lights on at night the voltage would drop way down! Soon as I fitted the mazda one its been strong as ever!
Old 13-05-2010, 07:55 PM   #10
2lt_Scort
85Amp from a 90's Magna should do the job nicely. Use a 6cyl Cortina top bracket.
Mk2 2dr 2lt Escort
Mk2 2dr 1.6lt Escort - now a 2lt.
2lt_Scort is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2010, 05:43 PM   #11
Neale
Neale's Avatar
depends what its going into, & what you want to achieve. They originally put the 2L into escorts because of auto gearboxes & polution gear was draining power from the standard 1600 crossflow.
Basically its going to cost alot of cash to get performance out of any motor, & if you want big hp figures you may aswell get an SR20 or something like that.
To put a pinto into a mk1 escort there is the expense of engineering, changing radiators, gearboxes, suspension, brakes crossmembers & engine mounts, etc. where if you put a basic turbo with low boost on a 1600 you can get reliable power out of a standard motor & torque goes through the roof (this will also flog a standard pinto). it fits straight in without the modifications plus you can put it on club rego!!
Saying that if you did the same to a pinto you would also good torque & power maybe more. If you already have a mk 2 with a pinto there is probably no reason to swap it for a 1600, & you will get good poer from it if you choose to spend a bit of cash on it.
If your in sydney on june 6 the small ford car club will be holding a dyno day, if your interested in seeing the differences in motors these sort of days will give you a good idea, & you can talk to everyone
Neale is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2010, 09:32 PM   #12
BradZ
I'm still alive
BradZ's Avatar
Thanks for the replies. As for the altenator, the one off a Kent 1600 is now in and working in my car. I just welded up a new bracket and its fine. Although it doesn't put out any voltage under 3k revs, and when i turn the ignition off the car stays running untill i turn the lights on. I'll work it out.
@Neale- I have no intention of swapping my pinto for a kent, mine's already been worked a fair bit so i'm happy with the power at the moment. Chasing 130hp though (:
2006 BF XR6
Winter White
Visual
-Lowered on SSSL's
-DJR Bobtail
-Darkest legal tint
-Tinted taillights
Audio
-Ford Premium Sound
Performance
Old 20-05-2010, 12:29 PM   #13
Jimmyd
1976 Ford Escort 2ltr Mk2 2 Door 4sp manual w/ Pinto
-Engine-
Bored to 2.2
Crow Cams race cam
Port Polished
Racing clutch
Oversize extractors
Machined dual throat weber carb
Regulator......
Chasing 130hp @ the flywheel? Should already be there with that recipe provided the head work has been done correctly and it has been tuned properly. The std 32/36DGAV will get you in that ball park, after that you want the 38DGAS off a Capri or a even a 34ADM from a XE-XF Falcon can get you there.
If chasing 130hp @ the treads you will need to go to duel 45s to even have a chance
Old 20-05-2010, 12:59 PM   #14
BradZ
I'm still alive
BradZ's Avatar
I'm after 130hp at the wheels. With the current set up it is supposed to ( and has in the past) pull 113hp at the wheels. I'm not sure what you mean by twin 45's? I think the next mod will be elec ignition or something like that as mentioned by one of the members, what gains should i expect from that?
2006 BF XR6
Winter White
Visual
-Lowered on SSSL's
-DJR Bobtail
-Darkest legal tint
-Tinted taillights
Audio
-Ford Premium Sound
Performance
Old 20-05-2010, 01:22 PM   #15
Puzzlescort
Rally Nut
Bradz what they mean by twin 45's is twin sidedraught weber carbies - 45 is the size of the throat
I would be very surprised if you will get 130hp at the rear wheels (roughly 170bhp allowing for 30% loss thru driveline) with a single modified downthroat weber, that equates to approx 95 rwkw which is getting very quite high for a pinto. I might add it does depend on what dyno is used as dyno figures can vary greatly from dyno to dyno
A solid pinto with a good cam, big valve head, good exhaust, high compression running twin 45's etc will be in the vancity of 160-180 + bhp, of course there are motors pushing up into the 200+ bhp area but are very heavily worked on twin 48's
probably need to know more about the motor specs
picture of pinto with twin 45's added
Old 20-05-2010, 04:38 PM   #16
Jimmyd
Puzzlescort is dead on the money.
Realistically 113rwhp is getting to the maximum power you can extract from a single dual throat carb - just simply can not flow enough air to produce more power. Keep in mind that if you are chasing 130rwhp with a NA 8v Pinto head that you will ultimately be sacrificing low down torque for absolute power - up around these numbers she will be a bit doughy below 2-3,000 rpm and will drive you nuts in traffic if she is a daily driver.
Don't get me wrong, it can be done but reliability and driveablilty will suffer. If you are chasing these numbers and you still want to maintain daily driver flexibility and reliablity you really need to be looking at either a 16v Sierra head conversion or forced induction - but of course that depends on your tolerence levels for driveablilty and the size of your wallet.......
James
Old 20-05-2010, 05:05 PM   #17
Puzzlescort
Rally Nut
I should add to Jimmy's post of driveability, you want some good low down torque if your racing on dirt, if you are on a circuit track where you can maintain very high rpm then maybe sacrifice low down, we have spent plenty of time on the dyno getting the balance of power / driveablity right for driving on dirt
As I have said in other posts Bradz lets look at the rest of the package that you have, what carbies, diff ratio, gearbox etc. You might find your motor is very strong but other items are letting it down, a close ratio gearbox is like adding 30 bhp compared to the std escort box
Old 20-05-2010, 08:51 PM   #18
V8falcons
V8falcons's Avatar
I just started/tested/tuned my new 2ltr engine (I built) yesterday,it has standard bore new rings bearings, nicely well ported head,44.5 in,38.5 ex valves,661 crow cam,vernier cam wheel,double valve springs match ported/modified stock manifold,rejeted 38mmDGAS weber(for the interim),electronic ign....etc
I would be lucky to see 110hp max at the rears,I would say.
Im going to a dyno in a few weeks so I'll let you know,And will play with the cam timming
It pulls very well for it first run without a dyno tune,happy so far.It also can be driven sensibly as well
I would be looking for a nice flat tourqe curve over a big power figure.
AU2 XR8 ute
XR4 fiesta
Old 24-05-2010, 03:17 PM   #19
BradZ
I'm still alive
BradZ's Avatar
How much would a twin 45 setup cost me? And where should i go looking? The car is very rarely under 3k revs. The car has a short diff ratio as i dont think it would go over 120kms. If i manage to find a twin 45 setup and new manifold, i'm probably going to need fatter rear tires? It gets no grip as is.
2006 BF XR6
Winter White
Visual
-Lowered on SSSL's
-DJR Bobtail
-Darkest legal tint
-Tinted taillights
Audio
-Ford Premium Sound
Performance
Old 24-05-2010, 06:02 PM   #20
BradZ
I'm still alive
BradZ's Avatar
The edit button has vanished on me so i'll post again. I'll list the engine mods as best i can. Has been bored to 2.2 (i think), the carb has been machined, it has much larger than normal extractors, port polished, Crow Cams race cam and the whole motor itself has been rebuilt. I dont think i've missed anything. The carb on that motor is supposed to push 113hp. The car is purely for rallying so driveability isnt really an issue. So after hearing this, what sort of numbers should i be expecting with twin 45's? And what sorta price am i looking at and where from?
2006 BF XR6
Winter White
Visual
-Lowered on SSSL's
-DJR Bobtail
-Darkest legal tint
-Tinted taillights
Audio
-Ford Premium Sound
Performance
Old 24-05-2010, 06:50 PM   #21
Puzzlescort
Rally Nut
BradZ
what we are trying to help with is firstly
- if you havent had the car on a dyno to get the supposed numbers then GET IT on one to see for yourself before you do anything else to see what & when the power is coming in. You need the benchmark to see where you can go to & can judge what effect the modifications that you do make
secondly
we make remarks on the rest of the package, gearbox, diff ratio, suspension to see what other cheap improvements can be made to help with the overall performance of the car
many of us here, like myself have been rallying / racing for over 20 years and soon realised that the ever search of more power is useless and expensive without being able to turn corners or get the power to the ground, espically on dirt in my case. I wish these forums were around 20 years ago when I started out, it would have saved a lot of money on developement being able to tap into a world of information
hopefully we can try to steer you in the right direction to spend the right money in the right places to get the best results
for twin 45's you could pay anywhere from 650? to over $1000, then they will need to be tuned to the motor.. does your motor have a big valve head? what compression ratio is it?
Old 25-05-2010, 02:00 PM   #22
V8falcons
V8falcons's Avatar
I have a set of dellorto 40s on a manifold with ram tubes and KN filters ,no linkages they can be had cheaply,PM me if your interested will be on ebay shortly.
AU2 XR8 ute
XR4 fiesta
Old 25-05-2010, 10:46 PM   #23
BradZ
I'm still alive
BradZ's Avatar
PM sent.
Puzzlescort, i dont know about the valve heads nor the compression ratio but i do know its higher than stock. Getting the car to a dyno is a lot harder than you think. With no license, no car trailer (relying on friends), no father to take you and a mother who is too scared to pull the car it makes it quite hard.
2006 BF XR6
Winter White
Visual
-Lowered on SSSL's
-DJR Bobtail
-Darkest legal tint
-Tinted taillights
Audio
-Ford Premium Sound
Performance
Old 25-05-2010, 11:15 PM   #24
Puzzlescort
Rally Nut
hey Bradz
no probs mate - we all started out like you. I know there is an event up at Swan hill over the long weekend, unfortunately I wont be going this year. you should jump onto yahoo groups and search / join the VCAS (Victorian Club Autocross Series) and see when & where the events are..
We are getting off topic, but, if you can make it to the Bendigo event run by Cerberus I will gladly take you for a couple of laps or if you get your car there spend some time going over it with you. I think apart from Swan hill track of course Bendigo would be the next closet
Old 26-05-2010, 09:58 PM   #25
BradZ
I'm still alive
BradZ's Avatar
Yeah i'm hoping to have my car done for the June meet. I need to re-wire it a bit because it isn't starting even with a charged battery. I'm also going to fill in a dent on the side behind the rear wheel from last race (whoops). I'd just really like to get a bit more power outta the old girl.
2006 BF XR6
Winter White
Visual
-Lowered on SSSL's
-DJR Bobtail
-Darkest legal tint
-Tinted taillights
Audio
-Ford Premium Sound
Performance
Old 06-06-2010, 12:23 AM   #26
obsesscort
obsesscort's Avatar
hey guys am new here. just for BradZ if you're after some webers check out ebay I had a quick squiz for ya but not sure what specs you need, heres a cheap example
http://cgi.ebay.com/ebaymotors/WEBER...Q5fAccessories
obsesscort is offline   Reply With Quote Multi-Quote with this Post
