Genuine Ford Parts A forum for the purchase of genuine Ford parts via an AFF member. |
#2221 | ||
![]() Join Date: Nov 2011
#2222 | ||
Yeh, the Owner manual, the service CAWS guide and the SYNC manual, all brand new in clear wallet. Never been filled out so you can have the backs filled out.
#2223 | ||
Cheers mate, I'll PM you.
#2224 | ||
yes thats the one. mounted on the door. can you PM me total price to 6062? cheers again.
#2225 | |||
FG Rear Door Mould.png FG Rear Door Parts.png |
#2226 | ||
http://www.fordforums.com.au/photos/...ppuser/2517052 first time ive tried to insert an image..... hopefully it works. its the half one to the right (like felt as u get in door belts) which i think is the circled part in your first image. nope couldnt insert image so just a link to my gallery. Last edited by FPV 460; 13-01-2025 at 05:31 PM. |
#2227 | |||
#2228 | ||
hahaha... thats nuts, hard pass but thanks for the info.
BTW can you pls give that part number? thanks. |
#2229 | ||
#2230 | ||
Parts Fiend
Are the shadow grey FGX Ute A & B pillar trims available?
Successful Sales With frenzal56, falconxr, loosecannon, lima_been, bo5ton, Mardk, Chapter Four, leakey, POELWYK, Dman4.0, rayban76, tutor, PridenJoy, Aplito Futura, sbutler, Bosko, storta1, portokatsiki, AUte, 5.8, xxxg, FTW-302, LeadFoot81, Peuty, BillM, Sox, needfordspeed, watejs06, CATXR8 |
#2231 | ||
#2232 | ||
Hello.
Any information regarding a part number for one of these SX rear glass brackets, Thanks. tailgate.jpg |
#2233 | |||
RH: SXA42146A LH: SXA42147A After 1/4/2009 they changed to: RH: 9R7ZA42146AA LH: 9R7ZA42147AA Not sure what the differences are or if they are interchangeable either? |
#2234 | ||
Thank you so much for the information.
#2235 | ||
Mr GT,
Just curious... Are the BF N/A I6 engine mounts NLA these days? Or still available? If still available, could you scare me with a price please. ![]() |
#2236 | |||
In general they are obsolete, but I did manage to find 2 x NOS laying around various suppliers. They are $150 each plus postage (that is if they are still there?). Gather these would be the last around (apart from personal collections). GT |
#2237 | ||
Parts Fiend
Thanks for the info, are there any FGX ute shadow grey trims available? Ive got sunvisors and coat hooks. Interior lights, grab handles etc?
#2238 | |||
Thanks for the reply. But at $150 each they are a bit too pricey for my wallet. I really don't like this POS that much the spend that kind of $$$... ![]() I remember seeing them around for $150 mark a pair a while back. That might have been the time they started to run them out. |
#2239 | ||
Howdy GT Legend. I'm hoping I can use your knowledge and skills in parts interpretation to provide some guidance on a brake-related issue, and point me towards the right parts if required.
I've got an FG F6 310 2009 model that came fitted with the basic Brembo 4-pot fronts and single-pot (red painted) rear callipers. I've managed to snag a used set of the "Premium Brake Package" 6-pot Brembo front and 4-pot rear Brembo callipers with Goodridge lines that apparently suit an FG like mine. The fronts fit perfectly using the existing rotors, however the rear callipers don't seem to suit the rear rotors. Does the premium 4-pot rear Brembo brake setup require a different rotor than the basic FPV single-pot rear brake setup? Diameter seems to suit, but the "offset" of the rotor seems just wrong and I've ended up with the inside pad jammed hard up against the inside face of the rotor when fitted up. Given that these callipers were bought secondhand, I'm also considering the possibility that the rear callipers may not be correct for my car, although I'm hoping it's just that I need the specific rotors for the 4-pot rear callipers. If the latter is the case, I might just get a full set of front and rear Premium Brake package rotors to suit the FG F6. I appreciate your time considering my query. You've certainly saved my bacon a few times and your services are a bloody godsend for this forum, and for anyone keeping an "obsolete" Ford on the road. ![]() Cheers, Ben
It's easier to get forgiveness than permission. |
#2240 | |||
So to start I will advise all brake discs for FG1 2008-2011. Front Rotors: Std: 298mm dia. AY1125A High Series Brakes: 322mm dia solid face. BAF1125B Performance brakes (Brembo): Early 2/2008 to 5/2008 355mm and grooved BAF1125B, but then from 5/2008 on they changed to 355mm but drilled BG1125A. So in essence front rotors for either 4 or 6 piston front Brembo's both used same BG1125A 355mm rotor. Rear Rotors: Std: 303mm dia solid face BGC2C026A High Performance Rear Brakes: 328mm dia and drilled BAFC2C026B. (This is what is fitted to vehicles with Brembo 4 pot on front and red PBR caliper on rear) From what I believe, the red PBR caliper is the same as a standard rear caliper just red. So this is what your vehicle would have had originally. Premium Brakes (Brembo): 330mm dia drilled. They are also different left to right. RH BG2C026B LH BG2C027B. So I think you need to change from the 328mm to the 330mm rotors to suit the Brembo rears over the red PBR that you have. I tried to see what else is different with doing the upgrade. From what I could tell the fronts have different flexible brake hoses from 4 to 6 pot Brembos and that's all that's different. On the rear, the rotor for red PBR type have spring washers with the wheel studs, the Brembo style do not, the rubber grommet to adjust the handbrake shoes are different between the two and so are the flexible brake hoses. Hope that helps and answers your question. Let me know if you need any further info. |
#2241 | |||
I might as well get a new set of front rotors to match the 6-pot callipers as well, which will give me new-ish "Premium Brake Package" 6F/4R callipers with brand new rotors to suit. It will also give me a complete set of the "High Performance Brake Package" option that was originally fitted to my F6 to put on the shelf and possibly fit to another project I've got waiting in the wings. If you could PM me a price on a full set of rotors to suit the FG Premium Brake Package, including freight to Orange NSW I'd be very appreciative. Thanks as always, Ben
#2242 | ||
George
![]() Join Date: Jun 2015
Hi GT,
Looking for all info regarding availability of a pair of dual zone blend door shaft kits, to suit my 2007 BFII Fairmont Ghia. Apparently there was also a later “improved” version of the drive shafts? Thanks, regards, George.
BFWSM https://www.fordforums.com.au/vbport...articleid=1708 http://fordforums.com.au/wsmpub/ba/501-05.html ![]() R/Up 2019 ![]() ![]() PWR Air/Oil Cooler, K&N, Egas elbow, V8 upper F6 lower CAI. 1997 Fairmont EL Ghia Tickford 4L Auto ![]() 1985 Falcon XF GL 4.1L Auto. 1979 Fairmont XD Ghia 4.1L Auto. 1971 Cortina GL Estate 1200cc Manual. |
#2243 | |||
https://www.ebay.com.au/itm/15314233...Bk9SR8Lu_OKYZQ |
2 users like this post: |
#2244 | |||
George
BFWSM https://www.fordforums.com.au/vbport...articleid=1708 http://fordforums.com.au/wsmpub/ba/501-05.html ![]() R/Up 2019 ![]() ![]() PWR Air/Oil Cooler, K&N, Egas elbow, V8 upper F6 lower CAI. 1997 Fairmont EL Ghia Tickford 4L Auto ![]() 1985 Falcon XF GL 4.1L Auto. 1979 Fairmont XD Ghia 4.1L Auto. 1971 Cortina GL Estate 1200cc Manual. Last edited by BFIIGhiaZF6; 02-02-2025 at 10:08 PM. |
#2245 | ||
Wasn't someone making them in metal? Although I think that would just cause other parts to break instead.
#2246 | ||
George
One more question GT, if I may, with respect to the HVAC heater shaft, do you happen to know what year/model Falcon the “improved” shaft was introduced?
#2247 | ||
3 users like this post: |
#2248 | ||
George
Thanks GT, that’s much appreciated.
#2249 | |||
Cost about $12 from local Ford dealer. Thanks again for your help. |
#2250 | |||
Costs about $12 from Ford dealer. |
Thread Tools | |
Display Modes | |
