Old 01-06-2006, 05:40 PM   #1
whiteknight66
Wink KB Laser Thermostat
Hey all...my Laser has a temp gauge that barely moves...earthed the gauge...it seems ok, so the thermostat will be changed..the one in there opens and closes, but can anyone suggest the correct temperature range that I should put in...ie: the factory one?
whiteknight66 is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2006, 07:29 PM   #2
VippiN
What a performer!
VippiN's Avatar
Don't know what you mean? If it's not getting warm good for you, generally the problem is getting too hot. :P
1981 Ford Laser KA :: E5 :: 2002-2003
1989 Ford Laser KE TX3 :: BP :: 2003-2007 75fwkW
1990 Ford Laser KF TX3 :: BP :: 2010-2011
1991 Ford Laser KF TX3 :: BP-T :: 2011-2015 109fwkW
2007 Ford Falcon BF XR6 Turbo Ute :: Barra 245T :: 2014-2019 324rwkW
1998 Ford Falcon AU XR8 Ute :: Windsor V8 :: 2019-2020
2008 Ford Fiesta XR4 :: Duratec 150 :: 2021-*
1998 Ford Falcon AU XR6 :: HP Intech :: 2021-*
VippiN is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2006, 07:47 PM   #3
dirty hands
Over Thinker
dirty hands's Avatar
If the thermostat was in the system it would raise the temperature
so it is my guess from what you describe someone has removed the thermostat
I would suggest you buy the one for the standard fitting listed for the car
add the coolant or anti freeze depending on where you live and go from there
also flush your radiator out at the same time
My car goes Brumm Brumm
dirty hands is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2006, 01:20 PM   #4
whiteknight66
The temp barely gets past the mark at the very bottom, the heater has a warm attitude so i figure it's running too cold, got told by a mate that if a car runs too cold then the fuel doesnt burn and leave very efficiently...is this true? I'd be happy if the temp got to a quarter....
Old 02-06-2006, 07:00 PM   #5
dirty hands
Over Thinker
Default yes
fuel economy and fouling plugs may occur
lots of problems when the car isnt running at temperature
you cant really tune it properly
get the thermo problem looked at when you can
Old 03-06-2006, 12:40 PM   #6
whiteknight66
Default thanks for the tips
ta all will give it a try
Old 21-06-2006, 12:36 AM   #7
whiteknight66
Default all good
Great. The thermostat that was in there was a weird looking thing indeed.Anyway installed a new one and hey presto...problem solved, I even have heat at 5am when I go to work
Old 01-07-2006, 06:27 PM   #8
revcore
revcore's Avatar
I had a similar problem with my KB but on a recent trip to the city I discovered that my thermostat was working properly because when I was waiting at the traffic lights with my foot on the brake and the car in drive, The temp went up to quarter way and remained there but went down when I began moving again.
My Ride...
2005 BA2 XR6 Magnet Ute.
revcore is offline   Reply With Quote Multi-Quote with this Post
Old 02-07-2006, 12:23 AM   #9
VippiN
What a performer!
VippiN's Avatar
That's probably because when you drove you got air into the engine bay faster..
Old 03-07-2006, 08:55 PM   #10
revcore
revcore's Avatar
Correct.
My Ride...
Old 27-02-2008, 11:47 AM   #11
irwin812002
Default Finding my thermostat
Can anyone help me find the thermostat in my ford last 92 model? I know nothing about cars and I have been told that my thermostat could be the problem and to remove it.
irwin812002 is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2008, 08:18 PM   #12
dirty hands
Over Thinker
follow the top radiator hose to where it meets the motor
there should be a housing that unbolts
under that housing should be the thermostat
search images of thermostat and thermostat housing in
google if it helps
http://images.google.com.au/imghp?hl=en&tab=wi
Old 07-09-2010, 02:38 PM   #13
AJT90Xr6
Also never add cold water... make sure it is room temp otherwise without the thermostat you can crack your head
AJT90Xr6 is offline   Reply With Quote Multi-Quote with this Post
