08-03-2016, 04:34 PM | #1 | ||
Hmmmmm Mulberry....
Howdy
Got a AU ute and the fuel pump is not running. Relay is switching on but pump not running. Can hot wire the pump, so i know its ok. Has anyone got a wiring diagram of the fuel pump circuit they than post or send me. Have looked online here, but it is barely readable, and i cannot print it off. Thank |
09-03-2016, 12:20 AM | #2 | ||
T-Series Club Member Vic
Have you tested that the relay is working, or are you hearing it click and assuming that means it's ok?
Try swapping the relay with another as a test if you haven't already. Good luck with it! |
27-11-2018, 06:18 AM | #3 | ||
I've got the same problem I know the pump is fine but have no power from the body back to the pump
Sent from my SM-G965F using Tapatalk |
