30-11-2016, 07:40 PM | #1 | ||
Sent from somewhere using Tapatalk
30-11-2016, 07:44 PM | #2 | ||
In relation to what?
Is it found in a Mondy or associated packaging?
Cheers Pete Melbourne 2010 Ford Mondeo Zetec TDCi Diesel Colour: Frozen White |
30-11-2016, 07:51 PM | #3 | ||
It's something I made for working on the Mondeo. A bit rough but it does the job.
30-11-2016, 08:22 PM | #4 | ||
To place over the body seam when you jack it up with your hydraulic Jack.
I have something similar for SWMBOs VW. Those from colder climates than ours use ice hockey pucks.
30-11-2016, 08:47 PM | #5 | ||
Yes, that's it. I initially used a block of wood under the seam until I managed to bend it when I jacked up the car too quickly.
I might check out the ice hockey pucks. Sent from somewhere using Tapatalk
01-12-2016, 09:28 AM | #6 | ||
I've been using discs of 3/4 plywood (no groove) in the trolley jack head. The seam just sinks in a bit.
The jack makers are a bit behind on this one. Some of the rubber pads look like they'd slice nicely in two. Not intended for sills I guess. I've assumed the vehicle weight should be taken on the edge of the seam, so the groove depth would be about 15mm. NZ your blocks don't seem to have been touching there? |
01-12-2016, 12:47 PM | #7 | ||
01-12-2016, 04:37 PM | #8 | |||
I had assumed that the weight was taken by the seam, but 3 of them have bent as a result of being used as lifting points. The shape of the scissor jack head is interesting - it looks to me as though the weight is taken on the inside of the sill. So that is how I've designed the wooden block, and it seems fine. But I could easily be wrong! I hate to mention the Accord for the second time this week, but the jacking points under the sills are far more substantial, and can be lowered directly onto axle stands. Or even dropped, as happened when the trolley jack release valve stuck! Sent from somewhere using Tapatalk
MB Mondeo TDCi wagon, sea grey, on MAK Invidia 16" wheels. Last edited by NZ XR6; 01-12-2016 at 04:43 PM. |
01-12-2016, 04:40 PM | #9 | |||
01-12-2016, 05:44 PM | #10 | ||
What are you lifting a truck?
You can jack it up from the suspension bolt front an rear just don't use the tips of the jacks plate,an don't use ply use a solid block of wood about 3 in high x 4in wide.you can bend the double plate of the subframe if its not forward enough closer to the wheel |
02-12-2016, 08:45 PM | #11 | |||
The Haynes manual suggests lifting the car under the centre of the front crossmember. You'd need a very special jack to reach that far! Sent from somewhere using Tapatalk
02-12-2016, 11:09 PM | #12 | ||
And these http://www.ebay.com.au/itm/Premium-S...YAAOSwImRYG08F and http://www.ebay.com.au/itm/HELI-GUY-...3D252639420309
regards Blue |
02-12-2016, 11:10 PM | #13 | ||
And you could make these yourself http://www.ebay.com.au/itm/HELI-GUY-...3D252639420309
regards Blue |
03-12-2016, 12:18 AM | #14 | |||
Challenge Accepted!
03-12-2016, 05:26 AM | #15 | |||
03-12-2016, 01:42 PM | #16 | ||
03-12-2016, 02:14 PM | #17 | ||
you could just use a standrd scissor jack to give you some clearance then slide in the trolley jack.. don't forget to crack the wheelnuts first (hate wen that happens)an grease the wheelnut thread when you do them back up...
03-12-2016, 03:11 PM | #18 | ||
Challenge Accepted!
top left $249 aluminium 2T, WTDHF20SA. it fitted when my suspension was sad and tired at it's lowest point, 3 to 4 pumps and it's off the ground. It's heavier than the typical single cylinder hydraulic jack but it does everything else easier/quicker and for that I'm grateful. Mine is red and sports a different brand but it's identical.
Word of warning if when you assemble the handle to it and start to pump the cylinder and the arm doesn't lift, remove the rubber fill plug on the main cylinder. I just started to pump it and it wouldn't lift. Figured out removing the plug to check the fluid level helps bleed it and away you go. I cycled it three times to make sure air was bled and it's been good ever since. |
